  On 4/17/2020 at 1:05 PM, dolphs said:
with kernel >=5.6
Expand
There is no support in upstream kernel and it won't be because its way too expensive to pay for.
rgd NanoPi Fire3-LTS is it possible with kernel >=5.6 to (over)clock this board to 1.6GHz ( or even 1.8Ghz ) stable
Might be a lovely pick for my new server since the H5 boards are hard to get currently ( at friendlyarm at least )
Expand
Been a while since I been on these forums but if I remember correctly when I did get it to 1.6ghz the temps were quite high on load even with copper shims decent thermal paste.
I use mine for mining still going strong all 10 of them in a cluster.
Hello, I never mined anything before, but after I ve read some articles I ve become very interested in finding out more about mining with ARM boards.
https://www.linkedin.com/pulse/more-efficient-mining-raspberry-pi-julien-delorme/
and  https://climbers.net/sbc/nanopi-fire3-arm-supercomputer/
Please give me a hint:
-A ruff estimate of how much crypto ( equivalent in USD ) I will mine in a month with 10 x NanoPI Fire3 boards ?
-Do you know a better board for this task than NanoPI Fire3 ?
Expand
N2+ or Khadas VIM3. They're the only ones that have more performance than this SoC.
I've got the NanoPC T3+ with this SoC. Single core performance isn't great. But multi-core it is amazing. Faster than the RK3399.
Here some old benchmarks. For you the CPUMiner scores are important.
64-bit SBC's
Odroid N2+           Clock S/C    | B/C         | Blender   | 7z S/C    | 7Z B/C | CPUMiner
Ubuntu Bionic 4.9    2.02Ghz        2.40Ghz       11m20s      1755        2504      14
Khadas VIM3            |SBC bench result  |CPU Miner      |7-zip s/c A53 |7-zip b/c A73 |7-zip multi avg. of 3 |Blender
Ubuntu 18.04.02         http://ix.io/1MFD  13.10kH/s           1577       2311           10578                  42m51s
Armbian@1.9S.C./1.7B.C. http://ix.io/1NRJ
Odroid N2              |SBC bench result  |CPU Miner      |7-zip s/c A53 |7-zip b/c A73 |7-zip multi avg. of 3 |Blender
Ubuntu Bionic           http://ix.io/1Brv  11.35kH/s           1564       1879           9988                   50m28s
NanoPC T3+             |SBC bench result  |CPU Miner          |7-zip s/c |7-zip b/c     |7-zip multi avg. of 3 |Blender
Armbian Bionic          http://ix.io/1iRJ  10.99kH/s           1290                      10254                  1h10m25s
Arbmian Stretch         http://ix.io/1qiF  8.55kH/s            1275                      10149                  1h13m55s
Rock Pi 4B             |SBC bench result  |CPU Miner          |7-zip s/c |7-zip b/c     |7-zip multi avg. of 3 |Blender
Ubuntu                  http://ix.io/1uVr  9.50kH/s            1242       1818           7802                   1h17m22s
NanoPi M4              |SBC bench result  |CPU Miner          |7-zip s/c |7-zip b/c     |7-zip multi avg. of 3 |Blender
Armbian bionic hz1000   http://ix.io/1nLh  10.23kH/s           1335       2005           8352                   1h13m50s
 CONFIG_HZ=250          http://ix.io/1BLW  10.45kH/s           1335       2007           8320                   1h08m28s
Armbionic@1.4/1.8 hz250                                        1253       1828           7821                   1h12m52s
Armbian bionic nightly  http://ix.io/1pDo  10.24kH/s           1329       1990           8292                   1h13m28s
Armbian stretch desktop http://ix.io/1odF  8.66kH/s            1350       1977           8400                   1h14m12s
Armbian stretch dsk nightly  //ix.io/1pM0  8.80kH/s            1359       1993           8500                   1h15m04s
Armbian stretch core no fan  //ix.io/1pKU  8.80-8.65kH/s       1353       1989           8461
Armbian stretch core         //ix.io/1pL9  8.76kH/s            1354       1988           8456
Armbian stretch core nightly //ix.io/1pLf  8.82kH/s            1357       1994           8494
Lubuntu Bionic arm64    http://ix.io/1oGJ  9.24kH/s CPU Miner  1056       1551           6943                   1h28m13s
Lubuntu Bionic armhf    http://ix.io/1pJ1                      1111       1769           7705                   2h02m54s
Lubuntu Xenial armhf	http://ix.io/1oCb                      989        1507           6339                   2h20m51s
Khadas Vim2 Max        |SBC bench result  |CPU Miner          |7-zip s/c |7-zip b/c     |7-zip multi avg. of 3 |Blender
Ubuntu Xenial           http://ix.io/1qkA  6.86kH/s            823        1134           6682                   1h14m39s      7-zip only 600% of 800% used
It would be hard to make enough money to repay the devices, and power.
The Odroid N2+ is one of the most energy efficient SBCs around. When maxed out on CPUs it only consumes 6W. Most others need double of that for half the performance.
These days mining isn't done on computer hardware but on specialized hardware. So with a few SBCs you can't compete with these ASICs.
But if you use solar power then you've got the big advantage that you don't need to pay for energy costs. What's the biggest cost for ASICs. If you really want to do this, then do your research well. Else it's a probable moneypit. But at least you can enjoy the SBCs.
Greetings.
Yeah, mining is competitive enough today that you either need an edge (e.g. subsidized electricity) or spend a lot of time on optimization to do better than break-even. Especially true since some are even happy mining at a loss (e.g. circumventing currency regulation or money laundering).
You could still look into staking, though - Ethereum is migrating away from PoW(mining) to PoS (staking) and there are already Tezos, Cardano, Cosmos and others. The good news is that a decent SBC or two should be good enough for that.
Posted (edited)
Добрый день!
Подскажите, где можно скачать драйвер GPIO на эту плату для python3?
Good day! Tell me where you can download the GPIO driver for this board for python3?
Edited by alexeyDZ
