12 minutes ago, Jordi said:
Wow, have not tried. I'll try next monday. Thanks !!
Yeah there's something wrong with u-boot when it tries to read the edid info.
Read more about it here...
Dear friends, my system has come back to life. As I explained before, I had an armbian 5.14 Debian Jessy Desktop, and after a september 2018 update, when I rebooted the sistem, it didn't boot again. Before trying anything, I booted from a µSD and made an image of my system ( dd if=/dev/mmblck1  bs=10M  of=/mnt/pendrive/image.img ). Then I tried the solutions proposed here, but didn't work for my system. I tried copying /boot files from 5.14 distribution and from new distributions.. I tried with the files that I found on the installation without being updated and also with the updated versions, but any combination worked for me.
I don't have much idea about these issues.. but I have a friend ;) and he's a master.
My friend's first plan was related with downgrading the u-boot to an older version, but it didn't work, so I won't spent time on it.
The second plan worked! The result is not a clean installation.. but it boots.. and lets me access all my services. My server is working.. I'll install a new server on other machine with a clean installation.
The idea was :
1) Boot wit a µSD card with a new installation of 5.14 Armbian Jessy Desktop on my OrangePiPlus2
2) Move the installation to the emmc
nand-sata-install
3) Boot from emmc
4) Mark as 'hold' the packages related with the boot process (to perform an apt-get update && apt-get upgrade without affecting to these packages, because it's upgrade makes my system fail - we tried and we confirm it)
apt-mark hold linux-u-boot-orangepiplus-default
apt-mark hold uboot-tols
apt-mark hold linux-image-sun8i
5) Now yes, we can update the system
6) The system is now updated (not the packages marked as hold) and boots properly
7) Boot from the µSD in order to have complete acces to the emmc files
8) Mount the image we made at the beginning, with the old system (with all our info, but with the /boot damaged)
losetup -o 1048576 /dev/loop0 /mnt/pendrive/image.img
mnt /dev/loop0 /img/
8) And now, with rsync, we copy all the files from our old system to the new one, which is upgraded  (emmc is mounted on /media)
rsync -avpAHX --numeric-ids /img/bin/*  /media/bin
Important: don't use the -delete modifier.. we need to keep the 3.4.112 files from the new installation (the old installation was upgraded and these files were deleted!)
Repeat this rsync command with all these directories:
   bin  -   etc  -   home  -   lib  -   opt  -   root  -   sbin  -   selinux  -   srv  -   usr   -   var   -   mnt  -   media
(in other words: all but     dev  -   proc  -   run  -   sys  -   tmp)
9) Unmount everything (you'll need to execute first
losetup -d /dev/loop0
10) My friend edited the file etc/fstab file on the emmc, and he changed the mmblck1 on the first line for mmblck0     (I'm not sure it's necessary.. but he changed)
-- Added later BEGIN --
11) It's important to repeat the hold operations in order to protect the packages we don't want to be updated (the packages database has been replaced with the rsync copy)
-- Added later END --
And ... it worked !
I was really worried.. it was a pitty to loose my server..  My current installation is not clean at all.. but it works, and it allows me to run all the services to be able to do a manual migration process to a new installation.
I appreciate so much all the support you gave me on this thread.. Thanks !
Jordi, from Barcelona
same problem, it would seem that 5.60 does not work on orangepiplus.
I do not understand why putting an update without testing it first.
There was a lot of testings but they sadly didn't discover this problem.  You can improve this by joining and help testing + improve protocols + developing the project in general https://www.armbian.com/get-involved or by sponsoring https://www.armbian.com/donate and we will hire professionals (few hundred hours/release) to conduct profound testings. Nothing comes out of thin air.
Well i've finally found time to fiddle with emmc storage. Upgrade did corrupt boot script, so what i did is basically just copied everything from my usb flash to /dev/mmcblk1p1 including /boot  .. then fixed /boot/armbianEnv.txt so that root points to correct uuid and also /etc/fstab so that root fs can be mounted rw.. I also removed usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u line from armbianEnv.txt (not sure what that does, but it was not on sd card and i guess emmc isn't usb so .. ).
so basically, boot up with sd card or usb flash (i had running system on flash drive)
do
blkid
/dev/mmcblk1p1: UUID="c93833b4-8c9a-46b2-ad43-46d286ba9a10" TYPE="ext4" PARTUUID="e0788fc1-01"
to get UUID of mmcblk1p1
mkdir /tmp/mmc
mount /dev/mmcblk1p1 /tmp/mmc
rsync -avx / /tmp/mmc
vi /tmp/mmc/boot/armbianEnv.txt
change root UUID to the one of /dev/mmcblk1p1 from blkid command
save changes
vi /tmp/mmc/etc/fstab
change first line, use same UUID as above
save changes
umount /mnt/tmp
poweroff
then remove usb flash (for me) i guess sd card for you, and press reset button ..
