mikestp27 Posted March 12, 2016 Posted March 12, 2016 Hi, I'm using ARMBIAN Ubuntu 14.04.4 LTS 4.4.3-sunxi on a Cubietruck board with a battery connected. How do I setup the system to safely suspend, shutdown or hibernate when the battery power is low? Thank you very much.
luca219 Posted March 18, 2016 Posted March 18, 2016 intresting request. it's possibleAs soon as I have free time I try
luca219 Posted March 18, 2016 Posted March 18, 2016 hi , one solution is this: schedule this script every 5,10 minutes if you want mail alert need install heirloom mailx touch /root/battery_check.sh chmod +x /root/battery_check.sh crontab -e */10 * * * * /root/battery_check.sh prerequisite for mail alert apt-get install heirloom-mailx paste this in /root/check_battery.sh #!/bin/bash ###################################################################################### # SET MAIL NOTIFICATION mail_from=mail@domain.it smtp_server=smtp.server.it smtp_port=587 auth_username=mail@domain.it auth_passw=12345678 mail_to=mail2@domain.it ###################################################################################### # # Battery info # /usr/sbin/i2cset -y -f 0 0x34 0x82 0xC3 # read power OPERATING MODE register @01h POWER_OP_MODE=$(/usr/sbin/i2cget -y -f 0 0x34 0x01) BAT_EXIST=$(($(($POWER_OP_MODE&0x20))/32)) # divide by 32 is like shifting rigth 5 times CHARG_IND=$(($(($POWER_OP_MODE&0x40))/64)) # divide by 64 is like shifting rigth 6 times ######################################################################################## #read battery voltage 79h, 78h 0 mV -> 000h, 1.1 mV/bit FFFh -> 4.5045 V BAT_VOLT_LSB=$(/usr/sbin/i2cget -y -f 0 0x34 0x79) BAT_VOLT_MSB=$(/usr/sbin/i2cget -y -f 0 0x34 0x78) BAT_BIN=$(( $(($BAT_VOLT_MSB << 4)) | $(($(($BAT_VOLT_LSB & 0xF0)) >> 4)) )) BAT_VOLT=$(echo "($BAT_BIN*1.1)"|bc) # store maximum battery voltage to compare to if [ -f "/etc/default/battery" ]; then source "/etc/default/battery" else echo "MAX=$BAT_VOLT" > /etc/default/battery echo "MIN=3484" >> /etc/default/battery fi # integer is enough, cut down the decimals MAX=${MAX%.*} BAT_VOLT=${BAT_VOLT%.*} # mainline kernel shows battery existence even if not exists. this is walkaround if [ "$BAT_VOLT" -ge "3200" ]; then # if we have new max value, alter defaults if [ "$BAT_VOLT" -gt "$MAX" ]; then MAX=$BAT_VOLT sed -e 's/MAX=.*/MAX='$BAT_VOLT'/g' -i /etc/default/battery fi # if we have new min value, alter defaults if [ "$BAT_VOLT" -lt "$MIN" ]; then MIN=$BAT_VOLT sed -e 's/MIN=.*/MIN='$BAT_VOLT'/g' -i /etc/default/battery fi # calculate percentage percent=$(echo "($BAT_VOLT-$MIN)*100/($MAX-$MIN)"|bc) fi # define output format output="Load : $percent%" if [ "$percent" -gt 20 ]; then #echo $percent exit fi # if we have new min value, alter defaults if [ "$percent" -lt 20 ]; then #echo $percent # Alert shutdown mail mailx -v -r "$mail_from" -s "Cubietruck shutdown" -S smtp="$smtp_server:$smtp_port" -S smtp-use-starttls -S smtp-auth=login -S smtp-auth-user="$auth_username" -S smtp-auth-password=$auth_passw -S ssl-verify=ignore $mail_to poweroff fi
Igor Posted March 19, 2016 Posted March 19, 2016 You can simplify the script if you use newer vanilla kernels which already have this driver: http://forum.armbian.com/index.php/topic/611-wip-axp209-mainline-sysfs-interface/
mikestp27 Posted March 19, 2016 Author Posted March 19, 2016 Good morning, I'm using the latest vanilla kernel. I tested @luca219 script and it's not working... 1. The email is sent properly but the poweroff does not work. I initially thought the system was rebooting quickly but it's not the case. The script is ran by root's crontab so it should be able to poweroff. I edited the script to send a 2nd email after the poweroff and both emails are sent so the script has not crashed and the poweroff came back to the script. 2. Ignoring the poweroff issue for now, I went on and continued to another test... If I drain the battery to under 20%, the script sends an email every 10 minutes as per the cron; if I reconnect the power supply, I still get an email every 10 minutes until battery reaches 20%. But the problem is the script would trigger a poweroff when the system would reboot when the power comes back. In other words, the script needs to check if running on battery or power; if running on power, the script should not poweroff. Thank you.
mikestp27 Posted March 19, 2016 Author Posted March 19, 2016 Ok, reboot is now working... I should have thought of that sooner... Fixed the problem by using /sbin/reboot in the script. Looks like cron did not setup the path to sbin.
mikestp27 Posted March 19, 2016 Author Posted March 19, 2016 I started to look at @Igor suggestion (http://forum.armbian.com/index.php/topic/611-wip-axp209-mainline-sysfs-interface/) and it would certainly be simpler and more portable than I2C commands... However, I discovered a discrepancy between the battery percentage calculated in the script above (@luca219's) and the percentage reported by /etc/update-motd.d/30-sysinfo (which uses @Igor's suggestions). That puzzle me and I'm not sure which one is right...
tkaiser Posted March 19, 2016 Posted March 19, 2016 I discovered a discrepancy between the battery percentage calculated in the script above (@luca219's) and the percentage reported by /etc/update-motd.d/30-sysinfo (which uses @Igor's suggestions). That puzzle me and I'm not sure which one is right... That's the problem with numbers, they're most often wrong and people start only to care about it if they get different numbers for the same thing If you read through the thread you cited you might understand what the values are for.
luca219 Posted March 21, 2016 Posted March 21, 2016 hi, the code to detect the battery load is the work of Igor (present in forum), I have only adapted to the mikestp27 request.if Igor suggests using the updated one is undoubtedly the most delicious way. I use old Kernel , I can't test the operation of the new, for the moment.
tkaiser Posted March 21, 2016 Posted March 21, 2016 the code to detect the battery load is the work of Igor (present in forum), I have only adapted to the mikestp27 request. I know. And that there are discrepancies shown might be the result of the motd approach sometimes not showing actual values but ones from the past. I've been just amused by the usual way people deal with numbers. They're blindly trusted regardless of their meaning unless something seems to be totally wrong. As already written: there's an informative thread here in the forums to learn a bit about battery usage and capacity calculation.
