I'm currently designing a PCB which will use a nanopi duo board. Unfortunately it is not in stock at the moment so I can't order one yet to verify some measurements.
Can someone (@guidol or @larry bank maybe?) who has one sitting on their desk please give me the following info;
- Distance between headers.  Total width is 1" so I guessed 0.9"... Is this correct?
- length of the pin headers. So I know how high it will sit on the PCB
- total height of the pins + PCB
- is there anything on the bottom PCB which is higher than the plastic on the pin headers? In other words; can I push the whole module all the way down to a PCB and then only have the thickness of the plastic of the pin headers? Or is something "sticking" out..
- How much does the heatsink add to the total thickness? (Or what is the thickness of the heatsink...)
Thanks in advance for your help and time.
24mm
2mm plastic (yellow) & 6mm the metal pins
12mm
the uSD-port is below the plastic of the headers BUT the screws for the heat sink are 0.5-1mm higher than the yellow plastic
the heat-sink does add around 4mm - so the total thickness is 16mm
I have one more question, which I hope @guidol can help with too...
If I read the datasheet of "magjacks" made by Pulse (that is a connector with built in transformers / magnetics) I see the following;
There is clearly an set of resistors terminating the lines from the magjack to the PHY (in the H2+)...
However on the diagrams there is nothing like this;
So I hope that someone can measure for me the resistance between pin 13&14 on the headers of the DUO when it is not plugged into a shield. If there is a resistance of about 100ohms, it means that these resistors are built into the CPU... If not, then I need to add them. (And FriendlyArm might need to revise their shield or module ;-) )
Thanks in advance!
@chwe the snippets in my post come from their diagram of the module... I noticed forgot to add the snippets from the shield.. I'll add it when I'm home again.  But that will show no termination circuit...
between Pin 13 & 14 the ohm-meter doesnt show a reaction - like there is no connection between these two pins.
Did try also both directions (+/-)
NO zero Ohm and NO 100 Ohm
19 minutes ago, pzw said:
Thanks @guidol! Last question. Was that powered up?
no
[EDIT] with power via MicroUSB there are 105-120 Ohm - ALL measured without the base, BUT the picture for finding the right pins....with heatsink I couldnt read at the top of the Duo :(
Great news! Thanks @guidol. Saves me a headache.. haha .. I suspected that the termination might be in the h2+ ... Thanks for confirming this..
Hmm I'm not a EE but wasn't this clear from the schematics (as far as I understand schematics this was clarified in the minishield part of it). Hmm lets ask a EE... @TonyMac32 :P
@chwe In the schematics it was not clear if there is a termination circuit inside the CPU... The headache referred to the required implementation of a termination circuit in my design.
@TonyMac32 Thanks for verifying it :-) . It did strike me as odd if FA would have overlooked this termination requirement... Also I would have expected network throughput issues because of it, but I couldn't find reports about that... So that made it almost certain that the termination was happening on the die.
