guidol Posted December 9, 2017 Share Posted December 9, 2017 I did a apt update & upgrade on my NanoPi Neo2 NAS and it updated to nightly 5.37 but at the beginning of the boot-log it tells me: Net: No ethernet found. I didnt get an eth0 interface from the mainboard ethernet-port (only lo) [ 1.633544] dwmac-sun8i 1c30000.ethernet: PTP uses main clock [ 1.798411] dwmac-sun8i 1c30000.ethernet: PTP uses main clock [ 1.798556] dwmac-sun8i 1c30000.ethernet: Will use external PHY [ 1.904820] dwmac-sun8i 1c30000.ethernet: Chain mode enabled [ 1.904832] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported [ 1.904842] dwmac-sun8i 1c30000.ethernet: Normal descriptors [ 1.904853] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported [ 1.904863] dwmac-sun8i 1c30000.ethernet: COE Type 2 [ 1.904873] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported [ 1.905433] dwmac-sun8i 1c30000.ethernet: Cannot register the MDIO bus [ 1.905452] dwmac-sun8i 1c30000.ethernet: stmmac_dvr_probe: MDIO bus (id: 0) registration failed Now I can access the Neo2 only via TTL-serial-debug console Lucky me - I have a USB-Ethernet Adapter which I can use: [ 787.473350] MOSCHIP usb-ethernet driver 3-1:1.0 eth0: register 'MOSCHIP usb-ethernet driver' at usb-1c1b000.usb-1, MOSCHIP 7830/7832/7730 usb-NET adapter, 00:12:34:55:56:2b [ 787.473508] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 787.503850] MOSCHIP usb-ethernet driver 3-1:1.0 enx00123455562b: renamed from eth0 so here the armbianmontor -u : root@nanopineo23:~# armbianmonitor -u System diagnosis information will now be uploaded to http://sprunge.us/JQdE PS: The NanoPi NAS with only a "normal" Neo has found his Network after update to 5.37 root@nanopi-neo:~# dmesg|grep -i 1c30000 [ 4.313641] dwmac-sun8i 1c30000.ethernet: PTP uses main clock [ 4.313714] dwmac-sun8i 1c30000.ethernet: No regulator found [ 4.313819] dwmac-sun8i 1c30000.ethernet: Will use internal PHY [ 4.313937] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000) [ 4.314111] dwmac-sun8i 1c30000.ethernet: Chain mode enabled [ 4.314123] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported [ 4.314134] dwmac-sun8i 1c30000.ethernet: Normal descriptors [ 4.314145] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported [ 4.314156] dwmac-sun8i 1c30000.ethernet: COE Type 2 [ 4.314167] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported [ 19.124960] dwmac-sun8i 1c30000.ethernet eth0: device MAC address 16:1c:0c:e4:e5:76 [ 19.128797] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available [ 19.128816] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW [ 22.249109] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx ARMBIAN 5.37.171208 nightly Debian GNU/Linux 9 (stretch) Linux nanopineo23 4.14.4-sunxi64 #11 SMP Thu Dec 7 11:55:12 CET 2017 aarch64 GNU/Linux Neo2_Bootlog_537.txt Link to comment Share on other sites More sharing options...
Igor Posted December 9, 2017 Share Posted December 9, 2017 I guess enabling nightlies was perhaps too fast (I need to test repository management) but at least a problems were found. Since you have a temporal network, roll back to previous nightly version ... and don't update kernel until this is fixed. Link to comment Share on other sites More sharing options...
guidol Posted December 9, 2017 Author Share Posted December 9, 2017 7 minutes ago, Igor said: I guess enabling nightlies was perhaps too fast (I need to test repository management) but at least a problems were found. Since you have a temporal network, roll back to previous nightly version ... and don't update kernel until this is fixed. How to roll back? Re-Install? The kernel can be freezed in armbian-config - right? Link to comment Share on other sites More sharing options...
Igor Posted December 9, 2017 Share Posted December 9, 2017 20 minutes ago, guidol said: How to roll back? Re-Install? Install packages from here: https://beta.armbian.com/pool/main/l/linux-4.13.14-sunxi64/ you can leave headers out if you don't need them. Or via apt-get. Hmm. We could implement this to armbian-config, to make rollback simpler. Yes, freeze in armbian-config or manually. Link to comment Share on other sites More sharing options...
