I just installed Armbian_community_26.2.0-trunk.732_Rockpi-4bplus_trixie_current_6.18.22_minimal on a Rockpi-4bplus.
How do I install the correct Linux headers? The standard apt install linux-headers-$(uname -r) method doesn't work for armbian.
OK, there's a corresponding option in armbian-config, and it seems to run successfully, but for some reason, I only see linux-headers-6.12.74+deb13+1-arm64 and linux-headers-6.12.74+deb13+1-common in /usr/src.
We don't ship headers for each and every trunk image. Way too much data.
Simplest solution is to use the framework to create a complete set of kernel deb packages. Those will include matching headers.
Thanks, @Werner! I believe I can do it once I find clear instructions. There's still a lot I don't understand—where all needed things are. I'd appreciate it if you could just provide a link that could point me in the right direction.
Meanwhile, yesterday I somehow managed to install the headers using apt-get install linux-headers-current-rockchip64 . At least, for now, this allowed me to build the packages that needed the headers.
It seems like this might be a bit of a dirty trick (no?). So, I'd still like to do it right.
Okay so then we have some issues here
This is clearly wrong since these packages come from upstream Debian and cannot/will not work with Armbian kernels. This shall be reported here: https://github.com/armbian/configng/
Then you were lucky some working headers were present :)
https://docs.armbian.com/Developer-Guide_Build-Preparation/
Or in very short:
git clone the repo
./compile.sh BOARD=rockpi-4bplus BRANCH=current kernel
Check output/debs for your packages
Install via dpkg -i on the target board
