dasgeraet Posted June 13, 2015 Posted June 13, 2015 Helllo i have problems with an huwei e220 usb umts stick ther i don´t working under igor image only with banian 14.01 the stick is working
Igor Posted June 14, 2015 Posted June 14, 2015 In theory it should work at least with kernel 3.4.107 ... https://wiki.debian.org/Huawei/E220 Where did you try and where it stops?
dasgeraet Posted June 14, 2015 Author Posted June 14, 2015 _ _ ____ _| | __ _ _ __ ___ ___ | |__ ___ | _ \/ || | / _` | '_ ` _ \ / _ \| '_ \ / _ \ | |_) | || |__| (_| | | | | | | (_) | |_) | (_) | | _ <| ||_____\__,_|_| |_| |_|\___/|_.__/ \___/ |_| \_\_|Last login: Sat Jun 13 19:45:21 2015 from 192.168.227.151Load: 0.83, 0.81, 0.85 - Memory: 960Mbroot@ct-router:~# modprobe usb-ohciFATAL: Module usb-ohci not found.root@ct-router:~# modprobe usb-uhciFATAL: Module usb-uhci not found.root@ct-router:~# modprobe usbserial vendor=0x12d1 product=0x1001FATAL: Module usbserial not found.root@ct-router:~# modprobe usbserial vendor=0x12d1 product=0x1003FATAL: Module usbserial not found.root@ct-router:~# mknod /dev/ttyUSB0 c 188 0root@ct-router:~# mknod /dev/ttyUSB1 c 188 1root@ct-router:~# mknod /dev/ttyUSB2 c 188 2root@ct-router:~# ls -la /dev/ttyU*crw-r--r-- 1 root root 188, 0 Jun 14 17:15 /dev/ttyUSB0crw-r--r-- 1 root root 188, 1 Jun 14 17:15 /dev/ttyUSB1crw-r--r-- 1 root root 188, 2 Jun 14 17:15 /dev/ttyUSB2root@ct-router:~# rmmod usb-storagelibkmod: ERROR ../libkmod/libkmod-module.c:1802 kmod_module_get_holders: could not open '/sys/module/usb_storage/holders': No such file or directoryError: Module usb_storage is in useroot@ct-router:~# rmmod usb-serialError: Module usb_serial is not currently loadedroot@ct-router:~# lsusbBus 002 Device 002: ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n WLAN AdapterBus 003 Device 002: ID 12d1:1001 Huawei Technologies Co., Ltd. E169/E620/E800 HSDPA ModemBus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hubBus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hubBus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hubBus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hubroot@ct-router:~# modprobe usbserial vendor=0x12d1 product=0x1001FATAL: Module usbserial not found.root@ct-router:~# wvdial t-mobile--> WvDial: Internet dialer version 1.61--> Cannot open /dev/ttyUSB2: No such device or address--> Cannot open /dev/ttyUSB2: No such device or address--> Cannot open /dev/ttyUSB2: No such device or addressroot@ct-router:~# --> WvDial: Internet dialer version 1.61-bash: --: command not foundroot@ct-router:~# --> Cannot open /dev/ttyUSB2: No such device or address-bash: --: command not foundroot@ct-router:~# --> Cannot open /dev/ttyUSB2: No such device or address-bash: --: command not foundroot@ct-router:~# --> Cannot open /dev/ttyUSB2: No such device or address-bash: --: command not foundroot@ct-router:~# --> WvDial: Internet dialer version 1.61-bash: --: command not foundroot@ct-router:~# --> Cannot open /dev/ttyUSB2: No such device or address-bash: --: command not foundroot@ct-router:~# --> Cannot open /dev/ttyUSB2: No such device or address-bash: --: command not foundroot@ct-router:~# --> Cannot open /dev/ttyUSB2: No such device or address-bash: --: command not found
Igor Posted June 14, 2015 Posted June 14, 2015 You should find three /dev/ttyUSB* devices directly after you plug E220 into a USB port. Do you have them? And how is working under Bananian? Kernel source is very similar, configuration looks o.k. ... BTW. Try with kernel 3.4.107 ... 4.x has issues.