I can confirm that 5.59 works on orangepi pc plus from emmc.
Dear All,
Does anybody have the IMAGE like one listed above: Armbian_5.30_Orangepipcplus_Debian_jessie_default_3.4.113 and could share it with me anyhow?
I have got exactly the same issue like described by  gerotm and had the very same (very old) version installed,   but i do not have the genuine image to burn it to the SD card... I have searched over the Armbian website but it seems that such old archives are not available anymore.
Normally i would not mind installing new version, but all three currently available for Orange Pi Plus result in immediate crash when I set up hostapd AP on wlan0 (integrated wifi). My OrangePi Plus serves as MPD/Shairport player and router/access point and now i cannot use it as I fail to fix the MMC boot (i tried copying the /boot from SD installed Xenial Legacy Kernel 3.4 image and changing the boot device UUID but with no success) and on the other hand I fail to configure any of new versions as wifi immediately crashes (and I mean crashes, the system reboots almost immediately)...
So please... help, if anyone has the old image of Jessie for Orange Pi Plus, please share.  It would be much appreciated. Thanks in advance :)
Edited by lukaszbzyk
added crash description
Igor, Sir... Thank you very much... You can call me an irritating idiot but I copied & pasted like a dumb and i did Armbian_5.30_Orangepipcplus_Debian_jessie_default_3.4.113 whereas i mean Armbian_5.30_Orangepiplus_Debian_jessie_default_3.4.113... for Orange Pi Plus, not Orange Pi PC Plus...  And i even wrote a word "exactly"... What a shame...
Would it be too much to ask you to take a look on tapes once again? I am very sorry...  Thanks a lot in advance...
Thank You very much! I have managed to re-install it and use successfully. I have not managed to fix the mmc boot error but at least i could mount it and copy all the config files and data, and the hostapd does not crash on this old image. Thanks a lot again!
Same issue I got today when upgrade to Armbian 5.60
As recommend I've loaded from SD card (same content as eMMC) copied /boot folder from SD to eMMC, changed rootdev UUID in armbianEnv.txt. It doesn't help.
Do I need to recompile boot.scr or something like this?
Hello!
error in build-master\config\bootscripts\boot-sunxi.cmd
missing string=setenv devnum "0"
Info take from this
http://4pda.ru/forum/index.php?showtopic=668774&view=findpost&p=78434168
good file is this (see down)
Igor!
Please make good boot-sunxi.cmd and recompile core for orange pi pc plus and pust core to repository jessy!
# DO NOT EDIT THIS FILE
# Please edit /boot/armbianEnv.txt to set supported parameters
setenv load_addr "0x44000000"
setenv overlay_error "false"
# default values
setenv verbosity "1"
setenv console "both"
setenv disp_mem_reserves "off"
setenv disp_mode "1920x1080p60"
setenv rootfstype "ext4"
setenv docker_optimizations "on"
setenv devnum "0"
setenv rootdev "/dev/mmcblk${devnum}p1"
# Print boot source
itest.b *0x28 == 0x00 && echo "U-boot loaded from SD"
itest.b *0x28 == 0x02 && echo "U-boot loaded from eMMC or secondary SD"
itest.b *0x28 == 0x03 && echo "U-boot loaded from SPI"
# get PARTUUID of first partition on SD/eMMC it was loaded from
if test "${devtype}" = "mmc"; then
  part uuid mmc ${devnum}:1 partuuid;
  setenv devnum ${mmc_bootdev}
  setenv rootdev "/dev/mmcblk${mmc_bootdev}p1"
fi
echo "Boot script loaded from ${devtype}"
if test -e ${devtype} ${devnum} ${prefix}armbianEnv.txt; then
load ${devtype} ${devnum} ${load_addr} ${prefix}armbianEnv.txt
env import -t ${load_addr} ${filesize}
fi
if test "${logo}" = "disabled"; then setenv logo "logo.nologo"; fi
if test "${console}" = "display" || test "${console}" = "both"; then setenv consoleargs "console=tty1"; fi
if test "${console}" = "serial" || test "${console}" = "both"; then setenv consoleargs "${consoleargs} console=ttyS0,115200"; fi
setenv bootargs "root=${rootdev} rootwait rootfstype=${rootfstype} ${consoleargs} hdmi.audio=EDID:0 disp.screen0_output_mode=${disp_mode} panic=10 consoleblank=0 loglevel=${verbosity} ubootpart=${partuuid} ubootsource=${devtype} ${extraargs} ${extraboardargs}"
if test "${disp_mem_reserves}" = "off"; then setenv bootargs "${bootargs} sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16"; fi
