An hour a go I powered down my Neo Core 2 and now I can't get it to boot properly.
When I hook it to the serial Monitor this is the output.
It tries to load the "-fixup.scr" file in the /boot/dtb/allwinner/overlay folder but of course this is not available.
With the extfls command I searched the folder and those two files would be available:
sun50i-h5-fixup.scr
sun50i-a64-fixup.scr
The "sun50i-h5-fixup.scr" would be the right one for my processor however why does it choose "-fixup.scr" instead?
Here is the boot sequence output:
U-Boot SPL 2017.11-armbian (Mar 20 2018 - 14:52:25)
DRAM: 1024 MiB
Trying to boot from MMC2
NOTICE:  BL3-1: Running on H5 (1718) in SRAM A2 (@0x44000)
NOTICE:  Configuring SPC Controller
NOTICE:  BL3-1: v1.0(debug):ae78724
NOTICE:  BL3-1: Built : 14:52:20, Mar 20 2018
NOTICE:  DT: sun50i-h5-nanopi-neo-plus2
NOTICE:  SCPI: dummy stub handler, implementation level: 000000
INFO:    BL3-1: Initializing runtime services
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9
U-Boot 2017.11-armbian (Mar 20 2018 - 14:52:25 +0100) Allwinner Technology
CPU:   Allwinner H5 (SUN50I)
Model: FriendlyARM NanoPi NEO Plus 2
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
3100 bytes read in 180 ms (16.6 KiB/s)
## Executing script at 4fc00000
U-boot loaded from eMMC or secondary SD
Boot script loaded from mmc
0 bytes read in 82 ms (0 Bytes/s)
MMC: no card present
mmc_init: -123, time 2
** Bad device mmc 0 **
30723 bytes read in 372 ms (80.1 KiB/s)
** File not found /boot/dtb/allwinner/overlay/-fixup.scr **
4925983 bytes read in 505 ms (9.3 MiB/s)
13080584 bytes read in 824 ms (15.1 MiB/s)
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
   Image Name:   uInitrd
   Data Size:    4925919 Bytes = 4.7 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 49b4d000, end 49fff9df ... OK
   reserving fdt memory region: addr=4fa00000 size=6d000
   Loading Device Tree to 0000000049add000, end 0000000049b4cfff ... OK
Starting kernel ...
Loading, please wait...
starting version 232
done.
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
You can ignore that ...
What happens after this part:
Starting kernel ...
done.
thx. it keeps printing out the same line:
and after 10 or so seconds it does reboot and start over again
Phu now it's working again. So this is what I did:
I made a bootable SD Card to boot the system form the SD.
Then I used chkdsk on the internal 8GB eMMC.
Then I powered off the device, removed the SD-Card and now it works again....
strange...
But thx for the help hope this won't happen again...
