Today I installed the armbian build "system" as suggested by @Igor in some threads (VirtualBox with Ubuntu 16.04 64Bit and a GitHub clone).
After generating a armbian 5.38 (with old kernel, bad WiFi and USB unuseable for WiFi or Ethernet) for my OPi i96
I did see that also a entry is for the BananaPi M2 Ultra.
I got the little brother - the BPi M2 Berry - so I created also a image for an sd-card :)
At the fist try I did no connect to the board (I know video driver isnt there).
Ethernet isnt recognized (no DHCP and no device).
The first connect I did get with a USB-WLAN Dongle (RTL8192CUS from edimax) while using a USB-TTL-serial.
After that I did see problems with the AP6112 Wifi Module brcmfmac in the dmesg which I didnt see when the RTL8192CU(S) was connected.
I installed the armbian-firmware-full  (5.35) over the armbian-firmware (5.38) and rebooted - and now the brcmfmac does work :)
[EDIT] BUT not stable :(
While using brcmfmac I do get many ebrcmfmac error in the dmesg.
WhenI dont use it - when using a RTL8192cu(s) - I dont get neither brcmfmac nor cfg80211 errors in the dmesg.
I think - maybe - the drivers to work on every 2nd boot?
Sometimes they work at boot-time and at the next boot the complete wifi is down (AP6212 and RTL8192CU(s))
I'll try to use it while remove the modules for brmc* in /etc/rc.local :
rmmod brcmfmac
rmmod brcmutil
[EDIT] now blacklisted in /etc/modprobe.d/blacklist.conf:
blacklist brcmfmac
blacklist brcmutil
[   40.569474] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[   40.569488] brcmfmac: brcmf_run_escan: error (-110)
[   40.569497] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[   73.609473] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[   73.609487] brcmfmac: brcmf_do_escan: error (-110)
[   73.609493] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[  116.569468] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[  116.569483] brcmfmac: brcmf_do_escan: error (-110)
[  116.569489] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
login as: root
root@192.168.6.120's password:
 ____  ____  _ __  __ ____  ____
| __ )|  _ \(_)  \/  |___ \| __ )  ___ _ __ _ __ _   _
|  _ \| |_) | | |\/| | __) |  _ \ / _ \ '__| '__| | | |
| |_) |  __/| | |  | |/ __/| |_) |  __/ |  | |  | |_| |
|____/|_|   |_|_|  |_|_____|____/ \___|_|  |_|   \__, |
                                                 |___/
Welcome to ARMBIAN 5.38 user-built Debian GNU/Linux 9 (stretch) 4.14.15-sunxi
System load:   0.02 0.05 0.01   Up time:       3 min
Memory usage:  5 % of 1000MB    IP:            192.168.6.120
Usage of /:    5% of 29G
root@bpi-m2-berry:~# lsmod
aes_arm_bs             20480  0
crypto_simd            16384  1 aes_arm_bs
cryptd                 20480  1 crypto_simd
ccm                    20480  3
rtl8192cu              65536  0
rtl_usb                20480  1 rtl8192cu
rtl8192c_common        32768  1 rtl8192cu
brcmfmac              159744  0
rtlwifi                53248  3 rtl_usb,rtl8192c_common,rtl8192cu
mac80211              446464  3 rtl_usb,rtlwifi,rtl8192cu
brcmutil               16384  1 brcmfmac
cfg80211              376832  3 mac80211,rtlwifi,brcmfmac
rfkill                 20480  5 cfg80211
evdev                  20480  1
uio_pdrv_genirq        16384  0
uio                    16384  1 uio_pdrv_genirq
ip_tables              20480  0
x_tables               20480  1 ip_tables
pwrseq_simple          16384  1
root@bpi-m2-berry:~# armbianmonitor -u
System diagnosis information will now be uploaded to http://ix.io/EMz
PS: Board-Name is edited, because I didnt got a M2 Ultra :)
Great job that you tried to do this. :D As you can see there are still a lot of obvious problems and mainline is not yet useful on this board. Not even for simple cases since its lack of network support. Wens made progress on this, so you can try even more complex job by adding few of those patches to userpatches/kernel/sunxi-next and recompile the kernel. Monitor debug/patching, adjust patches if necessary ... Patch is downloaded from Github by adding .patch to the commit URL, for example:
https://github.com/wens/linux/commit/48f1bef6c0b43defca07edd4d6e1962f272fe9d6.patch
Have fun!