if test "${docker_optimizations}" = "on"; then setenv bootargs "${bootargs} cgroup_enable=memory swapaccount=1"; fi
load ${devtype} ${devnum} ${ramdisk_addr_r} ${prefix}uInitrd
load ${devtype} ${devnum} ${kernel_addr_r} ${prefix}zImage
if test -e ${devtype} ${devnum} "${prefix}.next"; then
echo "Found mainline kernel configuration"
load ${devtype} ${devnum} ${fdt_addr_r} ${prefix}dtb/${fdtfile}
fdt addr ${fdt_addr_r}
fdt resize 65536
for overlay_file in ${overlays}; do
if load ${devtype} ${devnum} ${load_addr} ${prefix}dtb/overlay/${overlay_prefix}-${overlay_file}.dtbo; then
echo "Applying kernel provided DT overlay ${overlay_prefix}-${overlay_file}.dtbo"
fdt apply ${load_addr} || setenv overlay_error "true"
fi
done
for overlay_file in ${user_overlays}; do
if load ${devtype} ${devnum} ${load_addr} ${prefix}overlay-user/${overlay_file}.dtbo; then
echo "Applying user provided DT overlay ${overlay_file}.dtbo"
fi
done
if test "${overlay_error}" = "true"; then
echo "Error applying DT overlays, restoring original DT"
else
if load ${devtype} ${devnum} ${load_addr} ${prefix}dtb/overlay/${overlay_prefix}-fixup.scr; then
echo "Applying kernel provided DT fixup script (${overlay_prefix}-fixup.scr)"
source ${load_addr}
fi
if test -e ${devtype} ${devnum} ${prefix}fixup.scr; then
load ${devtype} ${devnum} ${load_addr} ${prefix}fixup.scr
echo "Applying user provided fixup script (fixup.scr)"
source ${load_addr}
fi
fi
bootz ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r}
else
echo "Found legacy kernel configuration"
load ${devtype} ${devnum} ${fdt_addr_r} ${prefix}script.bin
fi
# Recompile with:
Edited by pentagon
Implemented on the build level, but for updating the repository ... we don't update boot scripts via packages updating, at least not out of the box. This part has to be done manually atm by replacing the boot script.
Thanks!
Thanks!
Can any one here put the pre compiled .scr file for OPi+2E ? Thanks in advance...
On 9/22/2018 at 8:26 PM, Igor said:
make and boot from SD card, mount eMMC and copy /boot/boot.* to your eMMC /boot section.
I can't mount the eMMC :
root@orangepiplus:~# lsblk -o model,name,type,fstype,size,label
MODEL NAME         TYPE FSTYPE  SIZE LABEL
      mmcblk1boot0 disk           4M
      mmcblk1boot1 disk           4M
      mmcblk0      disk          60G
      └─mmcblk0p1  part ext4     60G <- @ SDCard
      mmcblk1      disk         7.3G
      └─mmcblk1p1  part ext4    7.2G <- eMM
#mount /dev/mmcblk1p1 /mnt/mountpoint
[34182.366277] EXT4-fs (mmcblk1p1): couldn't mount RDWR because of unsupported optional features (400)
Is there a reason for that?
None caused by Armbian / never seen such thing. If you can't make a filesystem on eMMC, it can simply be dead.
It seems linux-u-boot-${BOARD}-next for H3 still doesn't work. I am using nanopi neo air. The logs of the default branch and the next branch are:
1. linux-u-boot-nanopiair-next (U-Boot 2019.04-armbian) can not boot from emmc.
U-Boot 2019.04-armbian (May 04 2019 - 09:12:53 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: FriendlyARM NanoPi NEO Air
DRAM:  512 MiB
MMC:   mmc@1c0f000: 0, mmc@1c10000: 1
Loading Environment from EXT4... MMC: no card present
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
No controllers found
Autoboot in 1 seconds, press <Space> to stop
Card did not respond to voltage select!
starting USB...
USB is stopped. Please issue 'usb start' first.
starting USB...
No ethernet found.
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
starting USB...
No ethernet found.
No ethernet found.
=> <INTERRUPT>
2.  linux-u-boot-nanopiair-default (U-Boot 2018.05-armbian) does work.
U-Boot 2018.05-armbian (Sep 19 2018 - 12:03:31 +0200) Allwinner Technology
DRAM:  512 MiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
** Bad device mmc 0 **
Failed (-5)
In:    serial
Out:   serial
Err:   serial
starting USB...
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
3708 bytes read in 8 ms (452.1 KiB/s)
Boot script loaded from mmc
289 bytes read in 4 ms (70.3 KiB/s)
8141541 bytes read in 634 ms (12.2 MiB/s)
7322968 bytes read in 574 ms (12.2 MiB/s)
It seems that the old u-boot, which works with emmc, only gets a CPU running. It shows on htop. How to enable / disable CPUs on mainline linux?
htop (u-boot default)
htop (u-boot next, can't boot from emmc)
  • Igor unpinned this topic
