buvaluy Posted March 14, 2018 Posted March 14, 2018 I can't get wifi rt5370 working at banana pi m1 on Ubuntu xenial default desktop. dmesg show: phy1 -> rt2x00lib_request_firmware: Error - Failed to request Firmware. Looks like modules(rt2x00usb,rt2800lib,rt2800usb) are loadede but wifi still don't work.
Igor Posted March 14, 2018 Posted March 14, 2018 1 hour ago, buvaluy said: Failed to request Firmware apt install armbian-firmware-full should solve this problem.
buvaluy Posted March 14, 2018 Author Posted March 14, 2018 1 hour ago, Igor said: apt install armbian-firmware-full should solve this problem. It has't helped (
buvaluy Posted March 14, 2018 Author Posted March 14, 2018 Stil get "phy1 -> rt2x00lib_request_firmware: Error - Failed to request Firmware." I thought rt5370 requires open drivers rt2800lib,rt2800usb,rt2x00usb. It works fine out of the box on intel pc with this drivers, I was able to run it on same bananapi with openwrt. What can this message about firmware mean...?
buvaluy Posted March 14, 2018 Author Posted March 14, 2018 My device RT5370 1) INTEL I tried it on intel PC. It works fine. dmesg has line [ 4098.489842] ieee80211 phy1: rt2x00_set_rf: Info - RF chipset 5370 detected [ 4098.525834] ieee80211 phy1: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin' 2) BANAN dmesg has lines [ 16.911706] usbcore: registered new interface driver rt2870 [ 22.671287] phy0 -> rt2x00lib_request_firmware: Error - Failed to request Firmware. Intel has file /usr/lib/firmware/rt2870.bin --- Banan has file /lib/firmware/rt2870.bin intel doesn't have loaded module rt5370sta --- Banan has loaded module rt5370sta May be banan doesn't know about file rt2870.bin?
