Hey Guys,
following this very closely for a couple of days now, and I want to starting putting my two cents in the bucket. I work with the (Olimex) A13-SOM and got some working images. All quiet hacky so I would love to add the configuration to the installer script to get some clean build images.
Where to start? What info do I need?
I want to do both legacy kernel(I use LCD output) and vanilla kernel.
Booli
How can I participate in the new "master" branch build? I see a lot of work is being done in that field but the original installer guide seems to work of branch "Second".
just cloned the .git normally and switched to master did the trick.
Any irc channel where people hang out?
@Zador
I made a "master" default now.
@Booli
Documenatation is not properly updated yet so I can't point you there :(
start here:
https://github.com/igorpecovnik/lib/blob/master/configuration.sh
We have a kernel family that is not present (sun5i) so you need to check the exception part in the bottom and you need sun5i kernel config for legacy kernel. The rest is just like other board.
Then there is this file (which is about to be reworked)
https://github.com/igorpecovnik/lib/blob/master/boards.sh
regarding some special board definitions and boot scripts.
IRC, IgorPec@Freenode
@Booli
You should probably start with writing config file for mainline u-boot. This SoC is supported by current u-boot, but there is no config file for this specific board (use one of existing A13 config files as an example).
Then you can try writing dts file for mainline kernel, again, using existing sun5i files as an example.
Thanks @zador! and ofc Igor for all his work.
I got a working 3.4 kernel image build with this tree:
https://github.com/Booli/lib/tree/a13-olinux-som-512
Including my LCD 7" 800x480 24depth color.
still tweaking, also I don't have any non LCD connection to it, so don't know if I can test vanilla kernel. (My serial UART0 is only outputting crap on 115200 atm(on OSX))
More tweaking coming up.
Are you sure it is UART0? On A13 SOM UART0 pins are shared with microSD pins, so if you somehow connected to UART0 (old board revision?), no wonder you are getting garbage.
UART1 should be the way to go, so it needs to be configured both in u-boot and in kernel.
Hey,
yeah I meant UART1, the one available on the SOM.
I had not grounded the USB-serial connecter I botched together, hence the garbage. Now it is working :) or well it is outputting the debug log, how do I change t hat to make it a terminal?
Would be awesome to also be able to create a vanilla kernel.
Hi there,
first of all I would like to thank you both of your guys for your effort on making this work on the A13-som. I was very pleased to here that this board is supported now as well.
I was trying to get a readily avaiable image from the downloads section but there isn't any avaiable so I tried to use the build tools and stumbled into the following problem.
What I did:
Use the Ubuntu 14.04 miniimage and fetch the toolchain. I compiled using
./compile.sh BRANCH=default BOARD=olinux-som-a13 BUILD_DESKTOP="no" EXTERNAL="yes" FORCE_CHECKOUT="yes" BUILD_ALL="no" KERNEL_ONLY=no PROGRESS_DISPLAY=plain RELEASE=jessie
As far as I could see no errors so I used dd to put this on an sd and run it. The board started successfully to prompt did some preparation jobs as I expected and rebooted again to login prompt.
U-Boot SPL 2016.01-armbian (Feb 20 2016 - 16:31:27)
DRAM: 512 MiB
Failed to set core voltage! Can't set CPU frequency
Trying to boot from MMC
U-Boot 2016.01-armbian (Feb 20 2016 - 16:31:27 +0100) Allwinner Technology
CPU: Allwinner A13 (SUN5I)
I2C: ready
DRAM: 512 MiB
MMC: SUNXI SD/MMC: 0
Setting up a 1024x768 vga console (overscan 0x0)
In: serial
Out: vga
Err: vga
Net: No ethernet found.
starting USB...
USB0: USB EHCI 1.00
USB1: USB OHCI 1.0
scanning bus 0 for devices... 2 USB Device(s) found
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2070 bytes read in 323 ms (5.9 KiB/s)
** File not found /boot/.next **
** File not found .next **
29804 bytes read in 741 ms (39.1 KiB/s)
4089160 bytes read in 680 ms (5.7 MiB/s)
Kernel image @ 0x48000000 [ 0x000000 - 0x3e6548 ]
Starting kernel ...
