Saturday at 08:36 PM1 day Hi all First of all big thank you to everyone who worked on adding nvidia Jetson nano back to list of supported boards. I was able to do upgrade to Ubuntu 24.04 by myself but still on old kernel. Now, after recent changes to Armbian - the little board received new live!! Thanks! Kuba Hint: Somehow my LG monitor required extra grub config before DisplayPort & HDMI ports started to work properly (frequency was an issue). If anyone faced similar problems - here is what worked for me. GRUB_CMDLINE_LINUX="video=DP-1:2560x1440@60 video=HDMI-A-1:1920x1080@60e" Edited Saturday at 08:50 PM1 day by Kuba
12 hours ago12 hr 23 hours ago, Kuba said:First of all big thank you to everyone who worked on adding nvidia Jetson nano back to list of supported boards.Thank you! It took few days and now almost everything works. If you can provide more data, I can try to fix problem you have.test without the video= options.Post armbianmonitor -u.Post the output of dmesg | grep -iE 'drm|tegra|sor|dpaux|hdmi'.Post the EDID for each port: cat /sys/class/drm/card*-DP-1/edid | edid-decode and the same with HDMI-A-1.
