dvachon Posted November 2, 2018 Posted November 2, 2018 Hello, running ARMBIAN 5.59 stable Debian GNU/Linux 9 (stretch) 4.14.65-sunxi on Banana Pi pro /var/log is always full df -h /dev/zram0 49M 48M 0 100% /var/log root@mail:/etc# zramctl NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram0 lz4 50M 47.5M 7.8M 8.4M 2 /var/log /dev/zram1 lz4 249.7M 4K 63B 4K 2 [SWAP] /dev/zram2 lz4 249.7M 4K 61B 4K 2 [SWAP] Since i am running on sata (ssd of 128gig) i dont need that. Cannot find how to stop the mount of /var/log on /dev/zram0. Not in fstab. Want to use the real /var/log from / (root).
umiddelb Posted November 2, 2018 Posted November 2, 2018 5 hours ago, dvachon said: Hello, running ARMBIAN 5.59 stable Debian GNU/Linux 9 (stretch) 4.14.65-sunxi on Banana Pi pro /var/log is always full df -h /dev/zram0 49M 48M 0 100% /var/log You can disable logging to ram by setting `ENABLED=false´ in `/etc/default/armbian-ramlog´. 1
Tido Posted November 2, 2018 Posted November 2, 2018 5 hours ago, dvachon said: /dev/zram0 49M 48M 0 100% /var/log an interesting case, can you please send: armbianmonitor -u AND explain what services/programs you are running on your device ? thank you
gas_85 Posted November 2, 2018 Posted November 2, 2018 21 hours ago, dvachon said: Since i am running on sata (ssd of 128gig) i dont need that. Cannot find how to stop the mount of /var/log on /dev/zram0. Not in fstab. Want to use the real /var/log from / (root). How to disable it correctly: Only config edit will not give you correct effect.
splite Posted November 20, 2018 Posted November 20, 2018 I'm experimenting the same issue with a lot of devices, the 50Mo get filled up very quickly. Most of the time, nginx logs are responsible of that, but also hostapd in some case the wifi dongle is not present. This is very very annoying as the server can not work properly after the log folder is full. The only way is to move/remove files. I removed log2ram, but as I understand zram does the same !!
martinayotte Posted November 20, 2018 Posted November 20, 2018 Another possible workaround is to have a "crontab" job that delete or truncate files regularly ...
Set3 Posted March 10, 2019 Posted March 10, 2019 Hi martinayotte On 11/20/2018 at 9:01 PM, martinayotte said: Another possible workaround is to have a "crontab" job that delete or truncate files regularly ... On var/log and var/log/.hdd : Done that, every hour, it works, obviously :-) . also using sed to remove the "IR event FIFO is full" lines But now, for a while or perhaps since then, my warning system, based on what df under /var/log reports gives false warnings : df misreports the real size eg : in WinSCP, the calculate button says 2.2MB, where df says 75% of 50MB Perhaps the varlog scripts are not happy with the delete/modify ? Reboot repairs the mismatch Edit : Moved to using du iso df, du is reporting correctly. so that is solved, but perhaps a point of attention for the developers ?
fvgenn Posted October 4, 2019 Posted October 4, 2019 Hello! How could it be? zram is full, but /var/log is empty. I think this happened when once the log was full and I deleted a large file. How to fix it without rebooting? ======================================================================================== root@hms:/var# uname -a Linux hms 4.19.20-sunxi #5.75 SMP Sat Feb 9 19:02:47 CET 2019 armv7l armv7l armv7l GNU/Linux root@hms:/var# zramctl NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram4 lzo 121,1M 4K 78B 12K 4 [SWAP] /dev/zram3 lzo 121,1M 4K 78B 12K 4 [SWAP] /dev/zram2 lzo 121,1M 4K 78B 12K 4 [SWAP] /dev/zram1 lzo 121,1M 4K 78B 12K 4 [SWAP] /dev/zram0 50M 43,8M 7,8M 8,7M 4 /var/log root@hms:/var# df /var/log Filesystem 1K-blocks Used Available Use% Mounted on /dev/zram0 49584 44780 1220 98% /var/log root@hms:/var# du -k /var/log 12 /var/log/motion 4 /var/log/samba/cores/winbindd 4 /var/log/samba/cores/smbd 4 /var/log/samba/cores/nmbd 16 /var/log/samba/cores 28 /var/log/samba 4 /var/log/apache2 4 /var/log/apt 4 /var/log/unattended-upgrades 56 /var/log
fvgenn Posted October 4, 2019 Posted October 4, 2019 Got it. Looks like a bug lsof | grep /var/log ...... rsyslogd 1051 syslog 7w REG 254,0 18268 29 /var/log/syslog (deleted) rsyslogd 1051 syslog 8w REG 254,0 0 26 /var/log/kern.log (deleted) rsyslogd 1051 syslog 9w REG 254,0 44234481 22 /var/log/auth.log (deleted) in:imuxso 1051 1811 syslog 7w REG 254,0 18268 29 /var/log/syslog (deleted) in:imuxso 1051 1811 syslog 8w REG 254,0 0 26 /var/log/kern.log (deleted) in:imuxso 1051 1811 syslog 9w REG 254,0 44234481 22 /var/log/auth.log (deleted) in:imklog 1051 1812 syslog 7w REG 254,0 18268 29 /var/log/syslog (deleted) in:imklog 1051 1812 syslog 8w REG 254,0 0 26 /var/log/kern.log (deleted) in:imklog 1051 1812 syslog 9w REG 254,0 44234481 22 /var/log/auth.log (deleted) rs:main 1051 1813 syslog 7w REG 254,0 18268 29 /var/log/syslog (deleted) rs:main 1051 1813 syslog 8w REG 254,0 0 26 /var/log/kern.log (deleted) rs:main 1051 1813 syslog 9w REG 254,0 44234481 22 /var/log/auth.log (deleted) .... Perhaps, truncating the logs not syncronizeded properly with rsyslogd ... File i removed not from this list. restarting rsyslogd service solved the problem
