Levente Nemeth Posted July 31, 2018 Posted July 31, 2018 Hi all, I noticed that my OrangePi freezes after 4-5 days of uptime. Something happens (usually around 06:00) when my script simply stop working (no more log entries) and then reboots after ~12 hours (exactly at 13:17 in all occasions). Finally the orange pi becomes unresponsive and heats up to 85-90 degree Celsius. I've checked CPU temperature, disk and memory usage but haven't found anything... I'm a beginner in armbian and completely having no idea what could be the root casue. Could you please help? I've executed a diagnostics you can find it here: http://ix.io/1iQc Related syslog entries: Jul 31 06:10:01 localhost CRON[20175]: (root) CMD (/root/utils/cputemp.sh) Jul 31 06:10:01 localhost CRON[20176]: (root) CMD (free -m > /root/memory.log) Jul 31 06:10:01 localhost CRON[20178]: (root) CMD (df -h > /root/df.log) Jul 31 06:15:01 localhost CRON[20268]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1) Jul 31 06:17:01 localhost CRON[20307]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 31 06:20:01 localhost CRON[20369]: (root) CMD (/root/utils/cputemp.sh) Jul 31 06:20:01 localhost CRON[20370]: (root) CMD (free -m > /root/memory.log) Jul 31 06:20:01 localhost CRON[20371]: (root) CMD (df -h > /root/df.log) Jul 31 06:25:01 localhost CRON[20555]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )) Jul 31 06:25:01 localhost CRON[20554]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1) Jul 31 13:17:05 localhost systemd-modules-load[216]: Inserted module 'g_serial' Jul 31 13:17:05 localhost kernel: [ 0.000000] Booting Linux on physical CPU 0x0 Jul 31 13:17:05 localhost kernel: [ 0.000000] Linux version 4.14.14-sunxi (root@xeon) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 SMP Thu Jan 25 12:20:57 CET 2018 Jul 31 13:17:05 localhost kernel: [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d Jul 31 13:17:05 localhost kernel: [ 0.000000] CPU: div instructions available: patching division code Jul 31 13:17:05 localhost systemd-udevd[323]: link_config: could not get ethtool features for eth0 Jul 31 13:17:05 localhost kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache Jul 31 13:17:05 localhost fake-hwclock[212]: Tue Jul 31 11:17:01 UTC 2018 Jul 31 13:17:05 localhost systemd-udevd[323]: Could not set offload features of eth0: Device or resource busy Jul 31 13:17:05 localhost kernel: [ 0.000000] OF: fdt: Machine model: Xunlong Orange Pi Zero Jul 31 13:17:05 localhost kernel: [ 0.000000] Memory policy: Data cache writealloc Jul 31 13:17:05 localhost keyboard-setup.sh[229]: gzip: /etc/console-setup/cached_UTF-8_del.kmap.gz: unexpected end of file Jul 31 13:17:05 localhost kernel: [ 0.000000] Reserved memory: created CMA memory pool at 0x5bc00000, size 64 MiB Jul 31 13:17:05 localhost kernel: [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool Jul 31 13:17:05 localhost kernel: [ 0.000000] On node 0 totalpages: 131072 Jul 31 13:17:05 localhost kernel: [ 0.000000] free_area_init_node: node 0, pgdat c0dd8b00, node_mem_map db780000 Jul 31 13:17:05 localhost kernel: [ 0.000000] Normal zone: 1152 pages used for memmap Jul 31 13:17:05 localhost kernel: [ 0.000000] Normal zone: 0 pages reserved Jul 31 13:17:05 localhost kernel: [ 0.000000] Normal zone: 131072 pages, LIFO batch:31 Jul 31 13:17:05 localhost resolvconf[246]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /etc/resolvconf/run/resolv.conf Jul 31 13:17:05 localhost kernel: [ 0.000000] psci: probing for conduit method from DT. Jul 31 13:17:05 localhost kernel: [ 0.000000] psci: Using PSCI v0.1 Function IDs from DT Jul 31 13:17:05 localhost kernel: [ 0.000000] random: fast init done Jul 31 13:17:05 localhost kernel: [ 0.000000] percpu: Embedded 17 pages/cpu @dff5a000 s39884 r8192 d21556 u69632 Jul 31 13:17:05 localhost kernel: [ 0.000000] pcpu-alloc: s39884 r8192 d21556 u69632 alloc=17*4096 Jul 31 13:17:05 localhost log2ram[295]: sending incremental file list Jul 31 13:17:05 localhost kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 Jul 31 13:17:05 localhost kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920 Jul 31 13:17:05 localhost log2ram[295]: ./ Jul 31 13:17:05 localhost kernel: [ 0.000000] Kernel command line: root=UUID=a2c25aee-d15d-4aa7-8f41-ab6bb511776f rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=378fc799-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 Jul 31 13:17:05 localhost kernel: [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) Jul 31 13:17:05 localhost kernel: [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Jul 31 13:17:05 localhost log2ram[295]: alternatives.log Jul 31 13:17:05 localhost kernel: [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Jul 31 13:17:05 localhost kernel: [ 0.000000] allocated 524288 bytes of page_ext Jul 31 13:17:05 localhost kernel: [ 0.000000] Memory: 433616K/524288K available (8192K kernel code, 945K rwdata, 2340K rodata, 1024K init, 346K bss, 25136K reserved, 65536K cma-reserved, 0K highmem) Jul 31 13:17:05 localhost kernel: [ 0.000000] Virtual kernel memory layout: Jul 31 13:17:05 localhost kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) Jul 31 13:17:05 localhost log2ram[295]: alternatives.log.1 Jul 31 13:17:05 localhost kernel: [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) Jul 31 13:17:05 localhost kernel: [ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB) Jul 31 13:17:05 localhost log2ram[295]: alternatives.log.2.gz Jul 31 13:17:05 localhost kernel: [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) Jul 31 13:17:05 localhost kernel: [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) Jul 31 13:17:05 localhost kernel: [ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB) Jul 31 13:17:05 localhost kernel: [ 0.000000] .text : 0xc0008000 - 0xc0900000 (9184 kB) Jul 31 13:17:05 localhost log2ram[295]: aptitude Jul 31 13:17:05 localhost kernel: [ 0.000000] .init : 0xc0c00000 - 0xc0d00000 (1024 kB) Jul 31 13:17:05 localhost kernel: [ 0.000000] .data : 0xc0d00000 - 0xc0dec59c ( 946 kB) Jul 31 13:17:05 localhost kernel: [ 0.000000] .bss : 0xc0df5e00 - 0xc0e4c61c ( 347 kB) Jul 31 13:17:05 localhost log2ram[295]: aptitude.1.gz Jul 31 13:17:05 localhost kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 Jul 31 13:17:05 localhost kernel: [ 0.000000] ftrace: allocating 36979 entries in 73 pages Jul 31 13:17:05 localhost kernel: [ 0.000000] Hierarchical RCU implementation. Jul 31 13:17:05 localhost kernel: [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 Jul 31 13:17:05 localhost kernel: [ 0.000000] GIC: Using split EOI/Deactivate mode Jul 31 13:17:05 localhost log2ram[295]: armhwinfo.log Jul 31 13:17:05 localhost kernel: [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns Jul 31 13:17:05 localhost kernel: [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). Jul 31 13:17:05 localhost log2ram[295]: armhwinfo.log.1.gz Jul 31 13:17:05 localhost kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns Jul 31 13:17:05 localhost kernel: [ 0.000010] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns Jul 31 13:17:05 localhost kernel: [ 0.000026] Switching to timer-based delay loop, resolution 41ns Jul 31 13:17:05 localhost kernel: [ 0.000366] Console: colour dummy device 80x30 Jul 31 13:17:05 localhost log2ram[295]: armhwinfo.log.10.gz Jul 31 13:17:05 localhost kernel: [ 0.000389] console [tty1] enabled Jul 31 13:17:05 localhost kernel: [ 0.000434] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) Jul 31 13:17:05 localhost kernel: [ 0.000453] pid_max: default: 32768 minimum: 301 Jul 31 13:17:05 localhost kernel: [ 0.000793] Security Framework initialized Jul 31 13:17:05 localhost log2ram[295]: armhwinfo.log.2.gz Jul 31 13:17:05 localhost kernel: [ 0.000810] AppArmor: AppArmor disabled by boot time parameter Jul 31 13:17:05 localhost kernel: [ 0.000919] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) Jul 31 13:17:05 localhost log2ram[295]: armhwinfo.log.3.gz Jul 31 13:17:05 localhost kernel: [ 0.000934] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) Jul 31 13:17:05 localhost kernel: [ 0.002306] CPU: Testing write buffer coherency: ok Jul 31 13:17:05 localhost kernel: [ 0.002891] /cpus/cpu@0 missing clock-frequency property Jul 31 13:17:05 localhost kernel: [ 0.002931] /cpus/cpu@1 missing clock-frequency property Jul 31 13:17:05 localhost kernel: [ 0.002969] /cpus/cpu@2 missing clock-frequency property Jul 31 13:17:05 localhost log2ram[295]: armhwinfo.log.4.gz Jul 31 13:17:05 localhost kernel: [ 0.003008] /cpus/cpu@3 missing clock-frequency property Jul 31 13:17:05 localhost kernel: [ 0.003026] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 Jul 31 13:17:05 localhost log2ram[295]: armhwinfo.log.5.gz Jul 31 13:17:05 localhost kernel: [ 0.003652] Setting up static identity map for 0x40100000 - 0x40100054 Jul 31 13:17:05 localhost kernel: [ 0.003842] Hierarchical SRCU implementation. Jul 31 13:17:05 localhost kernel: [ 0.005117] smp: Bringing up secondary CPUs ... Jul 31 13:17:05 localhost kernel: [ 0.016206] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 Jul 31 13:17:05 localhost kernel: [ 0.027434] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 Jul 31 13:17:05 localhost log2ram[295]: armhwinfo.log.6.gz Jul 31 13:17:05 localhost kernel: [ 0.038591] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 Jul 31 13:17:05 localhost kernel: [ 0.038745] smp: Brought up 1 node, 4 CPUs Jul 31 13:17:05 localhost kernel: [ 0.038759] SMP: Total of 4 processors activated (192.00 BogoMIPS). Jul 31 13:17:05 localhost log2ram[295]: armhwinfo.log.7.gz Jul 31 13:17:05 localhost kernel: [ 0.038766] CPU: All CPU(s) started in HYP mode. Jul 31 13:17:05 localhost kernel: [ 0.038770] CPU: Virtualization extensions available. Jul 31 13:17:05 localhost kernel: [ 0.040382] devtmpfs: initialized Jul 31 13:17:05 localhost kernel: [ 0.053683] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 Jul 31 13:17:05 localhost kernel: [ 0.054075] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns Jul 31 13:17:05 localhost kernel: [ 0.054102] futex hash table entries: 1024 (order: 4, 65536 bytes) Jul 31 