<6>Booting Linux on physical CPU 0
<6>Initializing cgroup subsys cpuset
<5>Linux version 3.4.110-sun5i (root@ubuntu) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #1 PREEMPT Sat Feb 20 16:44:33 CET 2016
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: sun5i
<6>Memory Reserved:
<6> SYS : 0x43000000 - 0x4300ffff ( 64 kB)
<6> LCD : 0x50000000 - 0x50ffffff ( 16 MB)
<6>cma: CMA: reserved 192 MiB at 43c00000
Memory policy: ECC disabled, Data cache writeback
<6>sunxi: Allwinner A13 revision B (AW1625/sun5i) detected.
<7>On node 0 totalpages: 131072
<7>free_area_init_node: node 0, pgdat c07b4c30, node_mem_map d1000000
<7> DMA zone: 512 pages used for memmap
<7> DMA zone: 0 pages reserved
<7> DMA zone: 65024 pages, LIFO batch:15
<7> Normal zone: 512 pages used for memmap
<7> Normal zone: 65024 pages, LIFO batch:15
<7>pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
<7>pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
<5>Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup-enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 panic=10 consoleblank=0 enforcing=0 loglevel=1
<6>PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>Memory: 512MB = 512MB total
<5>Memory: 297676k/297676k available, 226612k reserved, 0K highmem
<5>Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc072c5c8 (7314 kB)
.init : 0xc072d000 - 0xc0758000 ( 172 kB)
.data : 0xc0758000 - 0xc07bcc60 ( 404 kB)
.bss : 0xc07bcc84 - 0xc086c800 ( 703 kB)
<6>SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
<6>NR_IRQS:128
<6>sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
<6>Console: colour dummy device 80x30
<6>console [tty1] enabled
<6>Calibrating delay loop... 383.38 BogoMIPS (lpj=1916928)
<6>pid_max: default: 32768 minimum: 301
<6>Mount-cache hash table entries: 512
<6>Initializing cgroup subsys cpuacct
<6>Initializing cgroup subsys devices
<6>Initializing cgroup subsys freezer
<6>Initializing cgroup subsys blkio
<6>CPU: Testing write buffer coherency: ok
<6>hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
<6>Setting up static identity map for 0x404f46f0 - 0x404f4748
<6>devtmpfs: initialized
<6>dummy:
<6>NET: Registered protocol family 16
<6>DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>hw-breakpoint: debug architecture 0x4 unsupported.
<6>Init eGon pin module V2.0
SOFTWINNER DMA Driver, © 2003-2004,2006 Simtec Electronics
<6>Initialize DMAC OK
<6>bio: create slab at 0
<5>SCSI subsystem initialized
<6>usbcore: registered new interface driver usbfs
<6>usbcore: registered new interface driver hub
<6>usbcore: registered new device driver usb
<6>Advanced Linux Sound Architecture Driver Version 1.0.25.
<6>cfg80211: Calling CRDA to update world regulatory domain
<6>Switching to clocksource aw_64bits_counter
<5>FS-Cache: Loaded
<6>CacheFiles: Loaded
[usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG
[sw_hcd0]: usb host driver initialize........
[sw_hcd0]: open_usb_clock
[sw_hcd0]: host_init_state = 1
[sw_hcd0]: platform is usb host
[sw_hcd0]: sw_hcd_host0: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx (X), HB-ISO Tx (X), SoftConn)
[sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IRQ 38
<6>sw_hcd_host0 sw_hcd_host0: sw_hcd host driver
<6>sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1
<6>hub 1-0:1.0: USB hub found
<6>hub 1-0:1.0: 1 port detected
is_on = 1, hcd0_set_vbus_cnt = 1
[sw_hcd_host0]: Set USB Power On
[sw_udc]: udc_init: version 20080411
<6>NET: Registered protocol family 2
<6>IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
<6>TCP established hash table entries: 16384 (order: 5, 131072 bytes)
<6>TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
<6>TCP: Hash tables configured (established 16384 bind 16384)
<6>TCP: reno registered
<6>UDP hash table entries: 256 (order: 0, 4096 bytes)
<6>UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
<6>RPC: Registered named UNIX socket transport module.
