I would like to run my NanoPi M4 from an external USB3 SSD.
Does anybody know if the images here:
http://wiki.friendlyarm.com/wiki/index.php/NanoPi_M4#Work_with_FriendlyCore
Will work? Or are they specifically for SD or eMMC?
If they won't work, how do I modify to make it work?
Many thanks!
M
53 minutes ago, mio75 said:
Many thanks!
M
Without eMMC/SD card as boot device its not possible. Not Armbian and not their builds.
Armbian works out of the box. Just do your homework: https://docs.armbian.com/User-Guide_Getting-Started/
you could ask the threadstarter of the following thread:
he do boot from sdcard and then change the rootfs to a
usb 3.0 device - but you cant boot directly from usb 3.0
Yep. nand-to-sata-install works pretty good.