guidol Posted December 9, 2017 Author Share Posted December 9, 2017 2 hours ago, Igor said: Install packages from here: https://beta.armbian.com/pool/main/l/linux-4.13.14-sunxi64/ you can leave headers out if you don't need them. @Igor Thanks for the information! I did: Rollback: mkdir /home/guido/rollback cd /home/guido/rollback wget https://beta.armbian.com/pool/main/l/linux-4.13.14-sunxi64/linux-dtb-next-sunxi64_5.34.171121_arm64.deb wget https://beta.armbian.com/pool/main/l/linux-4.13.14-sunxi64/linux-headers-next-sunxi64_5.34.171121_arm64.deb wget https://beta.armbian.com/pool/main/l/linux-4.13.14-sunxi64/linux-image-next-sunxi64_5.34.171121_arm64.deb dpkg --force-all -i ./linux-dtb-next-sunxi64_5.34.171121_arm64.deb dpkg --force-all -i ./linux-headers-next-sunxi64_5.34.171121_arm64.deb dpkg --force-all -i ./linux-image-next-sunxi64_5.34.171121_arm64.deb reboot armbian-config ==> system ==> freeze after that removed the usb-ethernet (because it was configured as the same IP) and rebootet again. (If I didnt need the headers - which I installed via dpkg.... could I use the armbian-config funtion to deinstall the headers?) Now my Neo2 NAS is accessable via SSH again - but I wonder after downgrading I do get the newer welcome Message out of /etc/armbian-release - which hasnt been downgraded?: Welcome to ARMBIAN 5.37.171208 nightly Debian GNU/Linux 9 (stretch) 4.13.14-sunxi64 I also did see that with the working 5.34 the u-boot doenst show the network: U-Boot 2017.11-armbian (Dec 07 2017 - 12:01:53 +0100) Allwinner Technology CPU: Allwinner H5 (SUN50I) Model: FriendlyARM NanoPi NEO 2 DRAM: 512 MiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: No ethernet found. As attachment you could see that the u-boot of my Orange Pi R1 could see the network card [EDIT because of the Linux-Headers] I did try to use armbian-config for removing/uninstallting the headers - and armbian-config offered it also to uninstall/remove it - but after I selected it it does try to INSTALL something. Then goes one screen back and did now again to remove/uninstall it But with dpkg I also could complete install the headers: root@nanopineo23:/home/guido/rollback# dpkg --purge --force-all linux-headers-next-sunxi64 (Reading database ... 65039 files and directories currently installed.) Removing linux-headers-next-sunxi64 (5.34.171121) ... dpkg: warning: while removing linux-headers-next-sunxi64, directory '/usr/src/linux-headers-4.13.14-sunxi64/scripts/selinux/mdp' not empty so not removed dpkg: warning: while removing linux-headers-next-sunxi64, directory '/usr/src/linux-headers-4.13.14-sunxi64/scripts/selinux/genheaders' not empty so not removed dpkg: warning: while removing linux-headers-next-sunxi64, directory '/usr/src/linux-headers-4.13.14-sunxi64/scripts/mod' not empty so not removed dpkg: warning: while removing linux-headers-next-sunxi64, directory '/usr/src/linux-headers-4.13.14-sunxi64/scripts/kconfig' not empty so not removed dpkg: warning: while removing linux-headers-next-sunxi64, directory '/usr/src/linux-headers-4.13.14-sunxi64/scripts/dtc' not empty so not removed dpkg: warning: while removing linux-headers-next-sunxi64, directory '/usr/src/linux-headers-4.13.14-sunxi64/scripts/basic' not empty so not removed Link to comment Share on other sites More sharing options...
maarten Posted December 10, 2017 Share Posted December 10, 2017 On 9-12-2017 at 7:37 PM, Igor said: Install packages from here: https://beta.armbian.com/pool/main/l/linux-4.13.14-sunxi64/ you can leave headers out if you don't need them. Or via apt-get. Hmm. We could implement this to armbian-config, to make rollback simpler. Yes, freeze in armbian-config or manually. Hi Igor, How does this work? How can we make sure the build process uses these packages? PS: thanks for all your work! EDIT: I've reset the Armbian repo to commit 5f4c4c77b28b4d15fd0165809ccfaed7af5c73e5 (right before the update to 4.14) and created a file named `.ignore_changes`. After that the network worked again even though it's not recognised on boot. Link to comment Share on other sites More sharing options...
Dennboy Posted December 11, 2017 Share Posted December 11, 2017 Looks like nanopi neo plus2 is almost there, great work! I also stumbled on this Ethernet issue with the next kernel, in the Armbian_5.37_Nanopineoplus2_Debian_stretch_next_4.14.5.img I build yesterday with the Armbian build script. I need custom kernel to get some more Industrial I/O features like standalone triggers enabled, so the older 4.13.14 packages are unfortunately not enough. I guess I have to use wifi until there is a fix. If there is anything I can do to help (e.g. testing an initial fix), please let me know. I also noticed some other minor issues in the image, otherwise it seems to be working fine: - kernel headers are not installed in the image (but may not be needed by all) - the /boot/overlay-user folder does not exist - had to run ldconfig a few times to get my libs in /usr/local/lib working Link to comment Share on other sites More sharing options...
