Igor Posted May 10, 2018 Share Posted May 10, 2018 On 5/6/2018 at 9:51 PM, umiddelb said: like the author's nickname or real name. Unfortunately, this property is not possible to change in admin. I can only request this feature to be added once or dive into the code ... 40 minutes ago, rufik said: Do you have a problem with logging in using tapatalk? The only problem is with my direct shortcut to the forum ... if I go to the forum that way it stuck. If I go from the main menu and then choosing armbian, it works. So far other function works. Link to comment Share on other sites More sharing options...
rufik Posted May 10, 2018 Share Posted May 10, 2018 1 minute ago, Igor said: The only problem is with my direct shortcut to the forum ... if I go to the forum that way it stuck. If I go from the main menu and then choosing armbian, it works. So far other function works. Hmmm, but I used to go to the forum from Tapatalk's just that way, from main menu. I've tried to clear app cache, but no-go. Link to comment Share on other sites More sharing options...
chrisf Posted May 10, 2018 Share Posted May 10, 2018 Looks like the logo doesn't work well with mobile. It's cutting off some text Link to comment Share on other sites More sharing options...
