t-bob Posted February 21, 2018 Posted February 21, 2018 Hi, I was wondering if anyone was having issues with the ethernet port using the legacy kernel ? It does seem to kind of work ... it will get DHCP from the router and configure the routing tables etc but after that it goes wonky. When I do a ping test from the router I get "50/50 transmitted, 15/50 received, 70% loss". A ping test from the opi-win to the router gets a similar result. If I try a ping/ssh from a PC connected to the router I get a 95% packet loss Everything else seems to work fine ... HDMI, USB, WiFi (AP/STA modes) which is really, really nice. Thanks TB
Nhan Nguyen Posted March 20, 2018 Posted March 20, 2018 I have the same problem when using the pre-build image. Yesterday, I compiled an image using latest source code and deployed it on two boards. Everything is working fine now
Igor Posted March 20, 2018 Posted March 20, 2018 4 hours ago, Nhan Nguyen said: Yesterday, I compiled an image using latest source code and deployed it on two boards. Everything is working fine now You mean https://github.com/armbian/build, default branch?
Nhan Nguyen Posted March 20, 2018 Posted March 20, 2018 2 hours ago, Igor said: You mean https://github.com/armbian/build, default branch? Yes, that is.
Nhan Nguyen Posted March 20, 2018 Posted March 20, 2018 Now, I see the issue again when connecting to a Gigabit Ethernet switch :(. There is no problem if we connect board to a Fast Ethernet switch
Igor Posted March 20, 2018 Posted March 20, 2018 1 minute ago, Nhan Nguyen said: Now, I see the issue again when connecting to a Gigabit Ethernet switch :(. There is no problem if we connect board to a Fast Ethernet switch https://www.armbian.com/pine64/ Most if not all problems which are written under Pine64 are also present here. Documentation is only slightly outdated. Some things were fixed in the meantime. Nothing we can do about. 1
Nhan Nguyen Posted March 20, 2018 Posted March 20, 2018 11 minutes ago, Igor said: https://www.armbian.com/pine64/ Most if not all problems which are written under Pine64 are also present here. Documentation is only slightly outdated. Some things were fixed in the meantime. Nothing we can do about. Thank Igor. I do work-around the issue by adding ethtool -s eth0 speed 100 duplex full to /etc/rc.local as suggestion and it works fine now