<6>RPC: Registered udp transport module.
<6>RPC: Registered tcp transport module.
<6>RPC: Registered tcp NFSv4.1 backchannel transport module.
<6>audit: initializing netlink socket (disabled)
<5>type=2000 audit(0.379:1): initialized
<5>VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
<6>NTFS driver 2.1.30 [Flags: R/W].
<6>fuse init (API version 7.18)
<6>msgmni has been set to 965
<6>alg: No test for stdrng (krng)
<6>Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
<6>io scheduler noop registered
<6>io scheduler deadline registered
<6>io scheduler cfq registered (default)
<6>sunxi disp driver loaded (/dev/disp api 1.0)
<6>Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
<6>[uart]: used uart info.: 0x0a
<6>[uart]: serial probe 1 irq 2 mapbase 0x01c28400
<6>sunxi-uart.1: ttyS0 at MMIO 0x1c28400 (irq = 2) is a U6_16550A
<6>[uart]: serial probe 3 irq 4 mapbase 0x01c28c00
<6>sunxi-uart.3: ttyS1 at MMIO 0x1c28c00 (irq = 4) is a U6_16550A
<6>brd: module loaded
<6>loop: module loaded
<6>'Low Performance USB Block' driver is deprecated. Please switch to usb-storage
<6>usbcore: registered new interface driver ub
[NAND] nand driver version: 0x2 0x9
<4>Dev Sunxi softw311 nand: part 1, start 32768, size 32768
<4>Dev Sunxi softw311 nand: part 2, start 65536, size 32768
<4>Dev Sunxi softw311 nand: part 3, start 98304, size 65536
<4>Dev Sunxi softw311 nand: part 4, start 163840, size 1048576
<4>Dev Sunxi softw311 nand: part 5, start 1212416, size 1048576
<4>Dev Sunxi softw311 nand: part 6, start 2260992, size 32768
<4>Dev Sunxi softw311 nand: part 7, start 2293760, size 65536
<4>Dev Sunxi softw311 nand: part 8, start 2359296, size 655360
<4>Dev Sunxi softw311 nand: part 9, start 3014656, size 524288
<4>Dev Sunxi softw311 nand: part 10, start 3538944, size 4243456
<6> nand: nanda nandb nandc nandd nande nandf nandg nandh nandi nandj
[NAND]nand driver, ok.
[spi]: sw spi init !!
[spi]: sw spi init fetch spi0 uning configuration failed
[spi]: Found 1 spi devices in config files
[spi]: boards num modalias max_spd_hz bus_num cs mode
[spi]: spi_board0 irq gpio not used
[spi]: 0 spidev 1000000 2 0 0x3
<4>spi: cannot find any using configuration for all 4 spi controllers, return directly!
<6>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
<6>ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[sw-ehci1]: open clock
[sw-ehci1]: Set USB Power ON
<6>sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
<6>sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2
<6>sw-ehci sw-ehci.1: irq 39, io mem 0x01c14000
<6>sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00
ehci_irq: port change detect
<6>hub 2-0:1.0: USB hub found
<6>hub 2-0:1.0: 1 port detected
[sw-ohci1]: open clock
<6>sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
<6>sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3
<6>sw-ohci sw-ohci.1: irq 40, io mem 0x01c14400
<6>hub 3-0:1.0: USB hub found
<6>hub 3-0:1.0: 1 port detected
<6>Initializing USB Mass Storage driver...
<6>usbcore: registered new interface driver usb-storage
<6>USB Mass Storage support registered.
