9 hours ago, jrtaylor said:
The system would boot to starting kernel and then just stay there. Any Ideas???
Well, first try to boot with more verbosity, check where is default boot log going ... and paste what you get.
This is all I get.
U-Boot SPL 2017.11-armbian (Jan 25 2018 - 07:59:18)
DRAM: 256 MiB
Trying to boot from MMC1
U-Boot 2017.11-armbian (Jan 25 2018 - 07:59:18 +0100) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi Zero
DRAM:  256 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
3763 bytes read in 93 ms (39.1 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
179 bytes read in 50 ms (2.9 KiB/s)
7411708 bytes read in 850 ms (8.3 MiB/s)
6968976 bytes read in 851 ms (7.8 MiB/s)
Found legacy kernel configuration
** File not found /script.bin **
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    7411644 Bytes = 7.1 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
   Loading Ramdisk to 498ee000, end 49fff7bc ... OK
Starting kernel ...
This is what is in /boot
root@orangepi:/# ls -al /boot
total 24731
drwxr-xr-x  5 root root    1024 Jun  8 16:02 .
drwxr-xr-x 22 root root    4096 Jun  8 00:42 ..
-rw-rw-r--  1 root root     209 Jun  8 16:02 armbianEnv.txt
-rw-rw-r--  1 root root    1624 Jan 27 19:04 armbian_first_run.txt.template
lrwxrwxrwx  1 root root       1 Jun  8 00:18 boot -> .
-rw-rw-r--  1 root root  230454 Jan 27 19:04 boot.bmp
-rw-rw-r--  1 root root    3746 Jun  8 16:02 boot.cmd
-rw-rw-r--  1 root root    4882 Jan 27 19:04 boot-desktop.png
-rw-rw-r--  1 root root    3804 Jun  8 15:40 boot.scr
-rw-r--r--  1 root root  157956 Jan 25 11:22 config-4.14.14-sunxi
lrwxrwxrwx  1 root root      17 Jan 27 19:03 dtb -> dtb-4.14.14-sunxi
drwxr-xr-x  3 root root    8192 Jan 27 19:03 dtb-4.14.14-sunxi
-rw-------  1 root root 7412871 Jun  8 01:36 initrd.img-4.14.14-sunxi
drwx------  2 root root   12288 Jun  8 00:16 lost+found
drwxrwxr-x  2 root root    1024 Jan 27 19:04 overlay-user
-rw-r--r--  1 root root 3093830 Jan 25 11:22 System.map-4.14.14-sunxi
lrwxrwxrwx  1 root root      21 Jun  8 01:36 uInitrd -> uInitrd-4.14.14-sunxi
-rw-r--r--  1 root root 7412935 Jun  8 01:36 uInitrd-4.14.14-sunxi
-rwxr-xr-x  1 root root 6968976 Jan 25 11:22 vmlinuz-4.14.14-sunxi
lrwxrwxrwx  1 root root      21 Jan 27 19:03 zImage -> vmlinuz-4.14.14-sunxi
I never see anything after Satrting kernel.... It looks like the kernel never loads.
It is loaded as shown above, but it probably doesn't start due to issue with device-tree or the encryption itself ...
root@orangepi:/# gunzip -c /boot/initrd.img* | cpio --quiet -t | grep dropbear
etc/dropbear
etc/dropbear/dropbear_ecdsa_host_key
etc/dropbear/dropbear_rsa_host_key
etc/dropbear/dropbear_dss_host_key
sbin/dropbear
scripts/init-premount/dropbear
scripts/init-bottom/dropbear
root@orangepi:/# gunzip -c /boot/initrd.img* | cpio --quiet -t | grep authorized_keys
root-Er9DIz/.ssh/authorized_keys
root@orangepi:/# gunzip -c /boot/initrd.img* | cpio --quiet -t | grep cryptsetup
lib/arm-linux-gnueabihf/libcryptsetup.so.4
lib/arm-linux-gnueabihf/libcryptsetup.so.4.6.0
lib/cryptsetup
lib/cryptsetup/askpass
sbin/cryptsetup
conf/conf.d/cryptsetup
It tries to boot with the legacy kernel configuration (/boot/.next is missing)
... but you are using the mainline kernel
Created an empty .next in /boot like on the original image that I downloaded. Now it goes to starting kernel and after 30 sec it reboots. Does this mean it could not mount the rootfs?
DRAM:  256 MiB
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
Scanning mmc 0:1...
3764 bytes read in 93 ms (39.1 KiB/s)
209 bytes read in 46 ms (3.9 KiB/s)
7412851 bytes read in 865 ms (8.2 MiB/s)
6968976 bytes read in 858 ms (7.7 MiB/s)
31935 bytes read in 1151 ms (26.4 KiB/s)
504 bytes read in 1474 ms (0 Bytes/s)
Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo
504 bytes read in 1629 ms (0 Bytes/s)
Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo
4179 bytes read in 1494 ms (2 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 44000000
   Image Name:   uInitrd
   Data Size:    7412787 Bytes = 7.1 MiB
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
   Loading Ramdisk to 498ee000, end 49fffc33 ... OK
   reserving fdt memory region: addr=43000000 size=6e000
   Loading Device Tree to 4987d000, end 498edfff ... OK
Starting kernel ...
OK got it working. Part of the problem is I commented out the serial line. So after it booted there was no console output.
Next questions is how can I get it to boot without unlocking the rootfs?
