I want to extend the current kernel (Tinkerboard with rockchip-kernel-4.4.120 on Debian-Armbian) to include IR (GPIO) and DVB modules. What do I have to consider or is this possible with the usual run-through? (copy .config from current system, make menuconfig, make, sudo make install, sudo make modules_install)
Is there possibly already a tutorial that I have not seen?
Clash
5 hours ago, Clash said:
Clash
Hi Clash!
i have been building my kernel with great success.
Take a look at https://gist.github.com/rfrht/5f0fa113f12fbacf832e57ff4967785a
Hope that helps!!!
don't hesitate to get in touch
14 hours ago, TonyMac32 said:
Docs.armbian.com
Here I can't find a description to rebuild the kernel on Debian-Stretch on the Tinkerboard. Building the system or kernel on an X86_64 is not an option.
@Clash
It is important what Tony stated though
read the documents.
the recommended build environment is done in a specific Ubuntu version, along correct gcc versions etc
i strongly recommend you to stick to that. While theoretically it might be possible to run a build in your TinkerBoard tool chain,  there might have compilation errors etc.
i have chose to run the Ubuntu image in a docker container in order to take advantage of native cpu speed and not tainting my physical environment. Works great, really. It was my first docker experience and worked real good.
Ah, I misread.  To be honest I think it was actually faster to start from scratch and install the build system on a PC and build than to recompile on the ARM device itself...
Worth to add here that we host kernel sources as well. Those are present in a stable repository, while beta we don't since it takes too much space.
linux-source-3.10.106-default-odroidxu4 - This package provides the source code for the Linux kernel 3.10.106
linux-source-3.10.107-default-odroidc1 - This package provides the source code for the Linux kernel 3.10.107
linux-source-3.10.107-default-pine64 - This package provides the source code for the Linux kernel 3.10.107
linux-source-3.14.30-default-meson64 - This package provides the source code for the Linux kernel 3.14.30
linux-source-3.14.79-default-cubox - This package provides the source code for the Linux kernel 3.14.79
linux-source-3.14.79-default-odroidc2 - This package provides the source code for the Linux kernel 3.14.79
linux-source-3.14.79-default-udoo - This package provides the source code for the Linux kernel 3.14.79
linux-source-3.14.79-default-udoo-neo - This package provides the source code for the Linux kernel 3.14.79
linux-source-3.14.79-dev-cubox - This package provides the source code for the Linux kernel 3.14.79
linux-source-3.4.113-default-sun4i - This package provides the source code for the Linux kernel 3.4.113
linux-source-3.4.113-default-sun7i - This package provides the source code for the Linux kernel 3.4.113
linux-source-3.4.113-default-sun8i - This package provides the source code for the Linux kernel 3.4.113
linux-source-4.11.12-dev-sun8i - This package provides the source code for the Linux kernel 4.11.12
linux-source-4.13.15-dev-mvebu - This package provides the source code for the Linux kernel 4.13.15
linux-source-4.13.15-next-odroidc2 - This package provides the source code for the Linux kernel 4.13.15
linux-source-4.13.16-next-cubox - This package provides the source code for the Linux kernel 4.13.16
linux-source-4.13.16-next-mvebu - This package provides the source code for the Linux kernel 4.13.16
linux-source-4.13.16-next-rockchip - This package provides the source code for the Linux kernel 4.13.16
linux-source-4.13.16-next-sunxi - This package provides the source code for the Linux kernel 4.13.16
linux-source-4.13.16-next-sunxi64 - This package provides the source code for the Linux kernel 4.13.16
linux-source-4.13.2-dev-sunxi64 - This package provides the source code for the Linux kernel 4.13.2
linux-source-4.14.0-dev-meson64 - This package provides the source code for the Linux kernel 4.14.0
linux-source-4.14.0-dev-mvebu64 - This package provides the source code for the Linux kernel 4.14.0
linux-source-4.14.0-dev-odroidc2 - This package provides the source code for the Linux kernel 4.14.0