<6>usbcore: registered new interface driver ums-alauda
<6>usbcore: registered new interface driver ums-cypress
<6>usbcore: registered new interface driver ums-datafab
<6>usbcore: registered new interface driver ums_eneub6250
<6>usbcore: registered new interface driver ums-freecom
<6>usbcore: registered new interface driver ums-isd200
<6>usbcore: registered new interface driver ums-jumpshot
<6>usbcore: registered new interface driver ums-karma
<6>usbcore: registered new interface driver ums-onetouch
<6>usbcore: registered new interface driver ums-realtek
<6>usbcore: registered new interface driver ums-sddr09
<6>usbcore: registered new interface driver ums-sddr55
<6>usbcore: registered new interface driver ums-usbat
------print_msc_config-----
vendor_id = 0x18d1
mass_storage_id = 0x1
adb_id = 0x2
usb_manufacturer_name = USB Developer
usb_product_name = Android
usb_serial_number = 20080411
msc_vendor_name = USB 2.0
msc_product_name = USB Flash Driver
msc_release = 100
luns = 3
<6>mousedev: PS/2 mouse device common for all mice
========RTC Inital ===================
<3>rtc_fetch_sysconfig_para: rtc_unused.
rtc_fetch_sysconfig_para:ok
pcf8563_init: after fetch_sysconfig_para: normal_i2c: 0x0. normal_i2c[1]: 0x0
<6>i2c /dev entries driver
config i2c gpio with gpio_config api
<4>i2c i2c-0: Invalid probe address 0x00
<6>I2C: i2c-0: AW16XX I2C adapter
<4>i2c i2c-1: Invalid probe address 0x00
<6>I2C: i2c-1: AW16XX I2C adapter
<4>i2c i2c-2: Invalid probe address 0x00
<6>I2C: i2c-2: AW16XX I2C adapter
<6>lirc_dev: IR Remote Control driver registered, major 251
<6>IR NEC protocol handler initialized
<6>IR RC5(x) protocol handler initialized
<6>IR RC6 protocol handler initialized
<6>IR JVC protocol handler initialized
<6>IR Sony protocol handler initialized
<6>IR RC5 (streamzap) protocol handler initialized
<6>IR SANYO protocol handler initialized
<6>IR MCE Keyboard/mouse protocol handler initialized
<6>IR LIRC bridge handler initialized
[pa_drv] start!!!
<6>usb 2-1: new high-speed USB device number 2 using sw-ehci
[pa_drv] init end!!!
<6>md: linear personality registered for level -1
<6>md: multipath personality registered for level -4
<6>md: faulty personality registered for level -5
<6>device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
<6>device-mapper: multipath: version 1.3.2 loaded
<6>device-mapper: multipath round-robin: version 1.0.0 loaded
<6>device-mapper: multipath queue-length: version 0.1.0 loaded
<6>device-mapper: multipath service-time: version 0.2.0 loaded
<6>[mmc-msg] sw_mci_init
<6>[mmc-msg] MMC host used card: 0x1, boot card: 0x1, io_card 0
<6>[mmc-msg] sdc0 set round clock 400000, src 24000000
<6>[mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<6>[mmc-msg] sdc0 Probe: base:0xf1c0f000 irq:32 sg_cpu:c3c44000(43c44000) ret 0.
<6>[mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<6>[mmc-msg] sdc0 power on
[ccmu] set sdc0 reset status to 0 failed!
<3>[mmc-err] Failed to release sdc0 reset
[mmc_pm]: no sdio card used in configuration
<6>sunxi_leds driver init
<7>Registered led device: green:pg09:led1
<6>usbcore: registered new interface driver usbhid
<6>usbhid: USB HID core driver
<6>IPv4 over IPv4 tunneling driver
<6>TCP: cubic registered
<6>Initializing XFRM netlink socket
<6>NET: Registered protocol family 17
<6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<6>NET: Registered protocol family 15
<6>8021q: 802.1Q VLAN Support v1.8
<6>VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
<5>Registering SWP/SWPB emulation handler
<6>registered taskstats version 1
<4>------------[ cut here ]------------
<4>WARNING: at drivers/power/axp_power/axp20-gpio.c:36 axp_gpio_set_io+0x170/0x188()
