jscax Posted October 5, 2018 Posted October 5, 2018 I can't make bluetooth work on my OPi0+ Is it a known bug? Am I doing it wrong? thank you
martinayotte Posted October 5, 2018 Posted October 5, 2018 Since most people doesn't care about Bluetooth, no developer took time to add it in device-tree ...
jscax Posted October 5, 2018 Author Posted October 5, 2018 5 hours ago, martinayotte said: Since most people doesn't care about Bluetooth, no developer took time to add it in device-tree ... I would use it for a temperature + humidity sensor
jscax Posted November 12, 2018 Author Posted November 12, 2018 On 10/5/2018 at 3:39 PM, martinayotte said: Since most people doesn't care about Bluetooth, no developer took time to add it in device-tree ... Pardon my huge ignorance. I think I'm not understanding the whole context Armbian vs OrangePI. OrangePI is selling PiZero Plus with bluetooth hardware built-in but is not delivering the driver to make it works, correct? This: https://github.com/orangepi-xunlong/OrangePiH5_kernel/tree/master/drivers/bluetooth is not something useful, correct? I'd like to have BT working. I bought OPI0+ for BT feature which I was missing on OPI0 and I did not consider that it shouldn't work. Can you please point me the direction to have BT working on OPI0+?
githubetc Posted November 22, 2018 Posted November 22, 2018 On 11/12/2018 at 10:54 AM, jscax said: Pardon my huge ignorance. I think I'm not understanding the whole context Armbian vs OrangePI. OrangePI is selling PiZero Plus with bluetooth hardware built-in but is not delivering the driver to make it works, correct? This: https://github.com/orangepi-xunlong/OrangePiH5_kernel/tree/master/drivers/bluetooth is not something useful, correct? I'd like to have BT working. I bought OPI0+ for BT feature which I was missing on OPI0 and I did not consider that it shouldn't work. Can you please point me the direction to have BT working on OPI0+? (1) You can reduce your ignorance about "Armbian vs Orangepi" by spending time reading both websites and doing some google searches. (2) Where does it say that Orange Pi Zero Plus has this bluetooth feature you bought it for ?https://www.aliexpress.com/store/product/Orange-Pi-Zero-Plus-H5-Chip-Quad-Core-Open-source-Cortex-A53-512MB-development-board-beyond/1553371_32828347476.html (3) How much have you invested in Armbian so far ? Instead of demanding support here because you paid a few dollars to Someone Else for this bluetooth feature of yours, you should be grateful that you can use Armbian for free.
thc013 Posted November 26, 2018 Posted November 26, 2018 install dev2mem and adjust and make /etc/init.d/ap6212-bluetooth look like this comment out the copy firmware and adjust the rest works for me can change with kernel updates # copy firmware #if [ -f "/lib/firmware/ap6212/bcm43438a0.hcd" ] && [ ! -f /etc/firmware/ap6212/4343A0.hcd ]; then # mkdir -p /etc/firmware/ap6212 # cp /lib/firmware/ap6212/bcm43438a0.hcd /etc/firmware/ap6212/4343A0.hcd #fi #if [ -f "/lib/firmware/ap6212/bcm43438a1.hcd" ] && [ ! -f /etc/firmware/ap6212/BCM43430A1.hcd ]; then # mkdir -p /etc/firmware/ap6212 # cp /lib/firmware/ap6212/bcm43438a1.hcd /etc/firmware/ap6212/BCM43430A1.hcd #fi . /lib/lsb/init-functions do_start () { if [ ! -z $(hciconfig | /bin/grep UART | /usr/bin/cut -d: -f1) ] then echo "ap6212 BT device allready initialized" hcitool dev else # Select MAC address if [ -z "$MAC_ADDR" ]; then MAC_OPTIONS="11:22:33:44:55:66" else MAC_OPTIONS="$MAC_ADDR" fi # Select tty port if [ -z "$PORT" ]; then log_warning_msg "No PORT set in /etc/default/ap6212, will use ttyS1" PORT="ttyS1" fi # Start patching rfkill unblock all echo "0" > /sys/class/rfkill/rfkill0/state echo "1" > /sys/class/rfkill/rfkill0/state #on orangepi win following command never ends on first try... force to run with a timeout... timeout 5s echo " " > /dev/$PORT #if [ $? != 0 ]; then # #timed out... retry # echo " " > /dev/$PORT #fi devmem2 0x1f00060 b 1 echo 10 > /sys/class/gpio/export echo out > /sys/class/gpio/gpio10/direction echo 0 > /sys/class/gpio/gpio10/value echo 1 > /sys/class/gpio/gpio10/value sleep 0.1 hciattach /dev/$PORT bcm43xx 115200 flow bdaddr $MAC_OPTIONS hciconfig hci0 up fi }
data Posted November 27, 2018 Posted November 27, 2018 What about the dts/dtb? Is the according uart declared in current builds?
martinayotte Posted November 27, 2018 Posted November 27, 2018 40 minutes ago, data said: Is the according uart declared in current builds UARTs in most of AllWinner SoC boards are enabled using DT overlays ... You need to add to /boot/armbianEnv.txt line like "overlays=uart1 uart2 uart3" and reboot.
