Stanislav Chizhik Posted Thursday at 07:56 AM Posted Thursday at 07:56 AM I just installed Armbian_community_26.2.0-trunk.732_Rockpi-4bplus_trixie_current_6.18.22_minimal on a Rockpi-4bplus. How do I install the correct Linux headers? The standard apt install linux-headers-$(uname -r) method doesn't work for armbian. OK, there's a corresponding option in armbian-config, and it seems to run successfully, but for some reason, I only see linux-headers-6.12.74+deb13+1-arm64 and linux-headers-6.12.74+deb13+1-common in /usr/src. 0 Quote
Werner Posted Thursday at 04:22 PM Posted Thursday at 04:22 PM We don't ship headers for each and every trunk image. Way too much data. Simplest solution is to use the framework to create a complete set of kernel deb packages. Those will include matching headers. 0 Quote
Solution Stanislav Chizhik Posted Friday at 02:03 AM Author Solution Posted Friday at 02:03 AM Thanks, @Werner! I believe I can do it once I find clear instructions. There's still a lot I don't understand—where all needed things are. I'd appreciate it if you could just provide a link that could point me in the right direction. Meanwhile, yesterday I somehow managed to install the headers using apt-get install linux-headers-current-rockchip64 . At least, for now, this allowed me to build the packages that needed the headers. It seems like this might be a bit of a dirty trick (no?). So, I'd still like to do it right. 0 Quote
Werner Posted Friday at 03:39 AM Posted Friday at 03:39 AM Okay so then we have some issues here 19 hours ago, Stanislav Chizhik said: armbian-config, and it seems to run successfully, but for some reason, I only see linux-headers-6.12.74+deb13+1-arm64 and linux-headers-6.12.74+deb13+1-common in /usr/src This is clearly wrong since these packages come from upstream Debian and cannot/will not work with Armbian kernels. This shall be reported here: https://github.com/armbian/configng/ 1 hour ago, Stanislav Chizhik said: sing apt-get install linux-headers-current-rockchip64 Then you were lucky some working headers were present 1 hour ago, Stanislav Chizhik said: a link that could point me in the right direction https://docs.armbian.com/Developer-Guide_Build-Preparation/ Or in very short: git clone the repo ./compile.sh BOARD=rockpi-4bplus BRANCH=current kernel Check output/debs for your packages Install via dpkg -i on the target board 1 Quote
Igor Posted 3 hours ago Posted 3 hours ago Community images are tied to daily beta repo where it should always be a match kernel - headers. Just make sure you have a clean updated system then proceeding to header installation via armbian-config. And only if this doesn't work, report so we can look into. 0 Quote
