Baos Posted March 15, 2016 Posted March 15, 2016 I noticed somebody did some work. All I did was add xenial to the compile script and it went through without any errors. Impressive. Welcome to ARMBIAN Ubuntu 16.04 4.4.5-sunxiAny reason an alpha image isn't available? Would you like the one I made?
tkaiser Posted March 15, 2016 Posted March 15, 2016 I noticed somebody did some work. All I did was add xenial to the compile script and it went through without any errors. Impressive. Commit logs exist root@armbian:/var/git/Armbian/lib# git log | grep -i xenial Fix for gksu on Xenial Disable setserial on Xenial Fix FEL/NFS boot on Xenial Fix for Xenial desktop Temporary fix for Xenial Disable switching to GCC 4.9 for wily and xenial Initial support for Xenial build target Prepare Pine64 addition and Ubuntu Xenial changes This is still work in progress, please do not publish pre-release images since user feedback at this stage isn't helpful (maybe Zador corrects me but I would believe we should first test everything internally and wait for Xenial to be released) 1
Igor Posted May 3, 2016 Posted May 3, 2016 Is there an available 16.04 release? Only if you build it yourself.
dilson Posted May 4, 2016 Posted May 4, 2016 Only if you build it yourself. Is there a 'how to'? I'm very interesting in do it, but I have a little experience with cubietruck e sunxi.
