Skip to content
View in the app
Armbian Community Forums
Toolchain Banana Pi M2 Zero (H3)
Featured Replies
Hello,
I'm trying to build a image using the amazing auto builder supplied by armbian. In the past I've build kernels and modules for linux running at CycloneV-Devices. I don't need graphic support. If I use the image for a M2 Plus there is a initialization issue at mmc:
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
Card did not respond to voltage select!
mmc_init: -95, time 22
So I'm stuck. Is there a way to get it running by using the auto builder?
Using the stock image provided by the manufacturer works.
Regards,
Sombohan
  • Author
Ok, I've got the patch but I'm not familiar to patch device trees from where do I have to apply the patch? Directly at the image at the sd-card or somewhere in the build-root?
For reasons unknown to me Igor decided 3 weeks ago to add this Zero as CSC config (I don't understand why). Those patches are also part of the build system but since the paths are bogus (v2017.09-bpi-m2z/drivers/mmc/) they don't work which I consider a feature and not a bug given the insane sh*t show we have here with Armbian and u-boot updates constantly breaking installations.
https://github.com/armbian/build/commit/0df0209db90855355abab5326ef075f8feb89ba5#diff-38c994f09106d3b8d9bc91cd2e61a7a8
This was just a hint that BPi people for their own needs to provide fake Armbian images that harm our reputation use an ugly patch for SD card detection. Sorry, can't help further... but maybe others jump in and explain how to fix the patch (which might break then all other sunxi boards?)
  • Author
Thank you, after I've tried to do some copy&paste with the .patch files. I've found out, that they where already installed. I've come to the expert view at board selection... "Show CSC/WIP/EOS" does the trick! So maybe I haven't read the documentation in depth. But now I can go on.
Yes, but this means you are on your own. We don't try to support boards you find in there. They might work or not. They might become supported (WIP), they will probably never be(CSC) or support ended (EOS).
Why has the board been added in the first place? Isn't this part of your commit a real problem?
https://github.com/armbian/build/blob/0df0209db90855355abab5326ef075f8feb89ba5/patch/u-boot/u-boot-sunxi/fix-sdcard-detect-bpi-m2z.patch
Without this ugly hack the Zero will not be able to boot anyway (see post #1 of this thread). The patch is expected to fail since the path definitions are wrong (v2017.09/drivers/mmc/sunxi_mmc.c and v2017.09-bpi-m2z/drivers/mmc/sunxi_mmc.c instead of drivers/mmc/sunxi_mmc.c). So it simply will not result in anyone being able to produce Armbian images for the board using the build system unless the patch is 'fixed'. Now imagine a Zero user figures out how to 'fix' this and then sends his modified code (probably breaking u-boot for every other sunxi device?) as PR and you or someone else merges it for whatever reasons...
We still use no testing branch, we still have neither PR/patch policies nor discussions, the attempts to establish a 'Board Bring Up' policy get ignored. But we constantly have an awful lot of trouble with u-boot and kernel updates breaking installations. Why?
  • Author
If I'm right the bananapim2zero is listed as CSC and you say that means "will probably never be"?
What makes it relevant to be supported?
I've only started this thread do give a smal hint for somebody stuck at this point. I'm trying to get kernel sources matching to the running kernel. The stock image based on armbian does come with the wrong headers by default.
By the way, I'm excited how fast a new user will be supported here. That's cool.
Well, it seems we have internally different views on how board support should look like. In my opinion pulling in the broken patchset from SinoVoip that is just the usual result of the ignorance they're famous for was not a great idea since it's both not working as expected and if Sinovoip's ugly hack would work it would negatively affect all our other sunxi devices.
Maybe the CSC config will be removed, maybe someone interested in this device will fix it (definitely not me). Device support should work without that ugly hack by simply following the upstream processes. @Icenowy's patch series to officially support this board in mainline is at v5 in the meantime with the most important change to fix the problem you ran into happened already in v2 many many months ago. The stuff that landed now in Armbian's build system is based on really outdated stuff dating back even prior to Icenowy's v2 patch.
  • Author
So for now that means, the support for the zero can be removed at any time because the build toolchain will be updated every time I start it, right?
What about compiling uboot with a working patch and put it here?
https://github.com/armbian/build/tree/master/packages/blobs
Similar to the way it is done for Rockchip boards? So the 'potential' harmful patch can be removed and the board can be stay as .csc without affecting others? The board might not get improvements from upstream uboot but it should at least work. As long as there's no solution for mainline uboot for this board this might be an ok-ish solution. When it breaks, then it breaks and someone interested in this board has to take care to get it up again..
https://github.com/armbian/build/commit/075259c3456c6ef016460be18d3eeddc66e4fed1
There is no problem with this board being added as CSC. But the patch series that was pulled in from SinoVoip contained a stupid and ugly hack and was obviously neither tested nor worked. So I really don't understand what happened. If anyone wants to support this board as CSC (at least a simple test has to happen since everything else is totally weird) then why not adopting Icenowy's DT corrections so that the production batch is able to boot?
Now everything fine, we have 4 files in the repo that result in non working images but it's not a real problem any more other than people playing around with the build system getting frustrated, asking unnecessary questions here and generating support efforts...
If we could only establish policies all developers feel bound to. Before something will be added a DISCUSSION has to happen...
  • Author
I like to share the things I've learned.
I've figured out, that was not the whole story. If a new user checks out the git repository there is an additional step to do.
Copy the fix-sdcard-detect-bpi-m2z.patch to your userpatch/u-boot/u-boot-sunxi/ folder. That file should not be influenced by the changes in the git repository.
On 4.3.2018 at 10:07 PM, tkaiser said:
After that small step it is possible to run the build-process and use the image afterwards.
It may help some users to get their Banana Pi M2 Zero running.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