13:17:05 localhost log2ram[295]: armhwinfo.log.8.gz Jul 31 13:17:05 localhost kernel: [ 0.058984] xor: measuring software checksum speed Jul 31 13:17:05 localhost kernel: [ 0.158446] arm4regs : 598.000 MB/sec Jul 31 13:17:05 localhost log2ram[295]: armhwinfo.log.9.gz Jul 31 13:17:05 localhost kernel: [ 0.258565] 8regs : 356.400 MB/sec Jul 31 13:17:05 localhost kernel: [ 0.358687] 32regs : 364.800 MB/sec Jul 31 13:17:05 localhost kernel: [ 0.458809] neon : 605.600 MB/sec Jul 31 13:17:05 localhost kernel: [ 0.458817] xor: using function: neon (605.600 MB/sec) Jul 31 13:17:05 localhost kernel: [ 0.458964] pinctrl core: initialized pinctrl subsystem Jul 31 13:17:05 localhost log2ram[295]: auth.log Jul 31 13:17:05 localhost kernel: [ 0.460517] NET: Registered protocol family 16 Jul 31 13:17:05 localhost kernel: [ 0.464739] DMA: preallocated 2048 KiB pool for atomic coherent allocations Jul 31 13:17:05 localhost kernel: [ 0.466309] cpuidle: using governor ladder Jul 31 13:17:05 localhost log2ram[295]: auth.log.1 Jul 31 13:17:05 localhost kernel: [ 0.466366] cpuidle: using governor menu Jul 31 13:17:05 localhost kernel: [ 0.468158] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. Jul 31 13:17:05 localhost kernel: [ 0.468167] hw-breakpoint: maximum watchpoint size is 8 bytes. Jul 31 13:17:05 localhost log2ram[295]: auth.log.2.gz Jul 31 13:17:05 localhost kernel: [ 0.659598] raid6: int32x1 gen() 90 MB/s Jul 31 13:17:05 localhost kernel: [ 0.829630] raid6: int32x1 xor() 76 MB/s Jul 31 13:17:05 localhost kernel: [ 0.999658] raid6: int32x2 gen() 121 MB/s Jul 31 13:17:05 localhost kernel: [ 1.169815] raid6: int32x2 xor() 92 MB/s Jul 31 13:17:05 localhost log2ram[295]: auth.log.3.gz Jul 31 13:17:05 localhost kernel: [ 1.339917] raid6: int32x4 gen() 123 MB/s Jul 31 13:17:05 localhost kernel: [ 1.510390] raid6: int32x4 xor() 91 MB/s Jul 31 13:17:05 localhost log2ram[295]: auth.log.4.gz Jul 31 13:17:05 localhost log2ram[295]: bootstrap.log Jul 31 13:17:05 localhost log2ram[295]: btmp Jul 31 13:17:05 localhost log2ram[295]: btmp.1 Jul 31 13:17:05 localhost log2ram[295]: cputemp.log Jul 31 13:17:05 localhost log2ram[295]: daemon.log Jul 31 13:17:05 localhost log2ram[295]: daemon.log.1 Jul 31 13:17:05 localhost log2ram[295]: daemon.log.2.gz Jul 31 13:17:05 localhost log2ram[295]: daemon.log.3.gz Jul 31 13:17:05 localhost log2ram[295]: daemon.log.4.gz Jul 31 13:17:05 localhost log2ram[295]: debug Jul 31 13:17:05 localhost log2ram[295]: debug.1 Jul 31 13:17:05 localhost log2ram[295]: debug.2.gz Jul 31 13:17:05 localhost log2ram[295]: debug.3.gz Jul 31 13:17:05 localhost log2ram[295]: debug.4.gz Jul 31 13:17:05 localhost log2ram[295]: dpkg.log Jul 31 13:17:05 localhost log2ram[295]: dpkg.log.1 Jul 31 13:17:05 localhost log2ram[295]: dpkg.log.2.gz Jul 31 13:17:05 localhost log2ram[295]: fail2ban.log Jul 31 13:17:05 localhost log2ram[295]: fail2ban.log.1 Jul 31 13:17:05 localhost log2ram[295]: fail2ban.log.2.gz Jul 31 13:17:05 localhost log2ram[295]: fail2ban.log.3.gz Jul 31 13:17:05 localhost log2ram[295]: fail2ban.log.4.gz Jul 31 13:17:05 localhost log2ram[295]: faillog Jul 31 13:17:05 localhost log2ram[295]: kern.log Jul 31 13:17:05 localhost log2ram[295]: kern.log.1 Jul 31 13:17:05 localhost log2ram[295]: kern.log.2.gz Jul 31 13:17:05 localhost log2ram[295]: kern.log.3.gz Jul 31 13:17:05 localhost log2ram[295]: kern.log.4.gz Jul 31 13:17:05 localhost log2ram[295]: lastlog Jul 31 13:17:05 localhost log2ram[295]: messages Jul 31 13:17:05 localhost log2ram[295]: messages.1 Jul 31 13:17:05 localhost log2ram[295]: messages.2.gz Jul 31 13:17:05 localhost log2ram[295]: messages.3.gz Jul 31 13:17:05 localhost log2ram[295]: messages.4.gz Jul 31 13:17:05 localhost log2ram[295]: pablo.log Jul 31 13:17:05 localhost log2ram[295]: pablo.log.1 Jul 31 13:17:05 localhost log2ram[295]: syslog Jul 31 13:17:05 localhost log2ram[295]: syslog.1 Jul 31 13:17:05 localhost log2ram[295]: syslog.2.gz Jul 31 13:17:05 localhost log2ram[295]: syslog.3.gz Jul 31 13:17:05 localhost log2ram[295]: syslog.4.gz Jul 31 13:17:05 localhost log2ram[295]: syslog.5.gz Jul 31 13:17:05 localhost log2ram[295]: syslog.6.gz Jul 31 13:17:05 localhost log2ram[295]: syslog.7.gz Jul 31 13:17:05 localhost log2ram[295]: user.log Jul 31 13:17:05 localhost log2ram[295]: user.log.1 Jul 31 13:17:05 localhost log2ram[295]: user.log.2.gz Jul 31 13:17:05 localhost log2ram[295]: user.log.3.gz Jul 31 13:17:05 localhost log2ram[295]: user.log.4.gz Jul 31 13:17:05 localhost log2ram[295]: wtmp Jul 31 13:17:05 localhost log2ram[295]: wtmp.1 Jul 31 13:17:05 localhost log2ram[295]: apache2/ Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log.1 Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log.10.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log.11.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log.12.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log.13.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log.14.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log.2.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log.3.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log.4.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log.5.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log.6.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log.7.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log.8.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/access.log.9.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log.1 Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log.10.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log.11.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log.12.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log.13.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log.14.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log.2.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log.3.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log.4.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log.5.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log.6.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log.7.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log.8.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/error.log.9.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/other_vhosts_access.log Jul 31 13:17:05 localhost log2ram[295]: apache2/other_vhosts_access.log.1 Jul 31 13:17:05 localhost log2ram[295]: apache2/other_vhosts_access.log.10.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/other_vhosts_access.log.2.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/other_vhosts_access.log.3.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/other_vhosts_access.log.4.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/other_vhosts_access.log.5.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/other_vhosts_access.log.6.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/other_vhosts_access.log.7.gz Jul 31 13:17:05 localhost systemd[1]: Starting Flush Journal to Persistent Storage... Jul 31 13:17:05 localhost log2ram[295]: apache2/other_vhosts_access.log.8.gz Jul 31 13:17:05 localhost log2ram[295]: apache2/other_vhosts_access.log.9.gz Jul 31 13:17:05 localhost log2ram[295]: apt/ Jul 31 13:17:05 localhost log2ram[295]: apt/eipp.log.xz Jul 31 13:17:05 localhost log2ram[295]: apt/history.log Jul 31 13:17:05 localhost log2ram[295]: apt/history.log.1.gz Jul 31 13:17:05 localhost log2ram[295]: apt/history.log.2.gz Jul 31 13:17:05 localhost log2ram[295]: apt/term.log Jul 31 13:17:05 localhost log2ram[295]: apt/term.log.1.gz Jul 31 13:17:05 localhost log2ram[295]: apt/term.log.2.gz Jul 31 13:17:05 localhost log2ram[295]: dbconfig-common/ Jul 31 13:17:05 localhost log2ram[295]: dbconfig-common/dbc.log Jul 31 13:17:05 localhost log2ram[295]: dbconfig-common/dbc.log.1 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/ Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.1 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.10 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.100 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.101 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.102 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.103 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.104 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.105 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.106 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.107 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.108 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.109 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.11 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.110 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.111 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.112 Jul 31 13:17:05 localhost kernel: [ 1.680785] raid6: int32x8 gen() 117 MB/s Jul 31 13:17:05 localhost kernel: [ 1.850811] raid6: int32x8 xor() 82 MB/s Jul 31 13:17:05 localhost kernel: [ 2.020757] raid6: neonx1 gen() 235 MB/s Jul 31 13:17:05 localhost kernel: [ 2.190863] raid6: neonx1 xor() 219 MB/s Jul 31 13:17:05 localhost kernel: [ 2.361104] raid6: neonx2 gen() 316 MB/s Jul 31 13:17:05 localhost kernel: [ 2.531289] raid6: neonx2 xor() 283 MB/s Jul 31 13:17:05 localhost kernel: [ 2.701462] raid6: neonx4 gen() 380 MB/s Jul 31 13:17:05 localhost kernel: [ 2.871615] raid6: neonx4 xor() 318 MB/s Jul 31 13:17:05 localhost kernel: [ 3.041840] raid6: neonx8 gen() 341 MB/s Jul 31 13:17:05 localhost kernel: [ 3.212008] raid6: neonx8 xor() 288 MB/s Jul 31 13:17:05 localhost kernel: [ 3.212015] raid6: using algorithm neonx4 gen() 380 MB/s Jul 31 13:17:05 localhost kernel: [ 3.212021] raid6: .... xor() 318 MB/s, rmw enabled Jul 31 13:17:05 localhost kernel: [ 3.212028] raid6: using neon recovery algorithm Jul 31 13:17:05 localhost kernel: [ 3.214889] SCSI subsystem initialized Jul 31 13:17:05 localhost kernel: [ 3.215226] libata version 3.00 loaded. Jul 31 13:17:05 localhost kernel: [ 3.215578] usbcore: registered new interface driver usbfs Jul 31 13:17:05 localhost kernel: [ 3.215652] usbcore: registered new interface