manuti Posted January 23, 2018 Posted January 23, 2018 There is a recent Etcher.io bug in Linux https://github.com/resin-io/etcher/issues/1955 causing errors writing images. While we're hoping to release Etcher 1.3.1 soon, but as a temporary workaround you can do to manually downgrade to 1.2.1 : sudo apt-get remove etcher-electron sudo apt-get update sudo apt-get install etcher-electron
Moklev Posted January 29, 2018 Posted January 29, 2018 1.3.1 https://forums.resin.io/t/etcher-v1-3-1-release/2446
manuti Posted January 29, 2018 Author Posted January 29, 2018 Yes, I know I think the 1.3.0 bricked two of my cards and that's supossed can't happens but for sure I have now two Read Only microSD card and i try every single method on every single platform ... and nothing. Bricked.
Moklev Posted January 30, 2018 Posted January 30, 2018 Try to remove all partitions with gparted (or gnome disk utility). Make a new one and format it.
manuti Posted January 30, 2018 Author Posted January 30, 2018 gparted, gnome disk utility, dd with dev zeo, dd with dev random, diskpart from windows, sd formatter from windows, disk utility from MacOS, try to format with an Android movile, ... NOTHING WORKS!!!
manuti Posted February 15, 2018 Author Posted February 15, 2018 I think Resin.io has spawned a monster https://github.com/resin-io/etcher/issues/2053 They are breaking many SD cards, maybe is time to recommend other tools to flash armbian.
Xalius Posted February 15, 2018 Posted February 15, 2018 That sounds a bit like just the card died to me, I never managed to break any sdcard from the software/bus side so far... eMMC are a different matter if you write to the boot/firmware partitions... do you have steps to reproduce?
manuti Posted February 15, 2018 Author Posted February 15, 2018 I'm not talking about eMMC is about "bricking" microSD and SD cards ... but this is supposed to be impossible !!!
TonyMac32 Posted February 19, 2018 Posted February 19, 2018 I put this on the bug, but did you try https://www.sdcard.org/downloads/formatter_4/
manuti Posted February 19, 2018 Author Posted February 19, 2018 On 2/19/2018 at 6:05 AM, TonyMac32 said: but did you try Expand Yes. SD formatter 4 and 3, and under Win10 and MacOS. My cards are now in the Resin.io house, I hope this mystery can be resolved.
Tido Posted February 19, 2018 Posted February 19, 2018 Change is not always improvement. etcher.io v 1.2.1 burns fine. 1
