denni_isl Posted January 12, 2021 Posted January 12, 2021 2 hours ago, balbes150 said: u-boot works correctly and the system is started using extlinux.conf. See the output Remove this from the settings root=/dev/mmcblk1p2 rootfstype=vfat console=uart8250,mmio32,0xff1a0000 And show the full contents of the "extlinux.conf" file What exactly image (full image name) are you trying to run, what steps are you doing ? Thank you balbes150 This is the output from u-boot Spoiler U-Boot SPL 2021.01-rc4 (Dec 31 2020 - 11:50:40 +0000) Loading Environment from SPIFlash... OK Trying to boot from SPI cannot find image node 'atf_1': -1 U-Boot 2021.01-rc4 (Dec 31 2020 - 11:50:40 +0000) SoC: Rockchip rk3399 Reset cause: POR Model: Firefly ROC-RK3399-PC Mezzanine Board DRAM: 3.9 GiB PMIC: RK808 MMC: mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from SPIFlash... SF: Detected w25q128 with page size 256 ByB OK In: serial Out: serial Err: serial Model: Firefly ROC-RK3399-PC Mezzanine Board Net: Error: ethernet@fe300000 address not set. No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf 1438 bytes read in 5 ms (280.3 KiB/s) 1: Armbian Retrieving file: /uInitrd 9546946 bytes read in 410 ms (22.2 MiB/s) Retrieving file: /zImage 28162560 bytes read in 1198 ms (22.4 MiB/s) append: root=LABEL=ROOTFS rootflags=data=writeback rootwait rw console=tty0 no_0 Retrieving file: /dtb/rockchip/rk3399-roc-pc-mezzanine.dtb 58060 bytes read in 9 ms (6.2 MiB/s) Moving Image from 0x2080000 to 0x2200000, end=3dd0000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 9546882 Bytes = 9.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f1602000, end f1f1cc82 ... OK Loading Device Tree to 00000000f15f0000, end 00000000f16012cb ... OK Starting kernel ... And this is extlinux.conf Spoiler LABEL Armbian LINUX /zImage INITRD /uInitrd #LINUX /Image #INITRD /Initrd # rk-3399 #FDT /dtb/rockchip/rk3399-rock-pi-4b.dtb #FDT /dtb/rockchip/rk3399-nanopc-t4.dtb FDT /dtb/rockchip/rk3399-roc-pc-mezzanine.dtb APPEND root=LABEL=ROOTFS rootflags=data=writeback rootwait rw console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 #append earlycon=uart8250,mmio32,0xff1a0000 console=tty0 console=ttyS2,1500000 swiotlb=1 root=/dev/mmcblk1p1 rootwait rw rootfstype=vfat init=/sbin/init #APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=uart8250,mmio32,0xff1a0000 console=tty0 no_console_suspend consoleblank=0 loglevel=7 fsck.fix=yes fsck.repair=yes net.ifnames=0 # rk-3328 #FDT /dtb/rockchip/rk3328-roc-pc.dtb #FDT /dtb/rockchip/rk3328-box-trn9.dtb #FDT /dtb/rockchip/rk3328-box.dtb #APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=uart8250,mmio32,0xff130000 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 # aw h6 #FDT /dtb/allwinner/sun50i-h6-tanix-tx6.dtb #APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyS0,115200 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 video=HDMI-A-1:e #APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyS0,115200 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mem=2048M video=HDMI-A-1:e The image is - Armbian_20.11_Arm-64_focal_current_5.10.0-rc4.img ps. Have not studied extlinux yet https://wiki.syslinux.org/wiki/index.php?title=EXTLINUX
balbes150 Posted January 12, 2021 Posted January 12, 2021 16 минут назад, denni_isl сказал: This is the output from u-boot In this log, everything is fine, u-boot has performed its task correctly, and the kernel is running. What is the problem? 17 минут назад, denni_isl сказал: And this is extlinux.conf The content is correct, but you can simplify and remove what is not needed (not used) and leave only this LABEL Armbian LINUX /zImage INITRD /uInitrd FDT /dtb/rockchip/rk3399-roc-pc-mezzanine.dtb APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=uart8250,mmio32,0xff1a0000 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
