Tested new versions ARMbian Server 5.59 Kernel 4.14 in OPI + 2.
Armbian Bionic: It starts but hangs when opening kernel.
Armbian Stretch: It works but I have not been able to change locales or keyboard language. armbian-config does not perform its function.
UN saludo.
Consider that images are tested and many people already download and use those images. How much time did you wait? (first boot needs several minutes) If this is not the case, some hardware trouble - power supply, bad or badly written SD card can be involved.
Bionic and Stretch build have the same u-boot and same kernel. If one is broken, then the other must be broken too.
