I am currently trying to upgrade my kernel from 3.4 to 4.14 and it is working quite well for my needs.
But i have a problem i have not found a solution for, i can not set the PE00-11 pins as gpios. Acutally i cant set or configure them at all.
I am using the /sys/class... export and writing via echo direction and value. For all other GPIOs it works perfectly fine exept for those 12 (and the IR0-pins PB3 and PB4, those are also not accessible).
I tried really a lot already: stripping down the kernel to only the most essential modules, deactivating almost everything in the dts file, using different images... but in essence, as soon as i change from 3.4 to mainline, the PE-pins stop working.
Has anyone any clue how i can dig deeper into this or maybe even a solution?
Edited by lime-fan
Thanks for this suggestion, but that is what i am already doing:
for i in {128..139} ; do echo $i > /sys/class/gpio/export ; done
for i in /sys/class/gpio/gpio* ; do echo "out" > $direction ; done
for i in /sys/class/gpio/gpio* ; do echo 1 > value ; done
if i do this with e.g. 256-277 (PI0-PI21) or 96-123 (PD0-27) or any other pin (exect for PB3 and PB4) this works perfectly fine.
If i access the gpios via /dev/mem directly it also does not work (as it does with kernel 3.4).
My guess is that this is somehow kernel related because i cound also not use the PG0-PG5-pins until i removed the emmc-support from the kernel.
The PE-pins can also be used for CSI but there is no CSI driver for mainline yet. Could this be the reason why those pins cannot be used as gpio?
Can i somehow see the memory areas the kernel is reserving or which are blocked by drivers or something?
Maybe i got one step further, i dont know :)
At least i now know that the wrong dtb file is loaded. I configured "lime2" (without emmc) but the "lime2-emmc" dtb file is used at bootup.
Who decides which dtb is used? Is it u-boot or already the kernel?
@Tido Thanks for your input, i read all through your links and checked that code.
I think my problem is one level deeper as even the direct access to /dev/mem does not work. Seems like something locks the gpios so that gpio_export() function does not work. Maybe i have to try to use gpiod_export() which could override that locks...
Has anyone a lime2 with mainline kernel 4.X and working PE-pins?
After a lot of searching and debugging i found the reason for this. LDO3 (the CSI0-LDO) is not switched on. Then the PE Register does not get power and the PE pins are not usable.
Now i am looking for a way to switch that LDO on. Do i have to do this in the dts files or somewhere else? I know that i can do this using I2C but i think a solution for all A20 users would be better...
Thats why LDO3 is switched off (lime2 crash at boot or when LDO3 is activated):
http://lists.infradead.org/pipermail/linux-arm-kernel/2016-March/417786.html
And there are some patches implementing a solution for this (slow rampup of LDO3 voltage):
https://lists.denx.de/pipermail/u-boot/2017-March/282789.html
I adapted these patches to work with the current armbian build, i will post them later.
PE pins are working now! :)