denni_isl Posted January 12, 2021 Posted January 12, 2021 20 minutes ago, balbes150 said: In this log, everything is fine, u-boot has performed its task correctly, and the kernel is running. What is the problem? The content is correct, but you can simplify and remove what is not needed (not used) and leave only this LABEL Armbian LINUX /zImage INITRD /uInitrd FDT /dtb/rockchip/rk3399-roc-pc-mezzanine.dtb APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=uart8250,mmio32,0xff1a0000 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 It is still the same u-boot messages. When booting the roc-rk3399-pc-plus board, there is immediately red light and this message; Quote Trying to boot from SPI cannot find image node 'atf_1': -1 Maybe related to this issue from here https://github.com/OE4T/meta-tegra/issues/502 commented on Nov 24, 2020 @om26er fwiw, I have an overlay that puts a file in /boot/extlinux/extlinux.conf. As @madisongh mentioned cboot's handling of ext4 is pretty primitive so if you go this route in your do_install you'll want something like the below so cboot can read it ok dd if=/dev/zero of=./extlinux.conf bs=1 count=1 seek=4095 status=none ?
balbes150 Posted January 12, 2021 Posted January 12, 2021 1 минуту назад, denni_isl сказал: It is still the same u-boot messages. When booting the roc-rk3399-pc-plus board, there is immediately red light and this message; The error message can be ignored, u-boot starts the kernel correctly.
denni_isl Posted January 12, 2021 Posted January 12, 2021 1 minute ago, balbes150 said: The error message can be ignored, u-boot starts the kernel correctly. Somehow the kernel hangs on - Starting kernel ...
balbes150 Posted January 12, 2021 Posted January 12, 2021 3 минуты назад, denni_isl сказал: Somehow the kernel hangs on - Starting kernel ... The kernel does not hang, but works. Enable the full output log and you will see where the stop occurs. How long do you wait for the system to start (HDMI connected)?
denni_isl Posted January 12, 2021 Posted January 12, 2021 22 minutes ago, balbes150 said: The kernel does not hang, but works. Enable the full output log and you will see where the stop occurs. How long do you wait for the system to start (HDMI connected)? The HDMI output hangs at Starting the kernel.... And the indication light is constant red. How does one make the output more verbose in extlinux - can not see it here https://wiki.syslinux.org/wiki/index.php?title=Config ?
balbes150 Posted January 12, 2021 Posted January 12, 2021 20 минут назад, denni_isl сказал: How does one make the output more verbose in extlinux You need to find the right parameters for your model. APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=uart8250,mmio32,0xff1a0000 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 What exactly is your model, is there a link ?
RussianNeuroMancer Posted January 12, 2021 Posted January 12, 2021 39 minutes ago, denni_isl said: The HDMI output hangs at Starting the kernel.... And the indication light is constant red. How does one make the output more verbose in extlinux - can not see it here https://wiki.syslinux.org/wiki/index.php?title=Config ? Did you checked ssh? Could be something like this: I have similar issue, and ssh works for me, and even Xorg works.
denni_isl Posted January 12, 2021 Posted January 12, 2021 16 minutes ago, balbes150 said: You need to find the right parameters for your model. APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=uart8250,mmio32,0xff1a0000 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 What exactly is your model, is there a link ? Taking out ,0xff1a0000 did get the kernel further, now it stops at the yellow screen. The model is roc-rk3399-pc-plus (en.t-firefly.com).
denni_isl Posted January 12, 2021 Posted January 12, 2021 22 minutes ago, balbes150 said: You need to find the right parameters for your model. APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=uart8250,mmio32,0xff1a0000 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 What exactly is your model, is there a link ? Taking out ,0xff1a0000 did get the kernel further, now it stops at the yellow screen (still the red indication light). The model is roc-rk3399-pc-plus (en.t-firefly.com).
