Carlos_Tico Posted May 10, 2018 Posted May 10, 2018 Clean Installation of Armbian Stretch mainline kernel 4.14.y to the internal memory of the Orange PI 2018-05-10 09:38:51: (mod_accesslog.c.180) writing access log entry failed: /var/log/lighttpd/access.log No space left on device 2018-05-10 09:39:21: (mod_accesslog.c.180) writing access log entry failed: /var/log/lighttpd/access.log No space left on device 2018-05-10 09:39:22: (mod_accesslog.c.180) writing access log entry failed: /var/log/lighttpd/access.log No space left on device 2018-05-10 09:39:52: (mod_accesslog.c.180) writing access log entry failed: /var/log/lighttpd/access.log No space left on device 2018-05-10 09:39:53: (mod_accesslog.c.180) writing access log entry failed: /var/log/lighttpd/access.log No space left on device pi@orangepiplus2e:~$ sudo fdisk -l Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/mmcblk1: 14.6 GiB, 15634268160 bytes, 30535680 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x6ea0214e Device Boot Start End Sectors Size Id Type /dev/mmcblk1p1 8192 30230303 30222112 14.4G 83 Linux Disk /dev/mmcblk1boot1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mmcblk1boot0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/sda: 7.6 GiB, 8103395328 bytes, 15826944 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x00000000 Device Boot Start End Sectors Size Id Type /dev/sda1 * 2 15826943 15826942 7.6G 7 HPFS/NTFS/exFAT
WarHawk_AVG Posted June 27, 2018 Posted June 27, 2018 Check power....check to ensure you have a good quality SD card...I too just went round and round...turns out I had a sd card that was wearing out
guidol Posted June 27, 2018 Posted June 27, 2018 On 5/10/2018 at 6:24 PM, Carlos_Tico said: Clean Installation of Armbian Stretch mainline kernel 4.14.y to the internal memory of the Orange PI 2018-05-10 09:38:51: (mod_accesslog.c.180) writing access log entry failed: /var/log/lighttpd/access.log No space left on device 2018-05-10 09:39:21: (mod_accesslog.c.180) writing access log entry failed: /var/log/lighttpd/access.log No space left on device I dont think you have to check the card, because most likely its caused by log2ram whcih is used ba armbian. I also got "no space" in /var/log with my Pihole, because log2ram was set to 50MB in /etc/default/log2ram (50MB Ram-Disk) @Igor is working with some other developers on a ZRAM option to replace this. By now I have extended (on systems with >= 5122MB of Ram) the log2ram size to 150-250MB (depending on the System Ram). Now my Pihole is working fine without getting "out of space" root@bpi-a20(192.168.6.3):~# more /etc/default/log2ram # configuration values for the log2ram service # # enable the log2ram service? ENABLED=true # # size of the tmpfs mount SIZE=250M # # use rsync instead of cp -r # requires rsync installed, may provide better performance # due to copying only new and changed files USE_RSYNC=true # 1