dasgeraet Posted June 14, 2015 Author Posted June 14, 2015 Yes it is an E220 and he works under bananian 1501 but not under yours image and not under bananian 1504, ls /dev/tty/USB* No such file or directory i have make an test with bananian 1501 upgrade to 1504 install to sata and e220 umts. umts work wlan/hostap works but not stable under yours image the i think the hostap is stable and works good but not the umts stick. I have also two cubietrucks with yours jessie image and the work fine and i won´t all devices under your image i think you make the better work best wishes from germany
dasgeraet Posted June 15, 2015 Author Posted June 15, 2015 Test with older kernel root@lamobo:~# wvdial t-mobile--> WvDial: Internet dialer version 1.61--> Initializing modem.--> Sending: ATZATZOK--> Sending: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0OK--> Sending: AT+CGDCONT=1,"IP","internet.t-mobile","0.0.0.0", 0,0AT+CGDCONT=1,"IP","internet.t-mobile","0.0.0.0", 0,0OK--> Modem initialized.--> Sending: ATDT*99#--> Waiting for carrier.ATDT*99#CONNECT--> Carrier detected. Starting PPP immediately.--> Starting pppd at Fri Jan 1 01:13:00 2010--> Pid of pppd: 3719--> Using interface ppp0--> pppd: â–’â–’ â–’â–’[01][10]â–’â–’[01]--> pppd: â–’â–’ â–’â–’[01][10]â–’â–’[01]--> pppd: â–’â–’ â–’â–’[01][10]â–’â–’[01]--> pppd: â–’â–’ â–’â–’[01][10]â–’â–’[01]--> pppd: â–’â–’ â–’â–’[01][10]â–’â–’[01]--> pppd: â–’â–’ â–’â–’[01][10]â–’â–’[01]--> local IP address 10.51.78.212--> pppd: â–’â–’ â–’â–’[01][10]â–’â–’[01]--> remote IP address 10.64.64.64--> pppd: â–’â–’ â–’â–’[01][10]â–’â–’[01]--> primary DNS address 10.74.210.210--> pppd: â–’â–’ â–’â–’[01][10]â–’â–’[01]--> secondary DNS address 10.74.210.211--> pppd: â–’â–’ â–’â–’[01][10]â–’â–’[01]--> pppd: â–’â–’ â–’â–’[01][10]â–’â–’[01]--> Connect time 0.1 minutes.--> pppd: â–’â–’ â–’â–’[01][10]â–’â–’[01]--> pppd: â–’â–’ â–’â–’[01][10]â–’â–’[01]--> pppd: â–’â–’ â–’â–’[01][10]â–’â–’[01]--> Disconnecting at Fri Jan 1 01:13:06 2010--> The PPP daemon has died: A modem hung up the phone (exit code = 16)--> man pppd explains pppd error codes in more detail.--> Try again and look into /var/log/messages and the wvdial and pppd man pages for more information.--> Auto Reconnect will be attempted in 5 seconds--> Initializing modem.--> Sending: ATZATZOK--> Sending: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0OK--> Sending: AT+CGDCONT=1,"IP","internet.t-mobile","0.0.0.0", 0,0^CCaught signal 2: Attempting to exit gracefully...AT+CGDCONT=1,"IP","internet.t-mobile","0.0.0.0", 0,0OK--> Modem initialized.--> Disconnecting at Fri Jan 1 01:13:07 2010
Igor Posted June 15, 2015 Posted June 15, 2015 Test with older kernel You used my stock 3.4.107 image? http://mirror.igorpecovnik.com/kernel/4.0.5-lamobo-r1-next.tar Try this one ... recompiled with what was missing.
dasgeraet Posted June 15, 2015 Author Posted June 15, 2015 Lamobo-r1_Debian_3.1_jessie_4.0.5.raw first test locking good I make more test can you help him too http://forum.armbian.com/index.php/topic/73-ftdi-ft232-on-cubietruck/im think thats the same probleme
Igor Posted June 16, 2015 Posted June 16, 2015 I already add few other things which might be useful in this area. I think this kernel should help in that case too.
remsnet Posted June 20, 2015 Posted June 20, 2015 I already add few other things which might be useful in this area. I think this kernel should help in that case too. raised lib #66 issue , see https://github.com/igorpecovnik/lib/issues/66