balbes150 Posted January 12, 2021 Posted January 12, 2021 13 минут назад, denni_isl сказал: Taking out ,0xff1a0000 did get the kernel further, now it stops at the yellow screen (still the red indication light). The model is roc-rk3399-pc-plus (en.t-firefly.com). Show the UART log
denni_isl Posted January 12, 2021 Posted January 12, 2021 15 minutes ago, balbes150 said: Show the UART log Spoiler CTRL-A Z for help | 1500000 8N1 | NOR | Minicom 2.7.1 | VT102 | Online 2:41 | ttyUSB0 steini@odroidn2:~$ sudo minicom -D /dev/ttyUSB0 [sudo] password for steini: Welcome to minicom 2.7.1 OPTIONS: I18n Compiled on Dec 23 2019, 02:06:26. Port /dev/ttyUSB0, 12:55:52 Press CTRL-A Z for help on special keys U-Boot TPL 2021.01-rc4 (Dec 31 2020 - 11:50:40) Trying to boot from BOOTROM Returning to boot ROM... U-Boot SPL 2021.01-rc4 (Dec 31 2020 - 11:50:40 +0000) Loading Environment from SPIFlash... OK Trying to boot from SPI cannot find image node 'atf_1': -1 U-Boot 2021.01-rc4 (Dec 31 2020 - 11:50:40 +0000) SoC: Rockchip rk3399 Reset cause: POR Model: Firefly ROC-RK3399-PC Mezzanine Board DRAM: 3.9 GiB PMIC: RK808 MMC: mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from SPIFlash... SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB OK In: serial Out: vidconsole Err: vidconsole Model: Firefly ROC-RK3399-PC Mezzanine Board Net: Error: ethernet@fe300000 address not set. No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf 258 bytes read in 5 ms (49.8 KiB/s) 1: Armbian Retrieving file: /uInitrd 9546946 bytes read in 410 ms (22.2 MiB/s) Retrieving file: /zImage 28162560 bytes read in 1198 ms (22.4 MiB/s) append: root=LABEL=ROOTFS rootflags=data=writeback rw console=uart8250,mmio32 console=tty0 no_console_suspend consoleblank=0 fsck.fi Retrieving file: /dtb/rockchip/rk3399-roc-pc-mezzanine.dtb 58060 bytes read in 8 ms (6.9 MiB/s) Moving Image from 0x2080000 to 0x2200000, end=3dd0000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 9546882 Bytes = 9.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f1602000, end f1f1cc82 ... OK Loading Device Tree to 00000000f15f0000, end 00000000f16012cb ... OK Starting kernel ... CTRL-A Z for help | 1500000 8N1 | NOR | Minicom 2.7.1 | VT102 | Online 0:0 | ttyUSB0
balbes150 Posted January 12, 2021 Posted January 12, 2021 30 минут назад, denni_isl сказал: Taking out ,0xff1a0000 Have you removed this parameter and not replaced it with anything ? Show the contents of extlinux.conf
denni_isl Posted January 12, 2021 Posted January 12, 2021 1 minute ago, balbes150 said: Have you removed this parameter and not replaced it with anything ? Show the contents of extlinux.conf Quote LABEL Armbian LINUX /zImage INITRD /uInitrd FDT /dtb/rockchip/rk3399-roc-pc-mezzanine.dtb APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=uart8250,mmio32 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
Panzerknacker Posted January 12, 2021 Posted January 12, 2021 earlycon=uart8250,mmio32,0xff1a0000 console=tty1 console=ttyS2,1500000
