I had a NanoPi NEO2 working well with ARMBIAN 5.34.171121.
After apt-get upgrade, ARMBIAN has been changed to ARMBIAN 5.37.171208 with below firmware update:
Get:1 http://beta.armbian.com xenial/main arm64 linux-dtb-next-sunxi64 arm64 5.37.171208 [25.0 kB]
Get:2 http://beta.armbian.com xenial/main arm64 linux-image-next-sunxi64 arm64 5.37.171208 [14.7 MB]
Get:3 http://beta.armbian.com xenial/main arm64 linux-u-boot-nanopineo2-next arm64 5.37.171208 [222 kB]
Get:4 http://beta.armbian.com xenial/main arm64 linux-xenial-root-next-nanopineo2 arm64 5.37.171208 [318 kB]
Then the Ethernet port is no longer working. Kernel message shows MDIO register failure:
root@NEO2-ST0:~# dmesg | grep -i eth
[    0.000000] psci: probing for conduit method from DT.
[    1.661750] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    1.838435] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    1.838566] dwmac-sun8i 1c30000.ethernet: Will use external PHY
[    1.944368] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    1.944381] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    1.944391] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    1.944401] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    1.944412] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    1.944422] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    1.944984] dwmac-sun8i 1c30000.ethernet: Cannot register the MDIO bus
[    1.945003] dwmac-sun8i 1c30000.ethernet: stmmac_dvr_probe: MDIO bus (id: 0) registration failed
Any hack do I need on device tree or driver to make it work again?
BTW: Is there any way to select specific version of ARMBIAN to build? 5.36 for example. Even if I checkout the specific release tag the build scripts will always switch to master and build the latest version.
Thanks & BR,
Xiaohai Li
Yes - as I alreday did - you have to rollback to the old version and wait for the next version where hopefully the bug is fixed.
After the rollback you should freeze the kernel in armbian-config to avoid the ethernet problem while the fix isnt ready.
See my thread for this problem:
PS: The NanoPi Neo2 has a H5-CPU and you did ask in the part for H2/H3-CPUs :)
The normal NanoPi Neo has a H3-CPU
58 minutes ago, Igor said:
Should be fixed after this commit: https://github.com/armbian/build/commit/10816a3c68c5041ce8c2d9f49db0696b9fec83a4. A beta repository has also been updated.
Iam using
ARMBIAN 5.34.171121 nightly Debian GNU/Linux 9 (stretch) 4.13.14-sunx
Linux nanopineo23 4.13.14-sunxi64 #246 SMP Mon Nov 20 01:58:09 CET 2017 aarch64
Is this commit active, that I can unfreeze my kernel in armbian-config and do a apt update & upgrade to get a actual system and the ethernet port would remain useable? ;)
32 minutes ago, Igor said:
Yes, it is.
Thanks - did work :)
ARMBIAN 5.37.171218 nightly Debian GNU/Linux 9 (stretch) 4.14.7-sunxi64
Linux nanopineo23 4.14.7-sunxi64 #38 SMP Mon Dec 18 00:49:34 CET 2017 aarch64 GNU/Linux
u-boot does show (like on the old working kernel): Net:   No ethernet found.
but ethernet does work:
[    8.463845] RTL8211E Gigabit Ethernet 0.2:07: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=0.2:07, irq=POLL)
[   12.544959] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   12.545009] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
That is normal. AFAIK no network support within u-boot for now or not enabled.
Good!
Good!
Really great work!
I could checkout the specific release tag, but the build scripts would always switch to master and build the latest version.
Thanks & BR.
On 12/18/2017 at 11:44 AM, Igor said:
Yes, it is.
Not all boards are created equal: OPi+2E Ubnt Xenial Next nightly -> 5.37.171221 = no ethernet; back to 5.34.171121 = OK.
Igor did the same for the Orange Pi Zero Plus (H5) as for the NanoPi Neo2
- maybe he isnt aware of the problem on the Orange Pi Plus 2E?
fixed.
