rahulvermag4 Posted November 13, 2018 Share Posted November 13, 2018 RTL8211D PHY on OrangePi Prime is not detected neigther in uBoot mode or Kernel mode. Will share the logs ASAP. Please suggest! Link to comment Share on other sites More sharing options...
Tido Posted November 13, 2018 Share Posted November 13, 2018 please do: armbianmonitor -u Link to comment Share on other sites More sharing options...
rahulvermag4 Posted November 17, 2018 Author Share Posted November 17, 2018 NetworkManager[667]: <info> [1542439328.9887] device (eth0): Activation: starting connection 'Realtek Eth' (34202701-37a2-436f-87de-8c511428f183) Nov 17 07:22:08 OrangePiRahul NetworkManager[667]: <info> [1542439328.9907] audit: op="connection-activate" uuid="34202701-37a2-436f-87de-8c511428f183" name="Realtek Eth" pid=4447 uid=1000 result="success" Nov 17 07:22:08 OrangePiRahul NetworkManager[667]: <info> [1542439328.9971] device (eth0): state change: disconnected -> prepare (reason 'none') [30 40 0] Nov 17 07:22:09 OrangePiRahul kernel: [ 1006.603011] dwmac-sun8i 1c30000.ethernet eth0: Could not attach to PHY Nov 17 07:22:09 OrangePiRahul kernel: [ 1006.603039] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) Nov 17 07:22:09 OrangePiRahul NetworkManager[667]: <info> [1542439329.0105] device (eth0): state change: prepare -> config (reason 'none') [40 50 0] Nov 17 07:22:09 OrangePiRahul NetworkManager[667]: <info> [1542439329.0213] device (eth0): state change: config -> failed (reason 'config-failed') [50 120 4] Nov 17 07:22:09 OrangePiRahul kernel: [ 1006.627186] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready Nov 17 07:22:09 OrangePiRahul NetworkManager[667]: <info> [1542439329.0236] policy: disabling autoconnect for connection 'Realtek Eth'. Nov 17 07:22:09 OrangePiRahul NetworkManager[667]: <warn> [1542439329.0261] device (eth0): Activation: failed for connection 'Realtek Eth' Nov 17 07:22:09 OrangePiRahul NetworkManager[667]: <info> [1542439329.0430] device (eth0): state change: failed -> disconnected (reason 'none') [120 30 0] Link to comment Share on other sites More sharing options...
rahulvermag4 Posted November 17, 2018 Author Share Posted November 17, 2018 Okay Link to comment Share on other sites More sharing options...
rahulvermag4 Posted November 17, 2018 Author Share Posted November 17, 2018 On 11/13/2018 at 11:35 AM, Tido said: please do: armbianmonitor -u Hi Tido, I have run armbianmonitor -u Logs attached and uploaded to http://ix.io/1sbe Also I have attached the file test.log Link to comment Share on other sites More sharing options...
Igor Posted November 17, 2018 Share Posted November 17, 2018 Where is armbianmonitor -u that we can place those logs into some context? Also try this: Link to comment Share on other sites More sharing options...
rahulvermag4 Posted November 26, 2018 Author Share Posted November 26, 2018 On 11/17/2018 at 1:20 PM, Igor said: Where is armbianmonitor -u that we can place those logs into some context? Also try this: I have run armbianmonitor -u please check and what may be the issue. Wifi Is working fine but Ethernet is not. One more Question how much time it will take the armbian to be stable for OrangePi Prime ? Link to comment Share on other sites More sharing options...
Igor Posted November 26, 2018 Share Posted November 26, 2018 48 minutes ago, rahulvermag4 said: Wifi Is working fine but Ethernet is not. We have a test report which shows that there is nothing wrong: https://github.com/armbian/testings/blob/master/orangepiprime-next.report 48 minutes ago, rahulvermag4 said: how much time it will take the armbian to be stable for OrangePi Prime ? Until development and answering to this questions goes directly from our pocket in 99% ... It is done when it's done. In case this is not fast enough, grab sources / build system https://github.com/armbian/build and fix the problem. Our resources are super tiny. Since we don't have this problem, I highly suspect something related to your hardware, PSU, cabling. Check here for some clues: https://forum.armbian.com/forum/31-sd-card-and-power-supply/ Link to comment Share on other sites More sharing options...
