Hi Guys,
i am owner of this box and i wanted to ask you if anyone is intressted in getting armbian running on it. Dissasambly does not look to be a big problem.
and here are som pictures:
https://forum.freaktab.com/forum/tv-player-support/allwinner-tv-players/679476-beelink-gs1-6k-tv-box-allwinner-h6-android-7-1-bt4-1-1000m-lan-usb-3-0-media-player-2gb-ram-16gb-rom
from the pictures i cannot tell were the uart pins are, anyone can ?
from user froezus post
I have tried to boot the OrangePi One Plus image on my Beelink GS1, but either the UART is bad configured or I have damaged the TXD pin :'(.
I can't stop the U-boot nor enter a login.
bootlog : https://pastebin.com/Rd2EEduZ
I try to get some information from the
sys_config.fex (from gs1_rv106N0.img): https://pastebin.com/TdnfRMJL
reverse dts: https://pastebin.com/jK2zhGAe
Everything seems correct so maybe I have damaged the TXD pin.
Do you think there is lot of work to make ethernet/ssh works one my board ?
Thanks,
Clement
he found a way to get uart output but no anwser yet were this uart pins are, it looks like we already have some device treefiels her and a bootlog.
anyone can help, i am here for test
many thanks
Krachlatte
Sorry for the delay, didn't see this post and I was quite busy with my other boards.
There has been many improvement on the upstream for the H6 and Cedrus is comming in 5.2. I will give it another try soon.
For the UART you can spot it quite easily on the corner of the board.
Regards,
Clement
In Android u-boot, some providers block the ability to stop startup.
It would be interesting to see the UART log when trying to run Armbian from SD card. I am interested in whether the u-boot from eMMC is interrupted and control is transferred to u-boot from SD card or not.
I reached the Linux console and can't input the login :'(.
I will try to make the ethernet/ssh work.
Monitor output (HDMI) not working ? Reaction to keystrokes (for example, the Capslock key changes the state of the indicator) on a conventional keyboard connected via USB is  (After starting Armbian and prompted to log) ? I see that runs u-boot assembled in Armbian from SD card. If you press and hold (do not release during u-boot) the space bar or enter key before turning on the power and after starting u-boot, is there a reaction ?
Sadly Ethernet still doesn't works :(,  if someone wants to help: https://github.com/clementperon/linux/commits/beelink_gs1
What's seems to work right now: UART, USB2 and USB3 ports, IR, eMMC and SDCARD
U-Boot 2019.04-rc4 (Apr 02 2019 - 00:02:37 +0200) Allwinner Technology
CPU:   Allwinner H6 (SUN50I)
Model: Beelink GS1
DRAM:  2 GiB
MMC:   mmc@4020000: 0
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
Net:   No ethernet found.
starting USB...
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
139 bytes read in 3 ms (44.9 KiB/s)
1:      linux
Retrieving file: /Image
20886016 bytes read in 2094 ms (9.5 MiB/s)
append: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootwait
Retrieving file: /sun50i-h6-beelink-gs1.dtb
15447 bytes read in 6 ms (2.5 MiB/s)
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Device Tree to 0000000049ff9000, end 0000000049fffc56 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.1.0-rc1 (clement@clement-VirtualBox) (gcc version 7.4.0 (Buildroot 2019.05-git-00426-g7902f540b8-dirty)) #11 SMP PREEMPT Wed Apr 3 15:30:57 CEST 2019
[    0.000000] Machine model: Beelink GS1
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 32 MiB at 0x00000000be000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xbdbe6840-0xbdbe7fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0xa8/0x470 with crng_init=0
[    0.000000] percpu: Embedded 23 pages/cu @(____ptrval____) s56664 r8192 d29352 u94208
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootwait
[    0.000000] Memory: 2006044K/2097152K available (11644K kernel code, 1708K rwdata, 5556K rodata, 1408K init, 448K bss, 58340K reserved, 32768K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000474] Console: colour dummy device 80x25
[    0.000548] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000559] pid_max: default: 32768 minimum: 301
[    0.000642] LSM: Security Framework initializing
[    0.001482] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.001902] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.001942] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.001963] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.002405] *** VALIDATE proc ***
[    0.002582] *** VALIDATE cgroup1 ***
[    0.002590] *** VALIDATE cgroup2 ***
[    0.024043] ASID allocator initialised with 32768 entries
[    0.032040] rcu: Hierarchical SRCU implementation.