driver hub Jul 31 13:17:05 localhost kernel: [ 3.215775] usbcore: registered new device driver usb Jul 31 13:17:05 localhost kernel: [ 3.216080] media: Linux media interface: v0.10 Jul 31 13:17:05 localhost kernel: [ 3.216136] Linux video capture interface: v2.00 Jul 31 13:17:05 localhost kernel: [ 3.216245] pps_core: LinuxPPS API ver. 1 registered Jul 31 13:17:05 localhost kernel: [ 3.216253] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> Jul 31 13:17:05 localhost kernel: [ 3.216282] PTP clock support registered Jul 31 13:17:05 localhost kernel: [ 3.218737] clocksource: Switched to clocksource arch_sys_counter Jul 31 13:17:05 localhost kernel: [ 3.409226] VFS: Disk quotas dquot_6.6.0 Jul 31 13:17:05 localhost kernel: [ 3.409371] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Jul 31 13:17:05 localhost kernel: [ 3.423642] NET: Registered protocol family 2 Jul 31 13:17:05 localhost kernel: [ 3.424701] TCP established hash table entries: 4096 (order: 2, 16384 bytes) Jul 31 13:17:05 localhost kernel: [ 3.424799] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) Jul 31 13:17:05 localhost kernel: [ 3.424920] TCP: Hash tables configured (established 4096 bind 4096) Jul 31 13:17:05 localhost kernel: [ 3.425075] UDP hash table entries: 256 (order: 1, 8192 bytes) Jul 31 13:17:05 localhost kernel: [ 3.425128] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) Jul 31 13:17:05 localhost kernel: [ 3.425462] NET: Registered protocol family 1 Jul 31 13:17:05 localhost kernel: [ 3.426159] RPC: Registered named UNIX socket transport module. Jul 31 13:17:05 localhost kernel: [ 3.426169] RPC: Registered udp transport module. Jul 31 13:17:05 localhost kernel: [ 3.426174] RPC: Registered tcp transport module. Jul 31 13:17:05 localhost kernel: [ 3.426180] RPC: Registered tcp NFSv4.1 backchannel transport module. Jul 31 13:17:05 localhost kernel: [ 3.426619] Trying to unpack rootfs image as initramfs... Jul 31 13:17:05 localhost kernel: [ 4.038691] Freeing initrd memory: 4980K Jul 31 13:17:05 localhost kernel: [ 4.041564] audit: initializing netlink subsys (disabled) Jul 31 13:17:05 localhost kernel: [ 4.041956] audit: type=2000 audit(4.020:1): state=initialized audit_enabled=0 res=1 Jul 31 13:17:05 localhost kernel: [ 4.042322] Initialise system trusted keyrings Jul 31 13:17:05 localhost kernel: [ 4.042600] workingset: timestamp_bits=14 max_order=17 bucket_order=3 Jul 31 13:17:05 localhost kernel: [ 4.052094] zbud: loaded Jul 31 13:17:05 localhost kernel: [ 4.056067] NFS: Registering the id_resolver key type Jul 31 13:17:05 localhost kernel: [ 4.056118] Key type id_resolver registered Jul 31 13:17:05 localhost kernel: [ 4.056124] Key type id_legacy registered Jul 31 13:17:05 localhost kernel: [ 4.056146] nfs4filelayout_init: NFSv4 File Layout Driver Registering... Jul 31 13:17:05 localhost kernel: [ 4.056154] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). Jul 31 13:17:05 localhost kernel: [ 4.057865] JFS: nTxBlock = 3938, nTxLock = 31508 Jul 31 13:17:05 localhost kernel: [ 4.065858] SGI XFS with ACLs, security attributes, realtime, no debug enabled Jul 31 13:17:05 localhost kernel: [ 4.078782] Key type asymmetric registered Jul 31 13:17:05 localhost kernel: [ 4.078950] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) Jul 31 13:17:05 localhost kernel: [ 4.079185] io scheduler noop registered Jul 31 13:17:05 localhost kernel: [ 4.079194] io scheduler deadline registered Jul 31 13:17:05 localhost kernel: [ 4.079693] io scheduler cfq registered (default) Jul 31 13:17:05 localhost kernel: [ 4.079702] io scheduler mq-deadline registered Jul 31 13:17:05 localhost kernel: [ 4.079710] io scheduler kyber registered Jul 31 13:17:05 localhost kernel: [ 4.079955] io scheduler bfq registered Jul 31 13:17:05 localhost kernel: [ 4.081691] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO Jul 31 13:17:05 localhost kernel: [ 4.088532] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver Jul 31 13:17:05 localhost kernel: [ 4.091320] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver Jul 31 13:17:05 localhost kernel: [ 4.181786] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled Jul 31 13:17:05 localhost kernel: [ 4.187275] console [ttyS0] disabled Jul 31 13:17:05 localhost kernel: [ 4.207526] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 39, base_baud = 1500000) is a U6_16550A Jul 31 13:17:05 localhost kernel: [ 4.207619] console [ttyS0] enabled Jul 31 13:17:05 localhost kernel: [ 4.213934] brd: module loaded Jul 31 13:17:05 localhost kernel: [ 4.223737] loop: module loaded Jul 31 13:17:05 localhost kernel: [ 4.226480] libphy: Fixed MDIO Bus: probed Jul 31 13:17:05 localhost kernel: [ 4.227388] dwmac-sun8i 1c30000.ethernet: PTP uses main clock Jul 31 13:17:05 localhost kernel: [ 4.227464] dwmac-sun8i 1c30000.ethernet: No regulator found Jul 31 13:17:05 localhost kernel: [ 4.227625] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000) Jul 31 13:17:05 localhost kernel: [ 4.227652] dwmac-sun8i 1c30000.ethernet: Chain mode enabled Jul 31 13:17:05 localhost kernel: [ 4.227664] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported Jul 31 13:17:05 localhost kernel: [ 4.227675] dwmac-sun8i 1c30000.ethernet: Normal descriptors Jul 31 13:17:05 localhost kernel: [ 4.227686] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported Jul 31 13:17:05 localhost kernel: [ 4.227698] dwmac-sun8i 1c30000.ethernet: COE Type 2 Jul 31 13:17:05 localhost kernel: [ 4.227708] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported Jul 31 13:17:05 localhost kernel: [ 4.227891] libphy: stmmac: probed Jul 31 13:17:05 localhost kernel: [ 4.228675] dwmac-sun8i 1c30000.ethernet: Found internal PHY node Jul 31 13:17:05 localhost kernel: [ 4.228935] libphy: mdio_mux: probed Jul 31 13:17:05 localhost kernel: [ 4.228970] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY Jul 31 13:17:05 localhost kernel: [ 4.228983] dwmac-sun8i 1c30000.ethernet: Powering internal PHY Jul 31 13:17:05 localhost kernel: [ 4.237127] libphy: mdio_mux: probed Jul 31 13:17:05 localhost kernel: [ 4.237956] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver Jul 31 13:17:05 localhost kernel: [ 4.237966] ehci-platform: EHCI generic platform driver Jul 31 13:17:05 localhost kernel: [ 4.238343] ehci-platform 1c1a000.usb: EHCI Host Controller Jul 31 13:17:05 localhost kernel: [ 4.238394] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1 Jul 31 13:17:05 localhost kernel: [ 4.239950] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000 Jul 31 13:17:05 localhost kernel: [ 4.278751] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00 Jul 31 13:17:05 localhost kernel: [ 4.279312] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 Jul 31 13:17:05 localhost kernel: [ 4.279328] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Jul 31 13:17:05 localhost kernel: [ 4.279339] usb usb1: Product: EHCI Host Controller Jul 31 13:17:05 localhost kernel: [ 4.279351] usb usb1: Manufacturer: Linux 4.14.14-sunxi ehci_hcd Jul 31 13:17:05 localhost kernel: [ 4.279362] usb usb1: SerialNumber: 1c1a000.usb Jul 31 13:17:05 localhost kernel: [ 4.280331] hub 1-0:1.0: USB hub found Jul 31 13:17:05 localhost kernel: [ 4.280430] hub 1-0:1.0: 1 port detected Jul 31 13:17:05 localhost kernel: [ 4.281695] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver Jul 31 13:17:05 localhost kernel: [ 4.281774] ohci-platform: OHCI generic platform driver Jul 31 13:17:05 localhost kernel: [ 4.282134] ohci-platform 1c1a400.usb: Generic Platform OHCI controller Jul 31 13:17:05 localhost kernel: [ 4.282176] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2 Jul 31 13:17:05 localhost kernel: [ 4.282585] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400 Jul 31 13:17:05 localhost kernel: [ 4.353206] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 Jul 31 13:17:05 localhost kernel: [ 4.353223] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Jul 31 13:17:05 localhost kernel: [ 4.353234] usb usb2: Product: Generic Platform OHCI controller Jul 31 13:17:05 localhost kernel: [ 4.353246] usb usb2: Manufacturer: Linux 4.14.14-sunxi ohci_hcd Jul 31 13:17:05 localhost kernel: [ 4.353256] usb usb2: SerialNumber: 1c1a400.usb Jul 31 13:17:05 localhost kernel: [ 4.354133] hub 2-0:1.0: USB hub found Jul 31 13:17:05 localhost kernel: [ 4.354209] hub 2-0:1.0: 1 port detected Jul 31 13:17:05 localhost kernel: [ 4.355646] usbcore: registered new interface driver usb-storage Jul 31 13:17:05 localhost kernel: [ 4.356648] mousedev: PS/2 mouse device common for all mice Jul 31 13:17:05 localhost kernel: [ 4.357499] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0 Jul 31 13:17:05 localhost kernel: [ 4.357513] sun6i-rtc 1f00000.rtc: RTC enabled Jul 31 13:17:05 localhost kernel: [ 4.357844] i2c /dev entries driver Jul 31 13:17:05 localhost kernel: [ 4.360875] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) Jul 31 13:17:05 localhost kernel: [ 4.363225] sunxi-mmc 1c0f000.mmc: Got CD GPIO Jul 31 13:17:05 localhost kernel: [ 4.418789] sunxi-mmc 1c0f000.mmc: base:0xe0ba3000 irq:23 Jul 31 13:17:05 localhost kernel: [ 4.420932] ledtrig-cpu: registered to indicate activity on CPUs Jul 31 13:17:05 localhost kernel: [ 4.421060] hidraw: raw HID events driver (C) Jiri Kosina Jul 31 13:17:05 localhost kernel: [ 4.421282] usbcore: registered new interface driver usbhid Jul 31 13:17:05 localhost kernel: [ 4.421288] usbhid: USB HID core driver Jul 31 13:17:05 localhost kernel: [ 4.423040] NET: Registered protocol family 10 Jul 31 13:17:05 localhost kernel: [ 4.450662] Segment Routing with IPv6 Jul 31 13:17:05 localhost kernel: [ 4.450837] NET: Registered protocol family 17 Jul 31 13:17:05 localhost kernel: [ 4.451178] Key type dns_resolver registered Jul 31 13:17:05 localhost kernel: [ 4.451976] Registering SWP/SWPB emulation handler Jul 31 13:17:05 localhost kernel: [ 4.453068] registered taskstats version 1 Jul 31 13:17:05 localhost kernel: [ 4.453076] Loading compiled-in X.509 certificates Jul 31 13:17:05 localhost kernel: [ 4.453227] zswap: loaded using pool lzo/zbud Jul 31 13:17:05 localhost kernel: [ 4.456180] Btrfs loaded, crc32c=crc32c-generic