linux-source-4.14.0-dev-odroidxu4 - This package provides the source code for the Linux kernel 4.14.0
linux-source-4.14.0-dev-rockchip - This package provides the source code for the Linux kernel 4.14.0
linux-source-4.14.0-dev-sunxi - This package provides the source code for the Linux kernel 4.14.0
linux-source-4.14.0-dev-udoo - This package provides the source code for the Linux kernel 4.14.0
linux-source-4.14.0-rc2-dev-rk3328 - This package provides the source code for the Linux kernel 4.14.0-rc2
linux-source-4.14.0-rc7-dev-sunxi64 - This package provides the source code for the Linux kernel 4.14.0-rc7
linux-source-4.14.14-next-cubox - This package provides the source code for the Linux kernel 4.14.14
linux-source-4.14.14-next-meson64 - This package provides the source code for the Linux kernel 4.14.14
linux-source-4.14.14-next-mvebu - This package provides the source code for the Linux kernel 4.14.14
linux-source-4.14.14-next-mvebu64 - This package provides the source code for the Linux kernel 4.14.14
linux-source-4.14.14-next-odroidc2 - This package provides the source code for the Linux kernel 4.14.14
linux-source-4.14.14-next-rockchip - This package provides the source code for the Linux kernel 4.14.14
linux-source-4.14.15-dev-mvebu - This package provides the source code for the Linux kernel 4.14.15
linux-source-4.14.15-dev-udoo - This package provides the source code for the Linux kernel 4.14.15
linux-source-4.14.15-next-odroidxu4 - This package provides the source code for the Linux kernel 4.14.15
linux-source-4.14.15-next-sunxi - This package provides the source code for the Linux kernel 4.14.15
linux-source-4.14.15-next-sunxi64 - This package provides the source code for the Linux kernel 4.14.15
linux-source-4.14.17-next-mvebu - This package provides the source code for the Linux kernel 4.14.17
linux-source-4.14.18-next-mvebu - This package provides the source code for the Linux kernel 4.14.18
linux-source-4.14.18-next-sunxi - This package provides the source code for the Linux kernel 4.14.18
linux-source-4.14.18-next-sunxi64 - This package provides the source code for the Linux kernel 4.14.18
linux-source-4.14.2-next-meson64 - This package provides the source code for the Linux kernel 4.14.2
linux-source-4.14.2-next-mvebu64 - This package provides the source code for the Linux kernel 4.14.2
linux-source-4.15.0-rc9-dev-meson64 - This package provides the source code for the Linux kernel 4.15.0-rc9
linux-source-4.15.0-rc9-dev-mvebu64 - This package provides the source code for the Linux kernel 4.15.0-rc9
linux-source-4.15.0-rc9-dev-odroidc2 - This package provides the source code for the Linux kernel 4.15.0-rc9
linux-source-4.15.0-rc9-dev-rockchip - This package provides the source code for the Linux kernel 4.15.0-rc9
linux-source-4.15.0-rc9-dev-sunxi - This package provides the source code for the Linux kernel 4.15.0-rc9
linux-source-4.4.102-default-mvebu - This package provides the source code for the Linux kernel 4.4.102
linux-source-4.4.102-default-mvebu64 - This package provides the source code for the Linux kernel 4.4.102
linux-source-4.4.102-default-rockchip - This package provides the source code for the Linux kernel 4.4.102
linux-source-4.4.102-next-udoo - This package provides the source code for the Linux kernel 4.4.102
linux-source-4.4.112-default-mvebu - This package provides the source code for the Linux kernel 4.4.112
linux-source-4.4.112-default-mvebu64 - This package provides the source code for the Linux kernel 4.4.112
linux-source-4.4.112-default-rockchip - This package provides the source code for the Linux kernel 4.4.112
linux-source-4.4.112-next-udoo - This package provides the source code for the Linux kernel 4.4.112
linux-source-4.4.115-default-mvebu - This package provides the source code for the Linux kernel 4.4.115
linux-source-4.4.120-default-rockchip - This package provides the source code for the Linux kernel 4.4.120
linux-source-4.4.77-default-rk3328 - This package provides the source code for the Linux kernel 4.4.77
linux-source-4.9.61-next-odroidxu4 - This package provides the source code for the Linux kernel 4.9.61
linux-source-4.9.71-dev-odroidxu4 - This package provides the source code for the Linux kernel 4.9.71
