Odroid C2: next and dev kernels do recognize USB hard-drives
The stable kernel does.
Kernel configuration issue?
I've just upgrade my NanoPi-K2, not upgraded since almost a year, with fresh build 4.18.12 ...
To my surprise, USB dongle was not appearing while doing "lsusb" !
Search on google with some warning seen in "dmesg", I found this unresolved thread : https://www.spinics.net/lists/linux-usb/msg168724.html
Doing the same workaround that the guy explain, doing "lsusb -v", make the dongle appearing ...
Strange issue ! Maybe you should try that too ...
EDIT : doing "ls usb -v" workaround is effectively working ...
And strangely, if a dongle is already present, adding another one doesn't require to do a "lsusb -v" again. It is only required when USB hub is empty ...
I have seen them not recognize devices if they weren't plugged in on boot, but I haven't gotten into it uet
Hi Tony,
Some more details of my previous EDIT have been lost during previous EDIT. I added them again : if "lsusb -v" make devices appears, then any new USB hot-plug is successfull, the bug is only related on the first hot-plug ...
23 minutes ago, TonyMac32 said:
There's been a lot of mess around dwc2/dwc3 in general.
Probably ... It wasn't an issue in my previous K2 4.13.2 from a year ago ...