[    0.041283] EFI services will not be available.
[    0.048074] smp: Bringing up secondary CPUs ...
[    0.080492] Detected VIPT I-cache on CPU1
[    0.080543] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.112432] Detected VIPT I-cache on CPU2
[    0.112463] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.144480] Detected VIPT I-cache on CPU3
[    0.144509] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.144580] smp: Brought up 1 node, 4 CPUs
[    0.144598] SMP: Total of 4 processors activated.
[    0.144606] CPU features: detected: 32-bit EL0 Support
[    0.144613] CPU features: detected: CRC32 instructions
[    0.145010] CPU: All CPU(s) started at EL2
[    0.145030] alternatives: patching kernel code
[    0.146772] devtmpfs: initialized
[    0.150495] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.150547] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.151909] pinctrl core: initialized pinctrl subsystem
[    0.153387] DMI not present or invalid.
[    0.153889] NET: Registered protocol family 16
[    0.154279] audit: initializing netlink subsys (disabled)
[    0.154417] audit: type=2000 audit(0.152:1): state=initialized audit_enabled=0 res=1
[    0.155824] cpuidle: using governor menu
[    0.156130] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.156140] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.157540] DMA: preallocated 256 KiB pool for atomic allocations
[    0.158927] Serial: AMBA PL011 UART driver
[    0.179151] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.179165] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.179172] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.179179] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.179680] cryptd: max_cpu_qlen set to 1000
[    0.180525] ACPI: Interpreter disabled.
[    0.182329] vgaarb: loaded
[    0.182642] SCSI subsystem initialized
[    0.183139] usbcore: registered new interface driver usbfs
[    0.183193] usbcore: registered new interface driver hub
[    0.183257] usbcore: registered new device driver usb
[    0.184013] pps_core: LinuxPPS API ver. 1 registered
[    0.184020] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.184044] PTP clock support registered
[    0.184190] EDAC MC: Ver: 3.0.0
[    0.188925] Advanced Linux Sound Architecture Driver Initialized.
[    0.189683] clocksource: Switched to clocksource arch_sys_counter
[    0.189845] VFS: Disk quotas dquot_6.6.0
[    0.189901] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.189945] *** VALIDATE hugetlbfs ***
[    0.190108] pnp: PnP ACPI: disabled
[    0.197318] NET: Registered protocol family 2
[    0.198379] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
[    0.198528] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.198706] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    0.198972] TCP: Hash tables configured (established 16384 bind 16384)
[    0.199083] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.199143] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.199318] NET: Registered protocol family 1
[    0.199714] RPC: Registered named UNIX socket transport module.
[    0.199720] RPC: Registered udp transport module.
[    0.199725] RPC: Registered tcp transport module.
[    0.199729] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.200442] kvm [1]: IPA Size Limit: 40bits
[    0.201250] kvm [1]: vgic interrupt IRQ1
[    0.201359] kvm [1]: Hyp mode initialized successfully
[    0.208317] Initialise system trusted keyrings
[    0.208453] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[    0.216358] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.217134] NFS: Registering the id_resolver key type
[    0.217159] Key type id_resolver registered
[    0.217165] Key type id_legacy registered
[    0.217177] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.217340] 9p: Installing v9fs 9p2000 file system support
[    0.222828] Key type asymmetric registered
[    0.222841] Asymmetric key parser 'x509' registered
[    0.222906] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.222916] io scheduler mq-deadline registered
[    0.222922] io scheduler kyber registered
[    0.224429] sun50i-de2-bus 1000000.display-engine: Error couldn't map SRAM to device
[    0.225272] sun4i-usb-phy 5100400.phy: failed to get clock usb0_phy
[    0.225641] sun50i-usb3-phy 5210000.phy: failed to get phy clock
[    0.232961] sun50i-h6-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
[    0.236508] EINJ: ACPI disabled.
