Darks1derCZ Posted 4 hours ago Posted 4 hours ago Good Morning, I am running into an issue when trying to compile an image for a SM8250 device. Most of the process is working fine until it gets to the Grub Section, at which point I get the following error: " cp: cannot stat '/usr/lib/linux-image-6.18.24-current-sm8250/qcom/sm8250-retroidpocket-rp5.dtb': No such file or directory" I have attached the logs, and would love to know if anyone has had a similar issue when trying to build an image for any device, and if so what you have done to solve it. Thanks all in advance for the support 0 Quote
Darks1derCZ Posted 4 hours ago Author Posted 4 hours ago https://paste.armbian.com/rapohapofe 0 Quote
Werner Posted 3 hours ago Posted 3 hours ago Confirmed. From first glance it looks like dts files are missing. 0 Quote
Darks1derCZ Posted 2 hours ago Author Posted 2 hours ago Ohhh thank you so much, I spent so much time trying to find the solution 0 Quote
Darks1derCZ Posted 2 hours ago Author Posted 2 hours ago So I can confirm that this solved the compiling issues, Thank you very much @Werner Now I am facing another issue with EFI when trying to boot. Will try to see if I can identify the problem and solve it. 0 Quote