balbes150 Posted January 12, 2021 Posted January 12, 2021 Is this your model ? http://wiki.t-firefly.com/en/ROC-RK3399-PC-PLUS/debug.html I wrote about changing the value. If you delete a parameter, then you need to delete it all. console=uart8250,mmio32,0xff1a0000
denni_isl Posted January 12, 2021 Posted January 12, 2021 19 minutes ago, balbes150 said: Is this your model ? http://wiki.t-firefly.com/en/ROC-RK3399-PC-PLUS/debug.html I wrote about changing the value. If you delete a parameter, then you need to delete it all. console=uart8250,mmio32,0xff1a0000 Yes, this is the board. Did try bot suggestions balbes150 and PanzerKnacker Quote LABEL Armbian LINUX /zImage INITRD /uInitrd # # earlycon=uart8250,mmio32,0xff1a0000 console=tty1 console=ttyS2,1500000 FDT /dtb/rockchip/rk3399-roc-pc-mezzanine.dtb APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 Can not see it on the network with sudo nmap -sn 192.168.1.0/24
balbes150 Posted January 12, 2021 Posted January 12, 2021 4 минуты назад, denni_isl сказал: Did try bot suggestions APPEND root=LABEL=ROOTFS rootflags=data=writeback rw earlycon=uart8250,mmio32,0xff1a0000 console=tty1 console=ttyS2,1500000 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
denni_isl Posted January 12, 2021 Posted January 12, 2021 19 minutes ago, balbes150 said: APPEND root=LABEL=ROOTFS rootflags=data=writeback rw earlycon=uart8250,mmio32,0xff1a0000 console=tty1 console=ttyS2,1500000 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 Quote 1: Armbian Retrieving file: /uInitrd 9546946 bytes read in 410 ms (22.2 MiB/s) Retrieving file: /zImage 28162560 bytes read in 1199 ms (22.4 MiB/s) append: root=LABEL=ROOTFS rootflags=data=writeback rw earlycon=uart8250,mmio32,0xff1a0000 console=tty1 console=ttyS2,1500000 no_cons Retrieving file: /dtb/rockchip/rk3399-roc-pc-mezzanine.dtb Failed to load '/dtb/rockchip/rk3399-roc-pc-mezzanine.dtb ' Skipping Armbian for failure retrieving fdt SCRIPT FAILED: continuing... 58060 bytes read in 9 ms (6.2 MiB/s) and extlinux.conf Quote LABEL Armbian LINUX /zImage INITRD /uInitrd FDT /dtb/rockchip/rk3399-roc-pc-mezzanine.dtb APPEND root=LABEL=ROOTFS rootflags=data=writeback rw earlycon=uart8250,mmio32,0xff1a0000 console=tty1 console=ttyS2,1500000 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 # earlycon=uart8250,mmio32,0xff1a0000 console=tty1 console=ttyS2,1500000 # APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 The boot directory (/BOOT partition) Quote steini@odroidn2:/media/steini/BOOT$ ls armbianEnv.txt Initrd armbianEnv.txt~ Initrd-5.10.4 armbian_first_run.txt.template initrd.img-5.10.0-rc4-arm-64 boot.bmp rk3399-roc-pc.dtb config-5.10.0-rc4-arm-64 rk3399-roc-pc.dtb-5.10.4 config-5.10.4 rk3399-roc-pc-mezzanine.dtb dtb rk3399-roc-pc-mezzanine.dtb-5.10.4 extlinux System.map-5.10.0-rc4-arm-64 Image uInitrd Image-5.10.4 zImage steini@odroidn2:/media/steini/BOOT$
Panzerknacker Posted January 12, 2021 Posted January 12, 2021 17 minutes ago, denni_isl said: Failed to load '/dtb/rockchip/rk3399-roc-pc-mezzanine.dtb ' Right path?