[    0.250354] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.252992] SuperH (H)SCI(F) driver initialized
[    0.253540] msm_serial: driver initialized
[    0.254642] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.261624] loop: module loaded
[    0.266270] libphy: Fixed MDIO Bus: probed
[    0.266855] tun: Universal TUN/TAP device driver, 1.6
[    0.267817] thunder_xcv, ver 1.0
[    0.267876] thunder_bgx, ver 1.0
[    0.267922] nicpf, ver 1.0
[    0.268518] hclge is initializing
[    0.268528] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.268534] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.268605] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    0.268612] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.268663] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[    0.268669] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.268715] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    0.268721] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.269065] sky2: driver version 1.30
[    0.269884] VFIO - User Level meta-driver version: 0.3
[    0.272553] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.272566] ehci-pci: EHCI PCI platform driver
[    0.272611] ehci-platform: EHCI generic platform driver
[    0.272837] ehci-platform 5101000.usb: EHCI Host Controller
[    0.272865] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 1
[    0.273284] ehci-platform 5101000.usb: irq 18, io mem 0x05101000
[    0.285696] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00
[    0.286352] hub 1-0:1.0: USB hub found
[    0.286383] hub 1-0:1.0: 1 port detected
[    0.286812] ehci-orion: EHCI orion driver
[    0.287014] ehci-exynos: EHCI EXYNOS driver
[    0.287117] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.287144] ohci-pci: OHCI PCI platform driver
[    0.287221] ohci-platform: OHCI generic platform driver
[    0.287422] ohci-platform 5101400.usb: Generic Platform OHCI controller
[    0.287442] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 2
[    0.287734] ohci-platform 5101400.usb: irq 19, io mem 0x05101400
[    0.350372] hub 2-0:1.0: USB hub found
[    0.350404] hub 2-0:1.0: 1 port detected
[    0.350998] ohci-exynos: OHCI EXYNOS driver
[    0.351730] usbcore: registered new interface driver usb-storage
[    0.354805] i2c /dev entries driver
[    0.355345] sun50i-h6-r-pinctrl 7022000.pinctrl: 7022000.pinctrl supply vcc-pl not found, using dummy regulator
[    0.356124] axp20x-i2c 0-0036: AXP20x variant AXP806 found
[    0.360963] dcdca: supplied by vcc-5v
[    0.362052] dcdcc: supplied by vcc-5v
[    0.362685] dcdcd: supplied by vcc-5v
[    0.363142] vdd-sys: Bringing 900000uV into 960000-960000uV
[    0.363612] dcdce: supplied by vcc-5v
[    0.364202] aldo1: supplied by vcc-5v
[    0.364796] aldo2: supplied by vcc-5v
[    0.365271] vcc-ac200: Bringing 700000uV into 3300000-3300000uV
[    0.365753] aldo3: supplied by vcc-5v
[    0.366209] vcc25-dram: Bringing 700000uV into 3300000-3300000uV
[    0.473869] bldo1: supplied by vcc-5v
[    0.474907] bldo2: supplied by vcc-5v
[    0.475529] bldo3: supplied by vcc-5v
[    0.475985] vcc-dcxoio: Bringing 700000uV into 1800000-1800000uV
[    0.476745] bldo4: supplied by vcc-5v
[    0.477340] cldo1: supplied by vcc-5v
[    0.477965] cldo2: supplied by vcc-5v
[    0.478417] vcc-wifi-1: Bringing 700000uV into 3300000-3300000uV
[    0.479188] cldo3: supplied by vcc-5v
[    0.479639] vcc-wifi-2: Bringing 700000uV into 3300000-3300000uV
[    0.480431] sw: supplied by regulator-dummy
[    0.480626] axp20x-i2c 0-0036: AXP20X driver loaded
[    0.485379] sdhci: Secure Digital Host Controller Interface driver
[    0.485390] sdhci: Copyright(c) Pierre Ossman
[    0.485892] Synopsys Designware Multimedia Card Interface Driver
[    0.486897] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.488691] ledtrig-cpu: registered to indicate activity on CPUs
[    0.490228] usbcore: registered new interface driver usbhid
