BTT Pi - ethernet not working after upgrade from 6.12.68 to 6.18.33
Go to solution Solved by JohnTheCoolingFan,
Hi everyone,
I downloaded a 6.12.68 image for my Bigtreetech Pi, compatible with CB1-sd.
After apt update and apt upgrade, onboard ethernet disappears.
During update got these messages:
- Err: 16 http://deb.debian.org/debian trixie-backports/main arm64 Packages.diff/Index      Could't find the start of the patch series
- Notice: Repository 'http... InRelease' changed its 'Version' value from '13.3' to '13.5'
Launching a new apt update, error and notice disappear.
After upgrade and reboot there is no more ethernet device, just wifi.
Investigating a little I found the kernel module sunxi_gmac.ko that was present in folder /usr/lib/modules/... current... /kernel/net/ethernet/allwinner before upgrade, is now missing after upgrade. There is just a sun4i-emac.ko after upgrade.
Plugging in an usb to ethernet adapter (Realtek r8152) works immediately, get eth0 and connect.
Can someone help to restore onboard ethernet?
Thanks, Mario
  • Solution
There's been a few changes to make etehrnet work on H6 that broek it for H616/H618 seemingly. Your best course of action for now would be to downgrade to 6.12 and lock the `linux-*` from being upgraded.
Also a small display with ST7796 and ADS7846 on shared SPI stopped working.
Downgraded to 6.12 and all works.
When you solve it, if you remember, give me a shout.
Thanks
I ran into this as well.  Downgrade to kernel 6.12.58 fixed the physical interface.
My board that initially had Trixie required the NetworkManager fix to get wifi working even after reverting. Something about the upgrade and/or downgrade broke netplan.
It should be / it was reported fixed a week ago, but you need to make image on your own or use nightly automated builds.
Quote
mattjm
i got the same problem my ethernet is gone.
how does one downgrade i cant figurer it out at all