Modules linked in:
[] (unwind_backtrace+0x0/0x134) from [] (warn_slowpath_common+0x54/0x64)
[] (warn_slowpath_common+0x54/0x64) from [] (warn_slowpath_null+0x1c/0x24)
[] (warn_slowpath_null+0x1c/0x24) from [] (axp_gpio_set_io+0x170/0x188)
[] (axp_gpio_set_io+0x170/0x188) from [] (OSAL_GPIO_Request+0x68/0xbc)
[] (OSAL_GPIO_Request+0x68/0xbc) from [] (BSP_disp_close_lcd_backlight+0x11c/0x1e8)
[] (BSP_disp_close_lcd_backlight+0x11c/0x1e8) from [] (BSP_disp_init+0x13c/0x1cc)
[] (BSP_disp_init+0x13c/0x1cc) from [] (DRV_DISP_Init+0xe4/0xf8)
[] (DRV_DISP_Init+0xe4/0xf8) from [] (Fb_Init+0x2e4/0xe78)
[] (Fb_Init+0x2e4/0xe78) from [] (lcd_module_init+0x110/0x11c)
[] (lcd_module_init+0x110/0x11c) from [] (do_one_initcall+0x11c/0x174)
<3>[mmc-err] smc 0 err, cmd 52, RTO
[] (do_one_initcall+0x11c/0x174) from [] (kernel_init+0x194/0x22c)
[] (kernel_init+0x194/0x22c) from [] (kernel_thread_exit+0x0/0x8)
<4>---[ end trace 01f1b2e1d7760586 ]---
<4>WARNING: at drivers/power/axp_power/axp20-gpio.c:73 axp_gpio_get_io+0x104/0x12c()
Modules linked in:
<3>[mmc-err] smc 0 err, cmd 5, RTO
[] (warn_slowpath_null+0x1c/0x24) from [] (axp_gpio_get_io+0x104/0x12c)
[] (axp_gpio_get_io+0x104/0x12c) from [] (axp_gpio_set_value+0x18/0x1a0)
[] (axp_gpio_set_value+0x18/0x1a0) from [] (OSAL_GPIO_Request+0x74/0xbc)
[] (OSAL_GPIO_Request+0x74/0xbc) from [] (BSP_disp_close_lcd_backlight+0x11c/0x1e8)
<4>---[ end trace 01f1b2e1d7760587 ]---
<6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
<6>[mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
<6>[mmc-msg] sdc0 set round clock 42857142, src 300000000
<6>[mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
<6>mmc0: new high speed SDHC card at address 59b4
<6>mmcblk0: mmc0:59b4 NCard 14.7 GiB
<6> mmcblk0: p1
<6>Console: switching to colour frame buffer device 100x30
<3>drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
<6>ALSA device list:
<6> #0: sunxi-CODEC Audio Codec
<6>md: Waiting for all devices to be available before autodetect
<6>md: If you don't use raid, use raid=noautodetect
<6>md: Autodetecting RAID arrays.
<6>md: Scanned 0 and added 0 devices.
<6>md: autorun ...
<6>md: ... autorun DONE.
<6>EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
<6>VFS: Mounted root (ext4 filesystem) on device 179:1.
<6>devtmpfs: mounted
<6>Freeing init memory: 172K
<30>systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
<30>systemd[1]: Detected architecture 'arm'.
<27>systemd[1]: Failed to insert module 'autofs4'
<27>systemd[1]: Failed to insert module 'ipv6'
<30>systemd[1]: Set hostname to .
<28>systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
<30>systemd[1]: Expecting device dev-ttyS0.device...
<30>systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
<30>systemd[1]: Started Forward Password Requests to Wall Directory Watch.
<30>systemd[1]: Starting Remote File Systems (Pre).
<30>systemd[1]: Reached target Remote File Systems (Pre).
<30>systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
<30>systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
<30>systemd[1]: Starting Paths.
<30>systemd[1]: Reached target Paths.
<30>systemd[1]: Starting Encrypted Volumes.
<30>systemd[1]: Reached target Encrypted Volumes.
<30>systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
<27>systemd[1]: Failed to open /dev/autofs: No such file or directory
<27>systemd[1]: Failed to initialize automounter: No such file or directory
<27>systemd[1]: Failed to set up automount Arbitrary Executable File Formats File System Automount Point.
<29>systemd[1]: Unit proc-sys-fs-binfmt_misc.automount entered failed state.
<30>systemd[1]: Starting Swap.
<30>systemd[1]: Reached target Swap.
