Skip to content
View in the app
Armbian Community Forums
  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
OrangePi 3 LTS - Bluetooth not working
Featured Replies
Wi-Fi works โ†’ so the problem is only in GPIO / DTB initialization for Bluetooth
It worked on the older kernel, but now it doesn't ๐Ÿ˜ž....
Supposedly this is the cause, but is it really?
Quote
DTB (device tree) does not configure GPIO reset/power for the UWE5622.
hci_uart cannot initialize the controller โ†’ hci0 is not created.
The overlay for BT in mainline 6.x does not yet exist in Trixie.
โŒ Result: hciconfig -a and bluetoothctl list show nothing.
armbianmonitor -u
https://paste.armbian.com/uzudezufit
Edited by kris777
Solved by kris777
Which kernel? Should work on 6.12.y, although I see issues with it on 6.18.y, as there were changes made to that wireless patch set that don't agree with my DTS changes.
In fairness, I haven't checked to see if it works at all regardless of my changes on that kernel though. Its on my list of things to investigate.
ย
The new DTS changes require an updated hciattach_opi binary. "known to work on 6.12.y"
https://github.com/armbian/build/blob/main/packages/blobs/bt/hciattach/hciattach_opi_arm64_upstream
ย
Welcome to Armbian!
Documentation: https://docs.armbian.com | Community support: https://forum.armbian.com
IP address: xx.x.x.xx
Create root password: *****
Repeat root password: *****
Developer Preview Build
This Armbian image was generated automatically for development and testing purpose.
It may include unfinished features or unstable components.
If you are not here to report issues or just test it, please do not use this image in production.
Expect things to change โ€” or even break โ€” as improvements are made.
Creating a new user account. Press <Ctrl-C> to abort
Please provide a username (eg. your first name):
Disabling user account creation procedure
root@orangepi3-lts:~# rfkill
ID TYPE      DEVICE         SOFT      HARD
 0 bluetooth bluetooth unblocked unblocked
 1 wlan      phy0      unblocked unblocked
 2 bluetooth hci0      unblocked unblocked
root@orangepi3-lts:~# bluetoothctl
[NEW] Media /org/bluez/hci0
	SupportedUUIDs: 0000110a-0000-1000-8000-00805f9b34fb
	SupportedUUIDs: 0000110b-0000-1000-8000-00805f9b34fb
Agent registered
[CHG] Controller 30:96:18:9E:A7:02 Pairable: yes
hci0 new_settings: powered bondable ssp br/edr le secure-conn
[bluetoothctl]> show
Controller 30:96:18:9E:A7:02 (public)
	Manufacturer: 0x01ec (492)
	Version: 0x09 (9)
	Alias: orangepi3-lts
	Class: 0x00400000 (4194304)
	Powered: yes
	PowerState: on
	Discoverable: no
	DiscoverableTimeout: 0x000000b4 (180)
	Pairable: yes
	UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
	UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
	UUID: SIM Access                (0000112d-0000-1000-8000-00805f9b34fb)
	UUID: PnP Information           (00001200-0000-1000-8000-00805f9b34fb)
	UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
	UUID: A/V Remote Control        (0000110e-0000-1000-8000-00805f9b34fb)
	UUID: Device Information        (0000180a-0000-1000-8000-00805f9b34fb)
	Modalias: usb:v1D6Bp0246d0554
	Discovering: no
	Roles: central
	Roles: peripheral
Advertising Features:
	ActiveInstances: 0x00 (0)
	SupportedInstances: 0x10 (16)
	SupportedIncludes: tx-power
	SupportedIncludes: appearance
	SupportedIncludes: local-name
	SupportedSecondaryChannels: 1M
	SupportedSecondaryChannels: 2M
	SupportedSecondaryChannels: Coded
	SupportedCapabilities.MinTxPower: 0xffffffec (-20)
	SupportedCapabilities.MaxTxPower: 0x0008 (8)
	SupportedCapabilities.MaxAdvLen: 0xfb (251)
	SupportedCapabilities.MaxScnRspLen: 0xfb (251)
	SupportedFeatures: CanSetTxPower
	SupportedFeatures: HardwareOffload
[bluetoothctl]> exit
root@orangepi3-lts:~# uname -a
Linux orangepi3-lts 6.12.74-current-sunxi64 #6 SMP Thu Feb 19 15:29:56 UTC 2026 aarch64 GNU/Linux
ย
  • Author
That's strangeย ย ๐Ÿ™‚ ...we have the same kernel. Maybe something's broken in the system? But I haven't messed with Bluetooth in the system. I've only updated the system: apt update /apt upgrade /reboot ๐Ÿ™‚
ย
ID TYPE ย  ย  ย DEVICE ย  ย  ย  ย  SOFT ย  ย  ย HARD
ย 0 bluetooth bluetooth unblocked unblocked
ย 1 wlan ย  ย  ย phy0 ย  ย  ย unblocked unblocked
bluetoothctl
Waiting to connect to bluetoothd...