[    0.490237] usbhid: USB HID core driver
[    0.493725] NET: Registered protocol family 17
[    0.493916] 9pnet: Installing 9P2000 support
[    0.493975] Key type dns_resolver registered
[    0.494628] registered taskstats version 1
[    0.494635] Loading compiled-in X.509 certificates
[    0.513477] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[    0.514525] sun50i-h6-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-ph not found, using dummy regulator
[    0.514995] printk: console [ttyS0] disabled
[    0.535957] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 14, base_baud = 1500000) is a 16550A
[    1.709516] printk: console [ttyS0] enabled
[    1.714999] sun50i-h6-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-pg not found, using dummy regulator
[    1.751269] 5000400.serial: ttyS1 at MMIO 0x5000400 (irq = 15, base_baud = 1500000) is a 16550A
[    1.762842] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.768369] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
[    1.776564] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f064 hci version 0x100 quirks 0x0000000002010010
[    1.786017] xhci-hcd xhci-hcd.0.auto: irq 20, io mem 0x05200000
[    1.792706] hub 3-0:1.0: USB hub found
[    1.796501] hub 3-0:1.0: 1 port detected
[    1.800706] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.806212] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
[    1.813876] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0  SuperSpeed
[    1.820539] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.829118] hub 4-0:1.0: USB hub found
[    1.832901] hub 4-0:1.0: 1 port detected
[    1.838523] ohci-platform: probe of 5311400.usb failed with error -22
[    1.846723] usb_phy_generic usb_phy_generic.1.auto: usb_phy_generic.1.auto supply vcc not found, using dummy regulator
[    1.858083] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[    1.863841] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 5
[    1.872252] hub 5-0:1.0: USB hub found
[    1.876046] hub 5-0:1.0: 1 port detected
[    1.882014] sun50i-h6-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-pf not found, using dummy regulator
[    1.892706] sunxi-mmc 4020000.mmc: Got CD GPIO
[    1.922582] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    1.933206] sun50i-h6-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-pc not found, using dummy regulator
[    1.967481] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    1.976852] sun50i-h6-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-pd not found, using dummy regulator
[    1.986882] vcc-gmac-3v3: supplied by vcc-ac200
[    1.991989] hctosys: unable to open rtc device (rtc0)
[    1.997429] vdd-gpu: disabling
[    2.000823] vcc-gmac-3v3: disabling
[    2.001630] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.004319] ALSA device list:
[    2.004322]   No soundcards found.
[    2.019149] Waiting for root device /dev/mmcblk0p2...
[    2.024150] mmc0: new high speed SDHC card at address aaaa
[    2.030883] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    2.040725]  mmcblk0: p1 p2
[    2.058208] random: fast init done
[    2.065474] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.073624] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    2.083900] devtmpfs: mounted
[    2.087576] Freeing unused kernel memory: 1408K
[    2.109718] Run /sbin/init as init process
[    2.185864] mmc1: new DDR MMC card at address 0001
[    2.191837] mmcblk1: mmc1:0001 NCard  14.5 GiB
[    2.197136] mmcblk1boot0: mmc1:0001 NCard  partition 1 4.00 MiB
[    2.203800] mmcblk1boot1: mmc1:0001 NCard  partition 2 4.00 MiB
[    2.218909] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    2.220179]  mmcblk1: p1 p2 p3 < p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 >
[    2.231529] mmcblk1: p1 size 25026560 extends beyond EOD, truncated
Starting syslogd: OK
Starting klogd: OK
Starting mdev...
