Darks1derCZ Posted 1 hour ago Posted 1 hour ago Good Morning, I am running into an issue when trying to compile an image for a SM8250 device. Most of the process is working fine until it gets to the Grub Section, at which point I get the following error: " cp: cannot stat '/usr/lib/linux-image-6.18.24-current-sm8250/qcom/sm8250-retroidpocket-rp5.dtb': No such file or directory" I have attached the logs, and would love to know if anyone has had a similar issue when trying to build an image for any device, and if so what you have done to solve it. Thanks all in advance for the support 0 Quote
Werner Posted 1 hour ago Posted 1 hour ago Confirmed. From first glance it looks like dts files are missing. 0 Quote
Darks1derCZ Posted 31 minutes ago Author Posted 31 minutes ago Ohhh thank you so much, I spent so much time trying to find the solution 0 Quote
