I have installed the Armbian 26.2 minimal IOT image based on Debian 13 Trixie - with the 6.18.x kernel - and I noticed the USB2 port (the single, vertical port next to the Ethernet port) is not working. Is this a limitation of the mainstream kernel (6.18.x) - i.e. does this work only with the vendor kernel (6.1.x) ? NB: I upgraded to 6.19 using the 'edge' kernel, but I'm seeing the same behavior.
Here's the armbianmonitor outpur - https://paste.armbian.com/raw/udefojuxuk
Edited by mitu
I encountered the same issue. When I used the Orange Pi 3B image based on the 6.18 kernel, USB was not available, but when using the 6.1 vendor image, USB worked.
@tim zeng sure, but that's not - directly - related, since the Orange PI5 and the Orange Pi3 are different SOCs/SBCs. The only common trait is the poor SW support offered by the vendor.
Edited by mitu
I have also encountered this using Orange pi 5 and latest Armbian updated as of today. That the "standing" USB port does not work also means that the  USB-C port doesn't work -- they are electrically connected.
So  Mitu's question is also mine:  Is this a limitation of the mainstream kernel (6.18.x) - i.e. does this work only with the vendor kernel (6.1.x)?
EDIT: typo
Edited by Alec Leamas
Typo
In mainline kernel 6.18 or above, the USB 2.0 port (and USB-C port) is configured as device mode. You can use following cmd to change to host mode to connect other USB devices, but you need to do it again after reboot.
sudo bash -c "echo host > /sys/kernel/debug/usb/fc000000.usb/mode"
It could be done by dtb overlay but there is no one available now.
  • Solution
The upstream default seems to be "otg" to allow users in userspace to change the usb port behavior.
Try this and use armbian-add-overlay
/dts-v1/;
/plugin/;
	fragment@0 {
		target = <&usb_host0_xhci>;
		__overlay__ {
			dr_mode = "host";
Not really. The USB-C port does work, I actually connected an USB hub to be able to add a keyboard/mouse to the SBC and it worked without issue.
I'll try this , thank you for the instructions. The USB-C port does work though if I connect a hub to it, I'm able to use the devices connected to the HUB without issue.
Edited by mitu
OK, I checked and the USB port is already set to host:
$ sudo cat /sys/kernel/debug/usb/fc000000.usb/mode
host
$ uname -r
7.0.2-edge-rockchip64
The USB-A port is still not functional, but - as said in my previous reply - the USB-C port is working fine.
I verified the overlay above working with diy kernel 7.1.0-rc1 and kernel 6.18.10 from apt repo.
@Werner The overlay solution worked - thank you !
Is armbian-add-overlay a separate package/command ? I managed to enable it by creating a rockchip-rk3588-usb-host.dts file in the /boot//dtb-7.0.5-edge-rockchip64/rockchip/overlay folder, compiling it to ockchip-rk3588-usb-host.dtbo with the device tree compiler (dtc) and then using armbian-config to enable the loading of the usb-host overlay.
That's default Debian behavior. Ubuntu includes sbin in PATH afaik. In any case Armbian does not alter this.
