apollon77 Posted January 15, 2016 Posted January 15, 2016 Hi, as I had set up my CubieTruck I decided to go with Legacy Wheezy ... Now I think about become a bit more current :-) Option 1 is to Upgrade to Legacy Jessie ... This is described in the documentation and hopefully should work that way, Correkt? Or Option 2 would be to go to Vanilla Jessie. Is this possible too? How? Thank you for your support, Ingo
Igor Posted January 15, 2016 Posted January 15, 2016 Possible if you are using SD boot, not possible if you use NAND. You need to install at least: uboot , kernel and dtb files http://www.armbian.com/kernel/
apollon77 Posted January 15, 2016 Author Posted January 15, 2016 After problems with NAND earlier I changed to /boot on SD-card and root on SATA ... have to check this (should be possible while checking where /boot ist, or ?!) :-) So I assume I need to upgrade to Legacy Jessie first and then change to vanilla kernel by installing uboot , kernel and dtb files? Or change kernel first whicl still on wheezy and upgrade then to Jessie ... correct?
Igor Posted January 15, 2016 Posted January 15, 2016 Both ways should work. If you are changing and tweaking things around double check if kernel installation was done properly after you done that.
apollon77 Posted January 15, 2016 Author Posted January 15, 2016 How should I do this?! Normally I simply use it :-) I'm not the linux freak :-)
disconnect Posted January 20, 2016 Posted January 20, 2016 I'd like to know too. I want to upgrade legacy trusty to vanilla kernel, i'm using SD card. (and if this works, a distro upgrade too)
Igor Posted January 20, 2016 Posted January 20, 2016 https://github.com/igorpecovnik/lib/blob/master/documentation/user-faq.md#how-to-upgrade-kernel Development version is about to be added ASAP.