Jul 31 13:17:05 localhost kernel: [ 4.469622] Key type encrypted registered Jul 31 13:17:05 localhost kernel: [ 4.479822] mmc0: host does not support reading read-only switch, assuming write-enable Jul 31 13:17:05 localhost kernel: [ 4.483556] ehci-platform 1c1b000.usb: EHCI Host Controller Jul 31 13:17:05 localhost kernel: [ 4.483626] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3 Jul 31 13:17:05 localhost kernel: [ 4.484422] ehci-platform 1c1b000.usb: irq 28, io mem 0x01c1b000 Jul 31 13:17:05 localhost kernel: [ 4.485745] mmc0: new high speed SDHC card at address e624 Jul 31 13:17:05 localhost kernel: [ 4.486728] mmcblk0: mmc0:e624 SB16G 14.8 GiB Jul 31 13:17:05 localhost kernel: [ 4.489614] mmcblk0: p1 Jul 31 13:17:05 localhost kernel: [ 4.518842] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00 Jul 31 13:17:05 localhost kernel: [ 4.519249] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 Jul 31 13:17:05 localhost kernel: [ 4.519265] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Jul 31 13:17:05 localhost kernel: [ 4.519276] usb usb3: Product: EHCI Host Controller Jul 31 13:17:05 localhost kernel: [ 4.519288] usb usb3: Manufacturer: Linux 4.14.14-sunxi ehci_hcd Jul 31 13:17:05 localhost kernel: [ 4.519299] usb usb3: SerialNumber: 1c1b000.usb Jul 31 13:17:05 localhost kernel: [ 4.520163] hub 3-0:1.0: USB hub found Jul 31 13:17:05 localhost kernel: [ 4.520237] hub 3-0:1.0: 1 port detected Jul 31 13:17:05 localhost kernel: [ 4.521614] ehci-platform 1c1c000.usb: EHCI Host Controller Jul 31 13:17:05 localhost kernel: [ 4.521680] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4 Jul 31 13:17:05 localhost kernel: [ 4.522293] ehci-platform 1c1c000.usb: irq 30, io mem 0x01c1c000 Jul 31 13:17:05 localhost kernel: [ 4.548789] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 Jul 31 13:17:05 localhost kernel: [ 4.549206] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 Jul 31 13:17:05 localhost kernel: [ 4.549221] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Jul 31 13:17:05 localhost kernel: [ 4.549233] usb usb4: Product: EHCI Host Controller Jul 31 13:17:05 localhost kernel: [ 4.549244] usb usb4: Manufacturer: Linux 4.14.14-sunxi ehci_hcd Jul 31 13:17:05 localhost kernel: [ 4.549256] usb usb4: SerialNumber: 1c1c000.usb Jul 31 13:17:05 localhost kernel: [ 4.550101] hub 4-0:1.0: USB hub found Jul 31 13:17:05 localhost kernel: [ 4.550168] hub 4-0:1.0: 1 port detected Jul 31 13:17:05 localhost kernel: [ 4.551367] ehci-platform 1c1d000.usb: EHCI Host Controller Jul 31 13:17:05 localhost kernel: [ 4.551408] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5 Jul 31 13:17:05 localhost kernel: [ 4.551850] ehci-platform 1c1d000.usb: irq 32, io mem 0x01c1d000 Jul 31 13:17:05 localhost kernel: [ 4.578771] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00 Jul 31 13:17:05 localhost kernel: [ 4.579109] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 Jul 31 13:17:05 localhost kernel: [ 4.579125] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Jul 31 13:17:05 localhost kernel: [ 4.579136] usb usb5: Product: EHCI Host Controller Jul 31 13:17:05 localhost kernel: [ 4.579148] usb usb5: Manufacturer: Linux 4.14.14-sunxi ehci_hcd Jul 31 13:17:05 localhost kernel: [ 4.579159] usb usb5: SerialNumber: 1c1d000.usb Jul 31 13:17:05 localhost kernel: [ 4.579957] hub 5-0:1.0: USB hub found Jul 31 13:17:05 localhost kernel: [ 4.580026] hub 5-0:1.0: 1 port detected Jul 31 13:17:05 localhost kernel: [ 4.581165] ohci-platform 1c1b400.usb: Generic Platform OHCI controller Jul 31 13:17:05 localhost kernel: [ 4.581207] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6 Jul 31 13:17:05 localhost kernel: [ 4.581596] ohci-platform 1c1b400.usb: irq 29, io mem 0x01c1b400 Jul 31 13:17:05 localhost kernel: [ 4.653059] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 Jul 31 13:17:05 localhost kernel: [ 4.653075] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Jul 31 13:17:05 localhost kernel: [ 4.653087] usb usb6: Product: Generic Platform OHCI controller Jul 31 13:17:05 localhost kernel: [ 4.653098] usb usb6: Manufacturer: Linux 4.14.14-sunxi ohci_hcd Jul 31 13:17:05 localhost kernel: [ 4.653109] usb usb6: SerialNumber: 1c1b400.usb Jul 31 13:17:05 localhost kernel: [ 4.653957] hub 6-0:1.0: USB hub found Jul 31 13:17:05 localhost kernel: [ 4.654036] hub 6-0:1.0: 1 port detected Jul 31 13:17:05 localhost kernel: [ 4.655233] ohci-platform 1c1c400.usb: Generic Platform OHCI controller Jul 31 13:17:05 localhost kernel: [ 4.655274] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7 Jul 31 13:17:05 localhost kernel: [ 4.655612] ohci-platform 1c1c400.usb: irq 31, io mem 0x01c1c400 Jul 31 13:17:05 localhost kernel: [ 4.723064] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001 Jul 31 13:17:05 localhost kernel: [ 4.723080] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Jul 31 13:17:05 localhost kernel: [ 4.723092] usb usb7: Product: Generic Platform OHCI controller Jul 31 13:17:05 localhost kernel: [ 4.723103] usb usb7: Manufacturer: Linux 4.14.14-sunxi ohci_hcd Jul 31 13:17:05 localhost kernel: [ 4.723114] usb usb7: SerialNumber: 1c1c400.usb Jul 31 13:17:05 localhost kernel: [ 4.723964] hub 7-0:1.0: USB hub found Jul 31 13:17:05 localhost kernel: [ 4.724031] hub 7-0:1.0: 1 port detected Jul 31 13:17:05 localhost kernel: [ 4.725180] ohci-platform 1c1d400.usb: Generic Platform OHCI controller Jul 31 13:17:05 localhost kernel: [ 4.725220] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8 Jul 31 13:17:05 localhost kernel: [ 4.725603] ohci-platform 1c1d400.usb: irq 33, io mem 0x01c1d400 Jul 31 13:17:05 localhost kernel: [ 4.793083] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001 Jul 31 13:17:05 localhost kernel: [ 4.793099] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Jul 31 13:17:05 localhost kernel: [ 4.793111] usb usb8: Product: Generic Platform OHCI controller Jul 31 13:17:05 localhost kernel: [ 4.793122] usb usb8: Manufacturer: Linux 4.14.14-sunxi ohci_hcd Jul 31 13:17:05 localhost kernel: [ 4.793133] usb usb8: SerialNumber: 1c1d400.usb Jul 31 13:17:05 localhost kernel: [ 4.793922] hub 8-0:1.0: USB hub found Jul 31 13:17:05 localhost kernel: [ 4.793991] hub 8-0:1.0: 1 port detected Jul 31 13:17:05 localhost kernel: [ 4.795199] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator Jul 31 13:17:05 localhost kernel: [ 4.798936] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator Jul 31 13:17:05 localhost kernel: [ 4.798954] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000) Jul 31 13:17:05 localhost kernel: [ 4.799576] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 Jul 31 13:17:05 localhost kernel: [ 4.807735] of_cfs_init Jul 31 13:17:05 localhost kernel: [ 4.807832] of_cfs_init: OK Jul 31 13:17:05 localhost kernel: [ 4.807963] vdd-cpux-dummy: disabling Jul 31 13:17:05 localhost kernel: [ 4.807968] vcc3v0: disabling Jul 31 13:17:05 localhost kernel: [ 4.807973] vcc5v0: disabling Jul 31 13:17:05 localhost kernel: [ 4.807977] vcc-wifi: disabling Jul 31 13:17:05 localhost kernel: [ 4.810935] Freeing unused kernel memory: 1024K Jul 31 13:17:05 localhost kernel: [ 5.267112] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq Jul 31 13:17:05 localhost kernel: [ 5.540244] sunxi-mmc 1c10000.mmc: base:0xe0c1e000 irq:24 Jul 31 13:17:05 localhost kernel: [ 5.562578] mmc1: new high speed SDIO card at address 0001 Jul 31 13:17:05 localhost kernel: [ 6.879916] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) Jul 31 13:17:05 localhost kernel: [ 7.736699] ip_tables: (C) 2000-2006 Netfilter Core Team Jul 31 13:17:05 localhost kernel: [ 9.530288] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro Jul 31 13:17:05 localhost kernel: [ 9.553732] g_serial gadget: Gadget Serial v2.4 Jul 31 13:17:05 localhost kernel: [ 9.553747] g_serial gadget: g_serial ready Jul 31 13:17:05 localhost kernel: [ 10.882253] thermal thermal_zone0: failed to read out thermal zone (-110) Jul 31 13:17:05 localhost kernel: [ 11.668518] xradio_wlan mmc1:0001:1: missed interrupt Jul 31 13:17:05 localhost kernel: [ 11.668617] xradio_wlan mmc1:0001:1: Input buffers: 30 x 1632 bytes Jul 31 13:17:05 localhost kernel: [ 11.668617] Hardware: 7.9 Jul 31 13:17:05 localhost kernel: [ 11.668617] WSM firmware ver: 8, build: 43, api: 1060, cap: 0x0003 Jul 31 13:17:05 localhost kernel: [ 11.668623] xradio_wlan mmc1:0001:1: Firmware Label:XR_C01.08.0043 Jun 6 2016 20:41:04 Jul 31 13:17:05 localhost kernel: [ 11.669724] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' Jul 31 13:17:05 localhost kernel: [ 11.928929] thermal thermal_zone0: failed to read out thermal zone (-110) Jul 31 13:17:05 localhost kernel: [ 12.474657] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL) Jul 31 13:17:05 localhost kernel: [ 12.476383] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available Jul 31 13:17:05 localhost kernel: [ 12.476394] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW Jul 31 13:17:05 localhost kernel: [ 12.476797] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready Jul 31 13:17:05 localhost kernel: [ 12.968806] thermal thermal_zone0: failed to read out thermal zone (-110) Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.113 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.114 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.115 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.116 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.117 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.118 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.119 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.12 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.120 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.121 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.122 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.123 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.124 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.125 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.126 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.127 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.128 