it keeps reading but shows nothing?
 bt-device -l
ERROR:lib/bluez/adapter.c:165:adapter_get_dbus_object_path: assertion failed: (ADAPTER_IS(self))
Bail out! ERROR:lib/bluez/adapter.c:165:adapter_get_dbus_object_path: assertion failed: (ADAPTER_IS(self))
Aborted
Something must have broken in the system, but what and where?
ย
Can you give me the exact: Armbian image + version ...
Contents of ..../lib/firmware/uwe5622/
also: armbianEnv.txt
Output dmesg | grep -i uart i dmesg | grep -i bluetooth
Maybe that will help me figure out where the errors are in my system? Or maybe I have Debian and you have Ubuntu?
Ps.ย or, more simply, information from the file: diagnostics.txt
command in terminal:
uname -a
cat /etc/os-release
ls -lh /lib/firmware/uwe5622/
lsmod | grep -iE "bt|sprd|uwe"
ls /dev/tty* | grep -i "ttyS\|ttyAMA\|ttyBT"
cat /boot/armbianEnv.txt
rfkill list
hciconfig -a
bluetoothctl list
hcitool dev
bt-device -l
dmesg | grep -iE "bluetooth|uwe|sprd|hci"
) > diagnostics.txt
Edited by kris777
  • Author
I tested the new version (Armbian_26.2.0-trunk.591_Orangepi3-lts_forky_current_6.18.18_minimal) in terms of bloototh and it's OK... but there are errors that rule out this image. Namely, the system lacks 4 working processor cores ๐Ÿ™‚ ... only one.ย Something is wrong at startup because the green LED is on and the red LED is constantly flashing/pulsing.
Bringing up secondary CPUs ...
[ 5.092655] CPU1: failed to come online [ 5.092666] CPU1: failed in unknown state : 0x0
[ 10.217311] CPU2: failed to come online [ 10.217324] CPU2: failed in unknown state : 0x0
[ 15.341948] CPU3: failed to come online [ 15.341961] CPU3: failed in unknown state : 0x0
[ 15.342047] smp: Brought up 1 node, 1 CPU [ 15.342057] SMP: Total of 1 processors activated.
[ 15.342063] CPU: All CPU(s) started at EL2
[ 15.342112] CPU features: detected: 32-bit EL0 Support
[ 15.342119] CPU features: detected: 32-bit EL1 Support
[ 15.342129] CPU features: detected: CRC32 instructions
[ 15.342146] CPU features: detected: PMUv3
[ 15.342193] alternatives: applying system-wide alternatives
ย
It's some kind of incompatibility: U-Boot / TF-A / kernelย  ....
Similar errors are found in the version uploaded by: armbian imager (minimal / cli / debian - trixie) more information:ย https://paste.armbian.com/afokonucej
command "poweroff" not working ! ?
On version: Ubuntu / minimal (cli) there are the same errors regarding CPU...etc
dmesg | grep "CPU"
[ ย  ย 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ ย  ย 0.000000] Detected VIPT I-cache on CPU0
[ ย  ย 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ ย  ย 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ ย  ย 0.000000] CPU features: detected: ARM erratum 845719
[ ย  ย 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ ย  ย 0.000000] rcu: ย ย  ย RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ ย  ย 0.006129] smp: Bringing up secondary CPUs ...
