Hi all!
After success image building I have problem at boot [Armbian_5.37_Lime2_Debian_jessie_default_3.4.113]
Boot stoped after line '<6>axp20_ldo2: 1800 <--> 3300 mV at 3000 mV'
PSU and board work fine, what is the problem?
Regards,
boot log
========HV Inital ===================
<3>tkey_fetch_sysconfig_para: tkey_unused.
hv_keypad_init: after fetch_sysconfig_para:  normal_i2c: 0x0. normal_i2c[1]: 0x0
<3>sunxi-rtc sunxi-rtc: Warning: RTC time is wrong!
<6>sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0
<6>i2c /dev entries driver
config i2c gpio with gpio_config api
<6>axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected
<6>axp_mfd 0-0034: AXP internal temperature monitoring enabled
<4>i2c i2c-0: Invalid probe address 0x00
<6>I2C: i2c-0: AW16XX I2C adapter
<4>i2c i2c-1: Invalid probe address 0x00
<6>I2C: i2c-1: AW16XX I2C adapter
<4>i2c i2c-2: Invalid probe address 0x00
<6>I2C: i2c-2: AW16XX I2C adapter
<5>cedar: failed to allocate memory buffer
[tt]----- avs_dev driver load... ----
[tt]-----      register iomem      ----
Cannot reserve region for ccmu
[tt]--- avs_dev driver load ok!! -----
[ace_drv] start!!!
[ace_drv] init end!!!
[pa_drv] start!!!
[pa_drv] init end!!!
<6>axp20_ldo1: 1300 mV
Need to be investigated.
8 minutes ago, alexparser said:
Linux 3.4.x not supported more in Armbian?
If you use the one from the download section, then it's supported. If you build on your own, check/get involved in https://forum.armbian.com/forum/20-development/ Just after the last release we moved up with u-boot and things might be partially broken at the moment.