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.129 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.13 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.130 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.131 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.132 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.133 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.134 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.135 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.136 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.137 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.138 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.139 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.14 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.140 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.141 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.142 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.143 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.144 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.145 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.146 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.147 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.148 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.149 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.15 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.150 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.151 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.152 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.153 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.154 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.155 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.156 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.157 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.158 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.159 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.16 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.160 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.161 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.162 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.163 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.164 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.165 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.166 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.167 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.168 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.169 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.17 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.170 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.171 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.172 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.173 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.174 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.175 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.176 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.177 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.178 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.179 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.18 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.180 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.181 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.182 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.183 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.184 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.185 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.186 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.187 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.188 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.189 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.19 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.190 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.191 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.192 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.193 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.194 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.195 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.196 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.197 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.198 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.199 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.2 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.20 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.200 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.201 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.202 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.203 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.204 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.205 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.206 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.207 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.208 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.209 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.21 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.210 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.211 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.212 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.213 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.214 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.215 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.216 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.217 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.218 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.219 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.22 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.220 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.221 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.23 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.24 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.25 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.26 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.27 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.28 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.29 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.3 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.30 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.31 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.32 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.33 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.34 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.35 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.36 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.37 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.38 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.39 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.4 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.40 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.41 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.42 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.43 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.44 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.45 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.46 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.47 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.48 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.49 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.5 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.50 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.51 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.52 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.53 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.54 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.55 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.56 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.57 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.58 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.59 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.6 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.60 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.61 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.62 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.63 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.64 Jul 31 13:17:05 localhost systemd[1]: Started Flush Journal to Persistent Storage. Jul 31 13:17:05 localhost sh[445]: eth0=eth0 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.65 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.66 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.67 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.68 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.69 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.7 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.70 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.71 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.72 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.73 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.74 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.75 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.76 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.77 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.78 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.79 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.8 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.80 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.81 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.82 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.83 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.84 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.85 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.86 