[ ย  ย 5.092344] CPU1: failed to come online
[ ย  ย 5.092356] CPU1: failed in unknown state : 0x0
[ ย  10.216761] CPU2: failed to come online
[ ย  10.216771] CPU2: failed in unknown state : 0x0
[ ย  15.341165] CPU3: failed to come online
[ ย  15.341176] CPU3: failed in unknown state : 0x0
[ ย  15.341242] smp: Brought up 1 node, 1 CPU
[ ย  15.341258] CPU: All CPU(s) started at EL2
[ ย  15.341291] CPU features: detected: 32-bit EL0 Support
[ ย  15.341297] CPU features: detected: 32-bit EL1 Support
[ ย  15.341309] CPU features: detected: CRC32 instructions
[ ย  16.273971] ledtrig-cpu: registered to indicate activity on CPUs
[ ย  17.351303] sun50i_cpufreq_nvmem: Using CPU speed bin speed0
Edited by kris777
ย
Yes we're aware of this, since it affects all H5 and H6 devices. We have a few ideas about what could be the cause like added logging (yes, sounds odd but..oh well) or certain ATF version. https://github.com/armbian/build/issues/9555
ย
  • Author
  • Solution
After the update/upgrade, all CPUs are now installed
nproc
4
This didn't fix my Bluetooth (maybe it's some individual bug in my system?) but since Bluetooth works correctly in the new images for OrangePi 3 LTS, I'm marking this thread as resolved... I'll probably install the latest image soon, although it will be time-consuming.
orangepi3-lts:~# dmesg | grep "CPU"
[ ย  ย 0.005157] smp: Bringing up secondary CPUs ...
[ ย  ย 0.007070] Detected VIPT I-cache on CPU1
[ ย  ย 0.007260] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ ย  ย 0.009368] Detected VIPT I-cache on CPU2
[ ย  ย 0.009541] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ ย  ย 0.011117] Detected VIPT I-cache on CPU3
[ ย  ย 0.011261] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ ย  ย 0.011373] smp: Brought up 1 node, 4 CPUs
[ ย  ย 0.011398] CPU: All CPU(s) started at EL2
[ ย  ย 0.011443] CPU features: detected: 32-bit EL0 Support
[ ย  ย 0.011449] CPU features: detected: 32-bit EL1 Support
[ ย  ย 0.011458] CPU features: detected: CRC32 instructions
[ ย  ย 0.011470] CPU features: detected: PMUv3
[ ย  ย 0.260754] ledtrig-cpu: registered to indicate activity on CPUs
[ ย  ย 0.414642] sun50i_cpufreq_nvmem: Using CPU speed bin speed0
[ ย  ย 0.457342] WARNING: CPU: 3 PID: 71 at drivers/iommu/iommu.c:612 __iommu_probe_device+0x1a8/0x4a0
[ ย  ย 0.457375] CPU: 3 UID: 0 PID: 71 Comm: kworker/u16:4 Not tainted 6.18.19-current-sunxi64 #2 PREEMPTย
ย
Ps.ย I don't know if I announced the CPU solution too early? Maybe there's a problem with the processor clock speed?
cat /etc/default/cpufrequtils
ENABLE=false
MIN_SPEED=480000
MAX_SPEED=1810000
GOVERNOR=performance
root@orangepi3-lts:~# cpu
Temperature: 40 ย ยฐC
CPU-0 Frequency: 1608 ย Mhz
CPU-1 Frequency: 1608 ย Mhz
CPU-2 Frequency: 1608 ย Mhz
CPU-3 Frequency: 1608 ย Mhz
root@orangepi3-lts:~# cat /etc/default/cpufrequtils
ENABLE=false
MIN_SPEED=480000
MAX_SPEED=1810000
ENABLE=false
MIN_SPEED=480000
MAX_SPEED=1810000
root@orangepi3-lts:~#ย
root@orangepi3-lts:~# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
1608000
root@orangepi3-lts:~# cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
performance
performance
performance
performance
shouldn't it be : 1810000ย  ...ย  ?ย
Edited by kris777
Account
Navigation
Search
Search
Chrome (Android)
  2. Tap Permissions โ†’ Notifications.
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