<30>systemd[1]: Starting Root Slice.
<30>systemd[1]: Created slice Root Slice.
<30>systemd[1]: Starting User and Session Slice.
<30>systemd[1]: Created slice User and Session Slice.
<30>systemd[1]: Starting Delayed Shutdown Socket.
<30>systemd[1]: Listening on Delayed Shutdown Socket.
<30>systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
<30>systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
<30>systemd[1]: Starting Journal Socket (/dev/log).
<30>systemd[1]: Listening on Journal Socket (/dev/log).
<30>systemd[1]: Starting udev Control Socket.
<30>systemd[1]: Listening on udev Control Socket.
<30>systemd[1]: Starting udev Kernel Socket.
<30>systemd[1]: Listening on udev Kernel Socket.
<30>systemd[1]: Starting Journal Socket.
<30>systemd[1]: Listening on Journal Socket.
<30>systemd[1]: Starting System Slice.
<30>systemd[1]: Created slice System Slice.
<30>systemd[1]: Starting system-serial\x2dgetty.slice.
<30>systemd[1]: Created slice system-serial\x2dgetty.slice.
<30>systemd[1]: Starting system-getty.slice.
<30>systemd[1]: Created slice system-getty.slice.
<30>systemd[1]: Starting Increase datagram queue length...
<30>systemd[1]: Starting Restore / save the current clock...
<30>systemd[1]: Starting udev Coldplug all Devices...
<30>systemd[1]: Mounting Debug File System...
<30>systemd[1]: Mounted Huge Pages File System.
<30>systemd[1]: Starting Load Kernel Modules...
<30>systemd[1]: Starting Create list of required static device nodes for the current kernel...
<6>sunxi_gpio driver init ver 1.3
<30>systemd[1]: Mounted POSIX Message Queue File System.
<6>gpiochip_add: registered GPIOs 1 to 15 on device: A1X_GPIO
<30>systemd[1]: Started Set Up Additional Binary Formats.
<30>systemd[1]: Starting LSB: Set keymap...
<30>systemd[1]: Starting Slices.
<30>systemd[1]: Reached target Slices.
<30>systemd[1]: Mounted Debug File System.
<30>systemd[1]: Started Increase datagram queue length.
<30>systemd[1]: Started Restore / save the current clock.
<30>systemd[1]: Started Load Kernel Modules.
<30>systemd[1]: Started Create list of required static device nodes for the current kernel.
<30>systemd[1]: Started LSB: Set keymap.
<30>systemd[1]: Time has been changed
<30>systemd[1]: Starting Create Static Device Nodes in /dev...
<30>systemd[1]: Mounting Configuration File System...
<30>systemd[1]: Starting Apply Kernel Variables...
<30>systemd[1]: Mounting FUSE Control File System...
<30>systemd[1]: Starting Syslog Socket.
<30>systemd[1]: Listening on Syslog Socket.
<30>systemd[1]: Starting Journal Service...
<30>systemd[1]: Started Journal Service.
<30>systemd-udevd[80]: starting version 215
<6>usbcore: registered new interface driver rtl8192cu
<6>EXT4-fs (mmcblk0p1): re-mounted. Opts: data=writeback,commit=600,errors=remount-ro
<46>systemd-journald[79]: Received request to flush runtime journal from PID 1
Debian GNU/Linux 8 olinux-som-a13 ttyS0
olinux-som-a13 login: <6>Adding 131068k swap on /var/swap. Priority:-1 extents:1 across:131068k SS
<30>systemd-shutdown[1]: Sending SIGTERM to remaining processes...
<46>systemd-journald[79]: Received SIGTERM from PID 1 (systemd-shutdow).
<30>systemd-shutdown[1]: Sending SIGKILL to remaining processes...
<30>systemd-shutdown[1]: Unmounting file systems.
<30>systemd-shutdown[1]: Unmounting /tmp.
<30>systemd-shutdown[1]: Unmounting /sys/fs/fuse/connections.
<30>systemd-shutdown[1]: Unmounting /sys/kernel/config.
<30>systemd-shutdown[1]: Unmounting /sys/kernel/debug.