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.87 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.88 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.89 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.9 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.90 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.91 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.92 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.93 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.94 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.95 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.96 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.97 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.98 Jul 31 13:17:05 localhost log2ram[295]: letsencrypt/letsencrypt.log.99 Jul 31 13:17:05 localhost log2ram[295]: mosquitto/ Jul 31 13:17:05 localhost log2ram[295]: mosquitto/mosquitto.log Jul 31 13:17:05 localhost log2ram[295]: mosquitto/mosquitto.log.1.gz Jul 31 13:17:05 localhost log2ram[295]: mosquitto/mosquitto.log.2.gz Jul 31 13:17:05 localhost log2ram[295]: mysql/ Jul 31 13:17:05 localhost log2ram[295]: mysql/error.log Jul 31 13:17:05 localhost log2ram[295]: mysql/error.log.1.gz Jul 31 13:17:05 localhost log2ram[295]: mysql/error.log.2.gz Jul 31 13:17:05 localhost log2ram[295]: mysql/error.log.3.gz Jul 31 13:17:05 localhost log2ram[295]: mysql/error.log.4.gz Jul 31 13:17:05 localhost log2ram[295]: mysql/error.log.5.gz Jul 31 13:17:05 localhost log2ram[295]: mysql/error.log.6.gz Jul 31 13:17:05 localhost log2ram[295]: mysql/error.log.7.gz Jul 31 13:17:05 localhost log2ram[295]: ntpstats/ Jul 31 13:17:05 localhost log2ram[295]: sysstat/ Jul 31 13:17:05 localhost log2ram[295]: unattended-upgrades/ Jul 31 13:17:05 localhost log2ram[295]: unattended-upgrades/unattended-upgrades-dpkg.log Jul 31 13:17:05 localhost log2ram[295]: unattended-upgrades/unattended-upgrades-dpkg.log.1.gz Jul 31 13:17:05 localhost log2ram[295]: unattended-upgrades/unattended-upgrades-dpkg.log.2.gz Jul 31 13:17:05 localhost log2ram[295]: unattended-upgrades/unattended-upgrades-shutdown.log Jul 31 13:17:05 localhost log2ram[295]: unattended-upgrades/unattended-upgrades.log Jul 31 13:17:05 localhost log2ram[295]: unattended-upgrades/unattended-upgrades.log.1.gz Jul 31 13:17:05 localhost log2ram[295]: unattended-upgrades/unattended-upgrades.log.2.gz Jul 31 13:17:05 localhost log2ram[295]: sent 10,020,619 bytes received 6,957 bytes 4,011,030.40 bytes/sec Jul 31 13:17:05 localhost log2ram[295]: total size is 9,994,594 speedup is 1.00 Jul 31 13:17:05 localhost systemd[1]: Starting Create Volatile Files and Directories... Jul 31 13:17:05 localhost systemd[1]: Started Create Volatile Files and Directories. Jul 31 13:17:05 localhost systemd[1]: Started Entropy daemon using the HAVEGE algorithm. Jul 31 13:17:05 localhost systemd[1]: Reached target System Time Synchronized. Jul 31 13:17:05 localhost systemd[1]: Starting Update UTMP about System Boot/Shutdown... Jul 31 13:17:05 localhost systemd[1]: Started Update UTMP about System Boot/Shutdown. Jul 31 13:17:05 localhost systemd[1]: Reached target System Initialization. Jul 31 13:17:05 localhost systemd[1]: Listening on D-Bus System Message Bus Socket. Jul 31 13:17:05 localhost systemd[1]: Reached target Sockets. Jul 31 13:17:05 localhost systemd[1]: certbot.timer: Adding 57min 11.549793s random time. Jul 31 13:17:05 localhost systemd[1]: Started Run certbot twice daily. Jul 31 13:17:05 localhost systemd[1]: Started Clean PHP session files every 30 mins. Jul 31 13:17:05 localhost systemd[1]: Started Daily Cleanup of Temporary Directories. Jul 31 13:17:05 localhost systemd[1]: apt-daily.timer: Adding 8h 57min 35.888841s random time. Jul 31 13:17:05 localhost systemd[1]: Started Daily apt download activities. Jul 31 13:17:05 localhost systemd[1]: apt-daily-upgrade.timer: Adding 37min 55.978190s random time. Jul 31 13:17:05 localhost systemd[1]: Started Daily apt upgrade and clean activities. Jul 31 13:17:05 localhost systemd[1]: Reached target Timers. Jul 31 13:17:05 localhost systemd[1]: Reached target Basic System. Jul 31 13:17:05 localhost systemd[1]: Starting Login Service... Jul 31 13:17:05 localhost systemd[1]: Starting LSB: Armbian gathering hardware information... Jul 31 13:17:05 localhost systemd[1]: Started Regular background program processing daemon. Jul 31 13:17:05 localhost cron[515]: (CRON) INFO (pidfile fd = 3) Jul 31 13:17:05 localhost systemd[1]: Started D-Bus System Message Bus. Jul 31 13:17:05 localhost cron[515]: (CRON) INFO (Running @reboot jobs) Jul 31 13:17:05 localhost armhwinfo[514]: [#033[0;32m ok #033[0m] Setting noop I/O scheduler for mmcblk0 Jul 31 13:17:05 localhost CRON[533]: (root) CMD (/root/HomeControl/rest.py) Jul 31 13:17:05 localhost CRON[535]: (root) CMD (/root/HomeControl/Pablo.py) Jul 31 13:17:05 localhost CRON[534]: (root) CMD (/usr/lib/armbian/apt-updates) Jul 31 13:17:05 localhost armhwinfo[514]: [#033[0;32m ok #033[0m] Starting ARM hardware info: Orange Pi Zero (5.38) Jul 31 13:17:05 localhost dbus[525]: [system] Successfully activated service 'org.freedesktop.systemd1' Jul 31 13:17:05 localhost systemd[1]: Starting LSB: Load kernel modules needed to enable cpufreq scaling... Jul 31 13:17:05 localhost systemd[1]: Starting LSB: mosquitto MQTT v3.1 message broker... Jul 31 13:17:05 localhost systemd[1]: Starting System Logging Service... Jul 31 13:17:05 localhost systemd[1]: Starting LSB: Start/stop sysstat's sadc... Jul 31 13:17:05 localhost systemd[1]: Starting Network Manager... Jul 31 13:17:05 localhost liblogging-stdlog: [origin software="rsyslogd" swVersion="8.24.0" x-pid="569" x-info="http://www.rsyslog.com"] start Jul 31 13:17:05 localhost systemd[1]: Started System Logging Service. Jul 31 13:17:05 localhost mosquitto[563]: Starting network daemon:: mosquitto. Jul 31 13:17:05 localhost systemd[1]: Started LSB: mosquitto MQTT v3.1 message broker. Jul 31 13:17:05 localhost systemd[1]: Started LSB: Start/stop sysstat's sadc. Jul 31 13:17:05 localhost systemd[1]: Started Login Service. Jul 31 13:17:06 localhost loadcpufreq[553]: Loading cpufreq kernel modules...done (none). Jul 31 13:17:06 localhost systemd[1]: Started LSB: Load kernel modules needed to enable cpufreq scaling. Jul 31 13:17:06 localhost haveged[510]: haveged: ver: 1.9.1; arch: generic; vend: ; build: (gcc 6.3.0 CTV); collect: 128K Jul 31 13:17:06 localhost haveged[510]: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 12/40; sz: 16108/62084 Jul 31 13:17:06 localhost haveged[510]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B): last entropy estimate 8.00249 Jul 31 13:17:06 localhost haveged[510]: haveged: fills: 0, generated: 0 Jul 31 13:17:06 localhost systemd[1]: Starting LSB: set CPUFreq kernel parameters... Jul 31 13:17:06 localhost kernel: [ 14.790446] random: crng init done Jul 31 13:17:06 localhost cpufrequtils[613]: CPUFreq Utilities: Setting ondemand CPUFreq governor...CPU0...CPU1...CPU2...CPU3...done. Jul 31 13:17:06 localhost systemd[1]: Started LSB: set CPUFreq kernel parameters. Jul 31 13:17:06 localhost systemd[1]: Starting LSB: Set sysfs variables from /etc/sysfs.conf... Jul 31 13:17:06 localhost sysfsutils[625]: Setting sysfs variables.... Jul 31 13:17:06 localhost systemd[1]: Started LSB: Set sysfs variables from /etc/sysfs.conf. Jul 31 13:17:06 localhost NetworkManager[575]: <info> [1533035826.8060] NetworkManager (version 1.6.2) is starting... Jul 31 13:17:06 localhost NetworkManager[575]: <info> [1533035826.8064] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 10-override-random-mac.conf, zz-override-wifi-powersave-off.conf) Jul 31 13:17:06 localhost NetworkManager[575]: <info> [1533035826.8742] manager[0x1ded108]: monitoring kernel firmware directory '/lib/firmware'. Jul 31 13:17:06 localhost NetworkManager[575]: <info> [1533035826.8781] monitoring ifupdown state file '/run/network/ifstate'. Jul 31 13:17:06 localhost NetworkManager[575]: <info> [1533035826.9085] dns-mgr[0x1df9828]: init: dns=default, rc-manager=resolvconf Jul 31 13:17:06 localhost NetworkManager[575]: <info> [1533035826.9235] rfkill0: found WiFi radio killswitch (at /sys/devices/platform/soc/1c10000.mmc/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/ieee80211/phy0/rfkill0) (driver xradio_wlan) Jul 31 13:17:06 localhost NetworkManager[575]: <info> [1533035826.9287] manager[0x1ded108]: WiFi hardware radio set enabled Jul 31 13:17:06 localhost NetworkManager[575]: <info> [1533035826.9326] manager[0x1ded108]: WWAN hardware radio set enabled Jul 31 13:17:06 localhost systemd[1]: Started Network Manager. Jul 31 13:17:06 localhost systemd[1]: Starting Network Manager Wait Online... Jul 31 13:17:06 localhost dbus[525]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' Jul 31 13:17:06 localhost systemd[1]: Reached target Network. Jul 31 13:17:07 localhost systemd[1]: Starting Fail2Ban Service... Jul 31 13:17:07 localhost systemd[1]: Starting Permit User Sessions... Jul 31 13:17:07 localhost systemd[1]: Starting The Apache HTTP Server... Jul 31 13:17:07 localhost systemd[1]: Started Unattended Upgrades Shutdown. Jul 31 13:17:07 localhost kernel: [ 15.609552] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx Jul 31 13:17:07 localhost kernel: [ 15.609629] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready Jul 31 13:17:07 localhost systemd[1]: Starting MariaDB database server... Jul 31 13:17:07 localhost systemd[1]: Starting OpenBSD Secure Shell server... Jul 31 13:17:07 localhost systemd[1]: Started Permit User Sessions. Jul 31 13:17:07 localhost systemd[1]: Starting Network Manager Script Dispatcher Service... Jul 31 13:17:07 localhost dbus[525]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher' Jul 31 13:17:07 localhost systemd[1]: Started Network Manager Script Dispatcher Service. Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4105] init! Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4139] guessed connection type (eth0) = 802-3-ethernet Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4143] update_connection_setting_from_if_block: name:eth0, type:802-3-ethernet, id:Ifupdown (eth0), uuid: 681b428f-beaf-8932-dce4-687ed5bae28e Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4169] addresses count: 1 Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4172] No dns-nameserver configured in /etc/network/interfaces Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4176] adding eth0 to connections Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4177] adding iface eth0 to eni_ifaces Jul 31 13:17:07 localhost dbus[525]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4204] autoconnect Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4206] management mode: unmanaged Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4556] devices added (path: /sys/devices/platform/soc/1c10000.mmc/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/net/wlan0, iface: wlan0) Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4558] device added (path: /sys/devices/platform/soc/1c10000.mmc/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/net/wlan0, iface: wlan0): no ifupdown configuration found. Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4560] devices added (path: /sys/devices/platform/soc/1c30000.ethernet/net/eth0, iface: eth0) Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4565] locking wired connection setting Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4568] devices added (path: /sys/devices/virtual/net/lo, iface: lo) Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4569] device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found. Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4570] end _init. Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4572] settings: loaded plugin ifupdown: (C) 2008 Canonical Ltd. To report bugs please use the NetworkManager mailing list. (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-settings-plugin-ifupdown.so) Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4578] settings: loaded plugin keyfile: (c) 2007 - 2016 Red Hat, Inc. To report bugs please use the NetworkManager mailing list. Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4579] (31288512) ... get_connections. Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4580] (31288512) ... get_connections (managed=false): return empty list. Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.4631] get unmanaged devices count: 1 Jul 31 13:17:07 localhost systemd[1]: Starting Hostname Service... Jul 31 13:17:07 localhost systemd[1]: Started OpenBSD Secure Shell server. Jul 31 13:17:07 localhost dbus[525]: [system] Successfully activated service 'org.freedesktop.hostname1' Jul 31 13:17:07 localhost systemd[1]: Started Hostname Service. Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.9885] settings: hostname: using hostnamed Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.9888] settings: hostname changed from (none) to "orangepizero" Jul 31 13:17:07 localhost NetworkManager[575]: <info> [1533035827.9907] dhcp-init: Using DHCP client 'dhclient' Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035827.9910] manager: WiFi enabled by radio killswitch; enabled by state file Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035827.9913] manager: WWAN enabled by radio killswitch; enabled by state file Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035827.9915] manager: Networking is enabled by state file Jul 31 13:17:08 localhost nm-dispatcher: req:1 'hostname': new request (2 scripts) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035827.9987] Loaded device plugin: NMBondDeviceFactory (internal) Jul 31 13:17:08 localhost nm-dispatcher: req:1 'hostname': start running ordered scripts... Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035827.9990] Loaded device plugin: NMBridgeDeviceFactory (internal) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035827.9992] Loaded device plugin: NMEthernetDeviceFactory (internal) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035827.9993] Loaded device plugin: NMInfinibandDeviceFactory (internal) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035827.9994] Loaded device plugin: NMIPTunnelDeviceFactory (internal) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035827.9996] Loaded device plugin: NMMacsecDeviceFactory (internal) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035827.9997] Loaded device plugin: NMMacvlanDeviceFactory (internal) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035827.9999] Loaded device plugin: NMTunDeviceFactory (internal) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.0001] Loaded device plugin: NMVethDeviceFactory (internal) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.0003] Loaded device plugin: NMVlanDeviceFactory (internal) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.0005] Loaded device plugin: NMVxlanDeviceFactory (internal) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.0090] Loaded device plugin: NMAtmManager (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-adsl.so) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.0188] Loaded device plugin: NMWifiFactory (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-wifi.so) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.0806] Loaded device plugin: NMWwanFactory (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-wwan.so) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.1183] Loaded device plugin: NMTeamFactory (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-team.so) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.1506] Loaded device plugin: NMBluezManager (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-bluetooth.so) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.1683] device (lo): link connected Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.1838] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1) Jul 31 13:17:08 localhost apachectl[660]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using ::1. Set the 'ServerName' directive globally to suppress this message Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.2328] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.2402] (wlan0): using nl80211 for WiFi device control Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.2426] device (wlan0): driver supports Access Point (AP) mode Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.2625] manager: (wlan0): new 802.11 WiFi device (/org/freedesktop/NetworkManager/Devices/3) Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.3167] device (wlan0): state change: unmanaged -> unavailable (reason 'managed') [10 20 2] Jul 31 13:17:08 localhost kernel: [ 16.856805] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready Jul 31 13:17:08 localhost kernel: [ 16.857707] ieee80211 phy0: Interface ID:0 of type:2 added Jul 31 13:17:08 localhost kernel: [ 16.872603] ieee80211 phy0: vif 0, configuring tx Jul 31 13:17:08 localhost kernel: [ 16.873282] ieee80211 phy0: vif 0, configuring tx Jul 31 13:17:08 localhost kernel: [ 16.873651] ieee80211 phy0: vif 0, configuring tx Jul 31 13:17:08 localhost kernel: [ 16.873976] ieee80211 phy0: vif 0, configuring tx Jul 31 13:17:08 localhost kernel: [ 16.874282] ieee80211 phy0: ignore IEEE80211_CONF_CHANGE_MONITOR (1)IEEE80211_CONF_CHANGE_IDLE (1) Jul 31 13:17:08 localhost kernel: [ 16.874489] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready Jul 31 13:17:08 localhost systemd[1]: Started The Apache HTTP Server. Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.3883] manager: NetworkManager state is now CONNECTED_GLOBAL Jul 31 13:17:08 localhost nm-dispatcher: req:2 'connectivity-change': new request (2 scripts) Jul 31 13:17:08 localhost nm-dispatcher: req:2 'connectivity-change': start running ordered scripts... Jul 31 13:17:08 localhost dbus[525]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' Jul 31 13:17:08 localhost systemd[1]: Starting Authorization Manager... Jul 31 13:17:08 localhost dbus[525]: [system] Activating via systemd: service name='fi.w1.wpa_supplicant1' unit='wpa_supplicant.service' Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.5104] device (eth0): link connected Jul 31 13:17:08 localhost systemd[1]: Starting WPA supplicant... Jul 31 13:17:08 localhost dbus[525]: [system] Successfully activated service 'fi.w1.wpa_supplicant1' Jul 31 13:17:08 localhost polkitd[743]: started daemon version 0.105 using authority implementation `local' version `0.105' Jul 31 13:17:08 localhost systemd[1]: Started WPA supplicant. Jul 31 13:17:08 localhost dbus[525]: [system] Successfully activated service 'org.freedesktop.PolicyKit1' Jul 31 13:17:08 localhost wpa_supplicant[762]: Successfully initialized wpa_supplicant Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.9064] supplicant: wpa_supplicant running Jul 31 13:17:08 localhost NetworkManager[575]: <info> [1533035828.9071] device (wlan0): supplicant interface state: init -> starting Jul 31 13:17:08 localhost systemd[1]: Started Authorization Manager. Jul 31 13:17:09 localhost NetworkManager[575]: <info> [1533035829.1396] sup-iface[0x1e41b00,wlan0]: supports 2 scan SSIDs Jul 31 13:17:09 localhost kernel: [ 17.674604] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready Jul 31 13:17:09 localhost NetworkManager[575]: <info> [1533035829.1484] device (wlan0): supplicant interface state: starting -> ready Jul 31 13:17:09 localhost NetworkManager[575]: <info> [1533035829.1491] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available') [20 30 42] Jul 31 13:17:10 localhost NetworkManager[575]: <info> [1533035830.0092] device (wlan0): supplicant interface state: ready -> inactive Jul 31 13:17:10 localhost NetworkManager[575]: <info> [1533035830.0770] manager: startup complete Jul 31 13:17:10 localhost systemd[1]: Started Network Manager Wait Online. Jul 31 13:17:10 localhost systemd[1]: Reached target Network is Online. Jul 31 13:17:10 localhost systemd[1]: Starting LSB: Start NTP daemon... Jul 31 13:17:10 localhost systemd[1]: Starting /etc/rc.local Compatibility... Jul 31 13:17:10 localhost systemd[1]: Starting LSB: disk temperature monitoring daemon... Jul 31 13:17:10 localhost systemd[1]: Starting LSB: Advanced IEEE 802.11 management daemon... Jul 31 13:17:10 localhost systemd[1]: Starting LSB: Update dynamic domain name service entries... Jul 31 13:17:10 localhost systemd[1]: Started /etc/rc.local Compatibility. Jul 31 13:17:10 localhost systemd[1]: Started LSB: Advanced IEEE 802.11 management daemon. Jul 31 13:17:10 localhost systemd[1]: Started LSB: disk temperature monitoring daemon. Jul 31 13:17:10 localhost systemd[1]: Started Getty on tty1. Jul 31 13:17:10 localhost systemd[1]: Started Serial Getty on ttyGS0. Jul 31 13:17:10 localhost systemd[1]: Started Serial Getty on ttyS0. Jul 31 13:17:10 localhost systemd[1]: Reached target Login Prompts. Jul 31 13:17:10 localhost mysqld[902]: 2018-07-31 13:17:10 3063685120 [Note] /usr/sbin/mysqld (mysqld 10.1.26-MariaDB-0+deb9u1) starting as process 902 ... Jul 31 13:17:10 localhost ntpd[977]: ntpd 4.2.8p10@1.3728-o Sat Sep 23 21:50:14 UTC 2017 (1): Starting Jul 31 13:17:10 localhost ntp[932]: Starting NTP server: ntpd. Jul 31 13:17:10 localhost systemd[1]: Started LSB: Start NTP daemon. Jul 31 13:17:10 localhost ntpd[977]: Command line: /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 106:110 Jul 31 13:17:10 localhost ntpd[987]: proto: precision = 0.875 usec (-20) Jul 31 13:17:10 localhost ntpd[987]: Listen and drop on 0 v6wildcard [::]:123 Jul 31 13:17:10 localhost ntpd[987]: Listen and drop on 1 v4wildcard 0.0.0.0:123 Jul 31 13:17:10 localhost ntpd[987]: Listen normally on 2 lo 127.0.0.1:123 Jul 31 13:17:10 localhost ntpd[987]: Listen normally on 3 eth0 192.168.0.50:123 Jul 31 13:17:10 localhost ntpd[987]: Listen normally on 4 lo [::1]:123 Jul 31 13:17:10 localhost ntpd[987]: Listen normally on 5 eth0 [fe80::42:9fff:fe4f:4c27%2]:123 Jul 31 13:17:10 localhost ntpd[987]: Listening on routing socket on fd #22 for interface updates Jul 31 13:17:10 localhost systemd[1]: Started LSB: Armbian gathering hardware information. Jul 31 13:17:11 localhost fail2ban-client[658]: 2018-07-31 13:17:11,829 fail2ban.server [976]: INFO Starting Fail2ban v0.9.6 Jul 31 13:17:11 localhost fail2ban-client[658]: 2018-07-31 13:17:11,837 fail2ban.server [976]: INFO Starting in daemon mode Jul 31 13:17:11 localhost ntpd[987]: Soliciting pool server 193.225.50.69 Jul 31 13:17:12 localhost systemd[1]: Started LSB: Update dynamic domain name service entries. Jul 31 13:17:12 localhost ntpd[987]: Soliciting pool server 185.82.232.254 Jul 31 13:17:12 localhost ntpd[987]: Soliciting pool server 193.224.45.107 Jul 31 13:17:13 localhost ntpd[987]: Soliciting pool server 62.112.193.129 Jul 31 13:17:13 localhost ntpd[987]: Soliciting pool server 193.224.163.77 Jul 31 13:17:13 localhost ntpd[987]: Soliciting pool server 212.92.16.193 Jul 31 13:17:14 localhost ntpd[987]: Soliciting pool server 193.225.190.4 Jul 31 13:17:14 localhost ntpd[987]: Soliciting pool server 193.225.118.162 Jul 31 13:17:14 localhost ntpd[987]: Soliciting pool server 195.228.75.149 Jul 31 13:17:14 localhost ntpd[987]: Soliciting pool server 193.225.190.6 Jul 31 13:17:15 localhost systemd[1]: Started MariaDB database server. Jul 31 13:17:15 localhost ntpd[987]: Soliciting pool server 193.6.222.47 Jul 31 13:17:15 localhost ntpd[987]: Soliciting pool server 193.6.176.59 Jul 31 13:17:15 localhost ntpd[987]: Soliciting pool server 193.224.45.106 Jul 31 13:17:16 localhost systemd[1]: Started Fail2Ban Service. Jul 31 13:17:16 localhost systemd[1]: Reached target Multi-User System. Jul 31 13:17:16 localhost systemd[1]: Reached target Graphical Interface. Jul 31 13:17:16 localhost systemd[1]: Starting Update UTMP about System Runlevel Changes... Jul 31 13:17:16 localhost systemd[1]: Started Update UTMP about System Runlevel Changes. Jul 31 13:17:16 localhost systemd[1]: Startup finished in 7.513s (kernel) + 17.854s (userspace) = 25.367s. Jul 31 13:17:17 localhost ntpd[987]: Soliciting pool server 188.227.227.31 Jul 31 13:17:17 localhost ntpd[987]: Soliciting pool server 193.225.118.130 Jul 31 13:17:17 localhost ntpd[987]: Soliciting pool server 2001:4c48:1::1
guidol Posted July 31, 2018 Posted July 31, 2018 Your OPi Zero seems to run alltime at 1200Mhz. Please check via armbianmonitor -m normally it should switch down (idle) to 240Mhz: root@opi-zero(192.168.6.99):~# armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 20:20:17: 1008MHz 0.06 0% 0% 0% 0% 0% 0% 70.4°C 2/8 20:20:23: 240MHz 0.05 1% 0% 0% 0% 0% 0% 69.1°C 1/8 20:20:28: 240MHz 0.05 1% 1% 0% 0% 0% 0% 70.3°C 2/8 Maybe it doesnt switch down at the armbian 5.38 with kernel 4.14 check /etc/default/cpufrequtils for the following content: # WARNING: this file will be replaced on board support package (linux-root-...) upgrade ENABLE=true MIN_SPEED=240000 MAX_SPEED=1200000 GOVERNOR=ondemand but when it doenst switch down to 240Mhz then try the following command and recheck via armbianmonitor -m echo 200000 > /sys/devices/system/cpu/cpufreq/ondemand/sampling_rate A slower cpu could run cooler. And it seems that you didnt use the WiFi - so you can disable it with the follwoing command in the /etc/rc.local (before the exit 0) : ifconfig wlan0 down rmmod xradio_wlan rmmod mac80211 rmmod cfg80211 actual I am running a armbian debian nightly version: Welcome to ARMBIAN 5.54.180727 testing Debian GNU/Linux 9 (stretch) 4.17.10-sunxi System load: 0.08 0.02 0.01 Up time: 4 days CPU temp: 70°C I did similiar configurations also on my OPi Zero Plus (non Plus2 but H5) - which also did before sometimes freeze and overheat. 1
Levente Nemeth Posted July 31, 2018 Author Posted July 31, 2018 Thanks. I've modified the sampling rate so that CPU frequency looks OK now: root@orangepizero:~# armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 21:36:45: 1200MHz 0.26 5% 3% 1% 0% 0% 0% 51.2°C 0/8 21:36:51: 1200MHz 0.24 2% 1% 1% 0% 0% 0% 51.5°C 0/8 21:36:56: 240MHz 0.22 1% 1% 0% 0% 0% 0% 50.9°C 0/8 21:37:01: 240MHz 0.20 2% 1% 0% 0% 0% 0% 51.4°C 0/8 21:37:06: 240MHz 0.24 2% 0% 0% 0% 0% 0% 51.2°C 0/8 21:37:11: 240MHz 0.22 2% 1% 0% 0% 0% 0% 51.2°C 0/8 Actually I see 2 issues here as follows: #1: something happened around 06:25 because I can not find any log entry between 06:25 and 13:17. After this point all my python scripts seems to be stopped. #2 the system seems to be restarted at 13:17:04 by itself. It runs couple of processes and then freezes at 13:17:17 and overheats. I just realized the problem when I came home from work around 18.00. I noticed that orange PI is unreachable (even the router didn't see it) and when I touch the device I could feel that its BADLY overheated (it was almost burning my hand). Here are some logs from my home automation service (logs are meaningless for you but you can check the timestamps): [2018/07/31 06:24:51][INFO] [MQTT][RECV]403 | p==19,e==577609126.00 [2018/07/31 06:24:52][INFO] [MQTT][RECV]407 | p==18,e==61189214.00 [2018/07/31 06:25:01][INFO] [MQTT][RECV]401 | p==34,e==569947835.00 [2018/07/31 13:17:14][INFO] Service started. Version: 2.0.2 [2018/07/31 13:17:14][INFO] Connected to broker My IOT devices are sending MQTT messages to this server at least in every 10 seconds. So something happened unexpectedly as no new message arrived and no other logs are printed. The next log is at 13:17:14 stating that the script was (re)started. Just to make it clear: I haven' t touch the system at this time so it was restarted by itself. I also noticed that this restart & freeze always happens around 06:25 and 13:17. Do you see anything suspicious in the logs? Should I attach some other logs? I've backed up the entire /var/logs for investigation purposes. BTW is there any overheat protection built-in mechanism in OrangePI / armbian? Thanks!
chwe Posted July 31, 2018 Posted July 31, 2018 1 hour ago, Levente Nemeth said: MQTT messages to this server at least in every 10 seconds. does it mean that you write a small chunk of data every 10 seconds to your SD-Card? In case yes, how long does your datalogger do this? Maybe you killed your SD-Card, got some file corruption on a part which gets it daily call at this time? (just speculating). Can you describe your system as best as you can: what's connected to the board? how is it powered? Maybe some sort of watchdog realizes hours later that your kernel is in an unhealthy state and tries to reboot your board. Or it's partly messed up etc. Unexpected crash/reboot is quite often a power and/or corrupted filesystem (bad SD-Card/eMMC/NAND) issue.
WarHawk_AVG Posted August 1, 2018 Posted August 1, 2018 If it still locks up it may be running hot...you can slow down to 816MJz which will limit maximum voltage to processor lowering it's heat output...it does slow it down, but will run alot cooler. I also changed mine from ondemand to conservative, but as tkaiser said...lower cpu on reads/writes makes things slow, especially if logging data. so kicking up minimum to 480 vs 240 is best. 1
Levente Nemeth Posted August 1, 2018 Author Posted August 1, 2018 Hi, Quote Can you describe your system as best as you can: what's connected to the board? how is it powered? Physically only LAN cable is connected and nothing else. It's powered with a high quality 2A mobile charger. Quote does it mean that you write a small chunk of data every 10 seconds to your SD-Card? In case yes, how long does your datalogger do this? Maybe you killed your SD-Card, got some file corruption on a part which gets it daily call at this time? (just speculating). Yes, data is written to the SD card very often (mysql + logging to file). However I've already replaced the SD card and symptoms are the same...
tkaiser Posted August 1, 2018 Posted August 1, 2018 21 minutes ago, Levente Nemeth said: Yes, data is written to the SD card very often (mysql + logging to file) Since you seem to be fine with letting your SD card wear out way too fast you could also install RPi-Monitor which will allow you to monitor your system even after crashes (RPi-Monitor constantly writes its monitoring databases to disk/card). Installation on Armbian is a one-liner: https://www.cnx-software.com/2016/03/17/rpi-monitor-is-a-web-based-remote-monitor-for-arm-development-boards-such-as-raspberry-pi-and-orange-pi/ Info wrt 'Write amplification': Edit: Monitoring write activity at the block device layer is sudo armbianmonitor -c mmcblk0