[    3.255114] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[    3.365896] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 0)
[    3.374879] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
[    3.382115] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
[    3.389343] dwmac-sun8i 5020000.ethernet: COE Type 2
[    3.394320] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
[    3.401110] dwmac-sun8i 5020000.ethernet: Normal descriptors
[    3.406781] dwmac-sun8i 5020000.ethernet: Chain mode enabled
[    3.412605] libphy: stmmac: probed
[    3.458621] Registered IR keymap rc-empty
[    3.465382] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0
[    3.472335] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input0
[    3.480138] sunxi-ir 7040000.ir: initialized sunXi IR driver
[    3.582329] WARNING: CPU: 1 PID: 1677 at drivers/clk/sunxi-ng/ccu_common.c:41 ccu_helper_wait_for_lock.part.0+0x94/0xb0
[    3.593101] Modules linked in: sun8i_mixer(+) sunxi_cir rc_core sun8i_drm_hdmi dw_hdmi realtek dwmac_sun8i stmmac_platform stmmac sun4i_drm sun4i_frontend sun4i_tcon sun8i_tcon_top drm_kms_helper drm e
[    3.614473] CPU: 1 PID: 1677 Comm: modprobe Not tainted 5.1.0-rc1 #11
[    3.620902] Hardware name: Beelink GS1 (DT)
[    3.625081] pstate: 40000005 (nZcv daif -PAN -UAO)
[    3.629868] pc : ccu_helper_wait_for_lock.part.0+0x94/0xb0
[    3.635346] lr : ccu_helper_wait_for_lock.part.0+0x44/0xb0
[    3.640821] sp : ffff000014543640
[    3.644131] x29: ffff000014543640 x28: ffff000008d242d0
[    3.649437] x27: ffff80007a9e0280 x26: 0000000000000100
[    3.654742] x25: 0000000000000001 x24: ffffffffffffffff
[    3.660048] x23: ffff0000113d09b8 x22: ffff0000112cd6c8
[    3.665354] x21: 0000000010000000 x20: 00000000d56a9d44
[    3.670658] x19: 0000000000001801 x18: 0000000000000019
[    3.675964] x17: 0000000000000001 x16: 0000000000000000
[    3.681269] x15: 0000000000000000 x14: 0000000000000000
[    3.686574] x13: 0000000000000001 x12: 0000000000a434e2
[    3.691880] x11: 0000000000000000 x10: 0000000000000980
[    3.697186] x9 : ffff0000145434b0 x8 : ffff80007abc3320
[    3.702491] x7 : 000080006c8ed000 x6 : 000000000d8223d4
[    3.707797] x5 : 00ffffffffffffff x4 : 00229219019e1000
[    3.713102] x3 : 0000000000000018 x2 : 000000000000062c
[    3.718408] x1 : 0000000029aaaaab x0 : 00000000d56bba19
[    3.723713] Call trace:
[    3.726159]  ccu_helper_wait_for_lock.part.0+0x94/0xb0
[    3.731291]  ccu_helper_wait_for_lock+0x10/0x20
[    3.735818]  ccu_nkmp_set_rate+0x240/0x2c0
[    3.739911]  clk_change_rate+0x144/0x2a0
[    3.743829]  clk_core_set_rate_nolock+0x1b4/0x1f0
[    3.748527]  clk_set_rate+0x38/0xb0
[    3.752021]  sun8i_mixer_bind+0x478/0x580 [sun8i_mixer]
[    3.757242]  component_bind_all+0xf8/0x290
[    3.761337]  sun4i_drv_bind+0xac/0x190 [sun4i_drm]
[    3.766122]  try_to_bring_up_master+0x17c/0x1e0
[    3.770646]  __component_add+0xa8/0x180
[    3.774476]  component_add+0x10/0x20
[    3.778052]  sun8i_mixer_probe+0x18/0x20 [sun8i_mixer]
[    3.783184]  platform_drv_probe+0x50/0xa0
[    3.787189]  really_probe+0x20c/0x2c0
[    3.790846]  driver_probe_device+0x58/0x110
[    3.795024]  device_driver_attach+0x6c/0x90
[    3.799202]  __driver_attach+0x84/0xd0
[    3.802948]  bus_for_each_dev+0x74/0xd0
[    3.806781]  driver_attach+0x20/0x30
[    3.810354]  bus_add_driver+0x148/0x200
[    3.814186]  driver_register+0x60/0x110
[    3.818017]  __platform_driver_register+0x40/0x50
[    3.822720]  sun8i_mixer_platform_driver_init+0x20/0x1000 [sun8i_mixer]