<6>EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
<30>systemd-shutdown[1]: All filesystems unmounted.
<30>systemd-shutdown[1]: Deactivating swaps.
<30>systemd-shutdown[1]: All swaps deactivated.
<30>systemd-shutdown[1]: Detaching loop devices.
<30>systemd-shutdown[1]: All loop devices detached.
<30>systemd-shutdown[1]: Detaching DM devices.
<30>systemd-shutdown[1]: All DM devices detached.
<30>systemd-shutdown[1]: Rebooting.
<6>[sw-ohci1]: shutdown start
[sw-ohci1]: close clock
<6>[sw-ohci1]: shutdown end
<6>[sw-ehci1]: shutdown start
[sw-ehci1]: Set USB Power OFF
[sw-ehci1]: close clock
<6>[sw-ehci1]: shutdown end
[sw_hcd0]: sw_hcd shutdown start
is_on = 0, hcd0_set_vbus_cnt = 0
[sw_hcd_host0]: Set USB Power Off
[sw_hcd0]: close_usb_clock
[sw_hcd0]: Set aside some time to AXP
[sw_hcd0]: sw_hcd shutdown end
[NAND]shutdown
nand try to shutdown 0 time
Nand flash shutdown ok!
<0>Restarting system.
DRAM: 512 MiB
I2C: ready
DRAM: 512 MiB
In: serial
Out: vga
Err: vga
starting USB...
USB0: USB EHCI 1.00
USB1: USB OHCI 1.0
Scanning mmc 0:1...
29804 bytes read in 740 ms (39.1 KiB/s)
Starting kernel ...
Machine: sun5i
<6>Memory Reserved:
<6>NR_IRQS:128
<6>dummy:
<5>FS-Cache: Loaded
vendor_id = 0x18d1
adb_id = 0x2
msc_release = 100
luns = 3
[pa_drv] start!!!
Modules linked in:
<4>---[ end trace 90e8655a8c04d851 ]---
Modules linked in:
<4>---[ end trace 90e8655a8c04d852 ]---
<6> mmcblk0: p1
<6>md: autorun ...
<30>systemd-udevd[79]: starting version 215
<46>systemd-journald[78]: Received request to flush runtime journal from PID 1
olinux-som-a13 login: root
Password:
You are required to change your password immediately (root enforced)
Changing password for root.
(current) UNIX password:
Enter new UNIX password:
Retype new UNIX password:
Bad: new password is too simple
Linux olinux-som-a13 3.4.110-sun5i #1 PREEMPT Sat Feb 20 16:44:33 CET 2016 armv7l
^C
Thank you for choosing Armbian! Support: www.armbian.com
root@olinux-som-a13:~#
I can login but the systems seems to hang, I waited very long to not destroy some important stuff. Ctrl-Z doesn't respond so at some point I used Ctrl-C to kill the job.
I get a shell. Everything seems to be ok. But after reboot I won't even get login prompt any more. And the terminal doesn't respond at all.
root@olinux-som-a13:~# reboot
<46>systemd-journald[78]: Received SIGTERM from PID 1 (systemd-shutdow).
[NAND]shutdown
DRAM: 512 MiB
I2C: ready
DRAM: 512 MiB
In: serial
Out: vga
Err: vga
starting USB...
USB0: USB EHCI 1.00
USB1: USB OHCI 1.0
Scanning mmc 0:1...
Starting kernel ...
Machine: sun5i
<6>Memory Reserved:
<6>NR_IRQS:128
<6>dummy:
<5>FS-Cache: Loaded
vendor_id = 0x18d1
adb_id = 0x2
msc_release = 100
luns = 3
[pa_drv] start!!!
Modules linked in:
<4>---[ end trace 4830e2ce8b9f07cb ]---
Modules linked in:
<4>---[ end trace 4830e2ce8b9f07cc ]---
<6> mmcblk0: p1
<6>md: autorun ...
I tried to figure out what's running there but the board has no network connection, so there is no way around terminal.
Do you have any idea what's running there and preventing the board from booting. I'd appreciate any hint.
If you need more logs, I have one login after flashing the sdcard to get it ;)
Thank you
derschueddi