denni_isl Posted January 12, 2021 Posted January 12, 2021 1 minute ago, Panzerknacker said: Right path? yes
balbes150 Posted January 12, 2021 Posted January 12, 2021 18 минут назад, denni_isl сказал: Failed to load '/dtb/rockchip/rk3399-roc-pc-mezzanine.dtb ' Check for the file at the specified path. /dtb/rockchip/rk3399-roc-pc-mezzanine.dtb I see you have dragged the necessary files to the root of the /BOOT partition (this is not correct)
balbes150 Posted January 12, 2021 Posted January 12, 2021 To get rid of all the tails that are now on your SD card, I recommend doing a clean check. Download the image from the link, unzip it and burn it to the SD card. Do not change anything on the SD card, connect to the device and check the launch. https://users.armbian.com/balbes150/firefly_station_p1/ Model Fyrefly Station P1 = ROC-RK3399-pc-plus + eMMC module. 2
denni_isl Posted January 12, 2021 Posted January 12, 2021 5 hours ago, balbes150 said: To get rid of all the tails that are now on your SD card, I recommend doing a clean check. Download the image from the link, unzip it and burn it to the SD card. Do not change anything on the SD card, connect to the device and check the launch. https://users.armbian.com/balbes150/firefly_station_p1/ Model Fyrefly Station P1 = ROC-RK3399-pc-plus + eMMC module. Armbian_21.02.0-trunk_Station-p1_bullseye_current_5.9.16_xfce_desktop.img.xz = yellow screen (etcher) Armbian_21.02.0-trunk_Station-p1_buster_current_5.9.16_xfce_desktop.img.xz = yellow screen (etcher) Armbian_21.02.0-trunk_Station-p1_buster_current_5.10.5_xfce_desktop.img.xz = Starting kernel ... (etcher) Armbian_20.11.6_Station-p1_bullseye_current_5.9.14.img = yellow screen (dd)
denni_isl Posted January 13, 2021 Posted January 13, 2021 8 hours ago, balbes150 said: Where is the UART log ? Armbian 20.11.6 Bullseye - armbianEnv.txt - verbosity=7 Quote steini@odroidn2:~$ sudo minicom -D /dev/ttyUSB0 [sudo] password for steini: Welcome to minicom 2.7.1 OPTIONS: I18n Compiled on Dec 23 2019, 02:06:26. Port /dev/ttyUSB0, 16:12:38 Press CTRL-A Z for help on special keys U-Boot TPL 2021.01-rc4 (Dec 31 2020 - 11:50:40) Trying to boot from BOOTROM Returning to boot ROM... U-Boot SPL 2021.01-rc4 (Dec 31 2020 - 11:50:40 +0000) Loading Environment from SPIFlash... OK Trying to boot from SPI cannot find image node 'atf_1': -1 U-Boot 2021.01-rc4 (Dec 31 2020 - 11:50:40 +0000) SoC: Rockchip rk3399 Reset cause: POR Model: Firefly ROC-RK3399-PC Mezzanine Board DRAM: 3.9 GiB PMIC: RK808 MMC: mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from SPIFlash... SF: Detected w25q128 with B OK In: serial Out: vidconsole Err: vidconsole Model: Firefly ROC-RK3399-PC Mezzanine Board Net: Error: ethernet@fe300000 address not set. No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3185 bytes read in 5 ms (622.1 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 162 bytes read in 4 ms (39.1 KiB/s) 14017362 bytes read in 602 ms (22.2 MiB/s) 27507200 bytes read in 1167 ms (22.5 MiB/s) 77135 bytes read in 12 ms (6.1 MiB/s) 2698 bytes read in 7 ms (376 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Moving Image from 0x2080000 to 0x2200000, end=3cd0000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 14017298 Bytes = 13.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f11bf000, end f1f1d312 ... OK Loading Device Tree to 00000000f1143000, end 00000000f11beffK Starting kernel ...
balbes150 Posted January 14, 2021 Posted January 14, 2021 16 часов назад, denni_isl сказал: Armbian 20.11.6 Bullseye This is the official version, look for how to enable output to the UART console in it. What is connected to the HDMI output and how ? Describe in more detail the configuration of the hardware you are using. I know that P1 (board roc-rk3399-pc-plus) users have no problem running images for P1.
