I tried two builds for my OPI Zero.
Armbian_5.35_Orangepizero_Debian_jessie_next_4.13.16.7z
Wifi works but no audio. (and instabel ethernet connect)
Armbian_5.35_Orangepione_Ubuntu_xenial_default_3.4.113.7z
Audio works but no WiFi
In witch build works both ?
Edited by prediger
Did you enable Analog-Codec as Hrdware in armbian-config?
Normally the Zero has no Audio-Out (only via extension) - so default its disabled.
Yes I did.
Did it work on your OPi Zero with Armbian_5.35_Orangepizero_Debian_jessie_next_4.13.16.7z
Or witch build did you use.
Hardware is OK. It works with  Armbian_5.35_Orangepione_Ubuntu_xenial_default_3.4.113.7z but no WiFi. :-)
Orange One has not onboard WiFi. For 3rd party USB devices, you are on your own to try making them work. It is a complex problem which is far out of our resources. Check "tested hardware" section on the download page to find out which of them work out of the box and on which kernel. It saves you a lot of time.
Iam using the OPi Zero only with Ethernet, because I use the little black Cube-case - and this is to small for the WiFi Antenna.
On my 2 OPi Zero I got working Audio with these two armbian-versions:
ARMBIAN 5.41.180208 nightly Ubuntu 16.04.3 LTS 4.14.18-sunxi
Linux orangepizero 4.14.18-sunxi #31 SMP Fri Feb 9 11:11:15 CET 2018 armv7l armv7l armv7l GNU/Linux
and
ARMBIAN 5.38 stable Ubuntu 16.04.3 LTS 3.4.113-sun8i
Linux orangepizero 3.4.113-sun8i #18 SMP PREEMPT Wed Jan 24 22:10:49 CET 2018 armv7l armv7l armv7l GNU/Linux
What I did:
Download: Armbian_5.38_Orangepizero_Debian_stretch_next_4.14.14.img
from https://dl.armbian.com/orangepizero/ Debian_stretch_next.7z
Ubpack with 7zip
Write Armbian_5.38_Orangepizero_Debian_stretch_next_4.14.14.img with Win32 Disk Imager on SD-Card
Connect the OPi Ziro with mein network via Eternet.
Plug in the SD-Card
Connect the powersupply
Waiting a wihle and look in my router for the IP of the OPi zero
First try connect witch WinSCP. User root pass 1234.
the OPi disconnect the session
then start a session via with WinSCP binded Putty (start Putty itselfe)
Type root type 1234 in Putty
following the instructions and OPi reboot.
After a wihle an connect with the new Password via WinSCP is posibel.
Now I can work with WinSCP and the linked Putty-client how used
Now in Putty
apt-get update
apt-get upgade
reboot
armbian-config
->System->Hardware->[space]analog-codec->Save->cancel->cancel->cancel
reboot
testing audio
alsamixer (checking Line-Out)
apt-get install mplayer2
mplayer http://hr-hr3-live.cast.addradio.de/hr/hr3/live/mp3/128/stream.mp3
Yahr an audiosignal on Line Out appers
armbian-config
->Network->wlan0->WiFi->OK
Setup my WiFi->Quit->cancel->cancel theirby the WiFi IP will be shown.
reboot
Unplug ethernetcabel imidetly.
Waitig a wihle
reconnect WinSCP via WiFi IP
open Putty via WinSCP
It runns. :-)