denni_isl Posted January 14, 2021 Posted January 14, 2021 1 hour ago, balbes150 said: This is the official version, look for how to enable output to the UART console in it. What is connected to the HDMI output and how ? Describe in more detail the configuration of the hardware you are using. I know that P1 (board roc-rk3399-pc-plus) users have no problem running images for P1. Using the 4 pin debug (close to usb-C) on the board connected to usb adapter (not the GPIO pins) connected to odroid-n2. Are you talking about more options through the GPIO pins and a USB adapter like this one https://www.aliexpress.com/item/1005001589090572.html?spm=a2g0o.productlist.0.0.7a3238aeXZN4i6&algo_pvid=6ca99289-4fc4-4f1a-b243-e1ced9b7863a&algo_expid=6ca99289-4fc4-4f1a-b243-e1ced9b7863a-17&btsid=0b0a555616106170618963449e6cd7&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_ Did fallow fallowing instructions from page 8 on this tread and that must have spoiled the SPI chip somehow, though u-boot seems to be working except the kernel is not functional. When one make mistakes is when he/she learn - Quote Posted December 23, 2020 Boot from SPI directly to NVME works: Latest U-Boot v2021.01-rc4 + this patch: rockchip: roc-pc-rk3399: fix boot from SPI flash on spi1 https://patchwork.kernel.org/project/linux-rockchip/list/?series=403611 To build uboot on roc-pc: make roc-pc-mezzanine-rk3399_defconfig make -j6 ./tools/mkimage -n rk3399 -T rkspi -d tpl/u-boot-tpl.bin:spl/u-boot-spl.bin idbloader-spi.img To deploy uboot on spi: dd if=idbloader-spi.img of=spi.img (#0x60000 = 393216 = 4096 * 96) dd if=u-boot.itb of=spi.img bs=4096 seek=96 flashcp -v spi.img /dev/mtd0 in U-Boot: edit boot_targets to have nvme0 as first entry On NVME drive (e.g. Samsung 970EVOPlus): /boot/extlinux/extlinux.conf: label mainline-kernel kernel /boot/Image initrd /boot/Initrd # fdt /rk3399-roc-pc.dtb fdt /boot/rk3399-roc-pc-mezzanine.dtb append earlycon=uart8250,mmio32,0xff1a0000 console=tty1 console=ttyS2,1500000 swiotlb=1 root=/dev/nvme0n1p1 rootwait rw rootfstype=ext4 init=/sbin/init ls /boot: Image (Image-5.10.0-next-20201223) Initrd (Initrd-5.10.0-next-20201223) rk3399-roc-pc-mezzanine.dtb (rk3399-roc-pc-mezzanine.dtb-5.10.0-next-20201223) Kernel built on roc-pc: Latest linux-next make -j6 make modules_install kernelversion=`cat ./include/config/kernel.release` cp .config /boot/config-$kernelversion mkinitramfs -c gzip -o ./initramfs-$kernelversion $kernelversion mkimage -A arm64 -O linux -T ramdisk -C none -a 0 -e 0 -n initramfs -d ./initramfs-$kernelversion ./Initrd cp arch/arm64/boot/Image /boot/Image cp Initrd /boot cp arch/arm64/boot/dts/rockchip/rk3399-roc-pc.dtb /boot cp arch/arm64/boot/dts/rockchip/rk3399-roc-pc-mezzanine.dtb /boot cp arch/arm64/boot/Image /boot/Image-$kernelversion cp Initrd /boot/Initrd-$kernelversion cp arch/arm64/boot/dts/rockchip/rk3399-roc-pc.dtb /boot/rk3399-roc-pc.dtb-$kernelversion cp arch/arm64/boot/dts/rockchip/rk3399-roc-pc-mezzanine.dtb /boot/rk3399-roc-pc-mezzanine.dtb-$kernelversion example .config:
Panzerknacker Posted January 14, 2021 Posted January 14, 2021 21 minutes ago, denni_isl said: u-boot seems to be working Therefore I doubt that the SPI chip is spoiled.