[    3.829327]  do_one_initcall+0x5c/0x1a0
[    3.833159]  do_init_module+0x54/0x1b8
[    3.836903]  load_module+0x1e6c/0x21c0
[    3.840648]  __se_sys_finit_module+0xc0/0xe0
[    3.844913]  __arm64_sys_finit_module+0x18/0x20
[    3.849440]  el0_svc_common+0x5c/0x100
[    3.853184]  el0_svc_handler+0x2c/0x90
[    3.856929]  el0_svc+0x8/0xc
[    3.859805] ---[ end trace 72fc10bd45fa975b ]---
[    3.865397] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_ops [sun8i_mixer])
[    3.874173] sun4i-drm display-engine: bound 6510000.tcon-top (ops sun8i_tcon_top_ops [sun8i_tcon_top])
[    3.883774] sun4i-drm display-engine: bound 6515000.lcd-controller (ops sun4i_tcon_ops [sun4i_tcon])
[    3.892986] sun8i-dw-hdmi 6000000.hdmi: 6000000.hdmi supply hvcc not found, using dummy regulator
[    3.902142] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY)
[    3.912302] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver
[    3.921178] sun4i-drm display-engine: bound 6000000.hdmi (ops sun8i_dw_hdmi_ops [sun8i_drm_hdmi])
[    3.930085] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.936728] [drm] No driver support for vblank timestamp query.
[    3.943101] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    4.009621] Console: switching to colour frame buffer device 128x48
[    4.046485] sun4i-drm display-engine: fb0: DRM emulated frame buffer device
Initializing random number generator... [    4.081576] random: dd: uninitialized urandom read (512 bytes read)
done.
Starting network: [    4.180639] NET: Registered protocol family 10
[    4.190569] Segment Routing with IPv6
OK
Starting dropbear sshd: [    4.229962] random: dropbear: uninitialized urandom read (32 bytes read)
OK
Welcome to Beelink GS1
buildroot login:
OK Noob here :( forget to declare the eth0 interface in network LOL.
Now it's better (no enable required for GMAC)
Starting network: [    3.827273] NET: Registered protocol family 10
[    3.836993] Segment Routing with IPv6
[    3.858499] dwmac-sun8i 5020000.ethernet eth0: device MAC address 56:9d:9e:04:70:5e
[    3.866350] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    3.880847] dwmac-sun8i 5020000.ethernet eth0: No Safety Features support found
[    3.888182] dwmac-sun8i 5020000.ethernet eth0: No MAC Management Counters available
[    3.895854] dwmac-sun8i 5020000.ethernet eth0: PTP not supported by HW
udhcpc: started, v1.30.1
[    3.920475] random: mktemp: uninitialized urandom read (6 bytes read)
udhcpc: sending discover
[    8.002149] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[    8.010543] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
udhcpc: sending select for 192.168.1.22
udhcpc: lease of 192.168.1.22 obtained, lease time 43200
deleting routers
[   13.052051] random: mktemp: uninitialized urandom read (6 bytes read)
hi, nice to see something happening for the Beelink GS1, since Beelink seems to have aboneded the device allready, development for the orangepi H6 is realy going forwared and is allready usable, is there a way i could assist here to get a mainline kernel runing on the gs1 ?
i tried the android 9.0 image from tanix t6, it boots fine on the beelink as well, but since te tanix t6 only has 10/100mb ethernet it is not usable at all on the gs1..
i was able to build an Armbian image whit your provided dts files for the GS1, HDMI works but it stops booting after starting version 241 and scanning for btrfs mounts.
now compiling librelec....  it is not bbooting, burned the image to an sd card and insertted this card into the beelink gs1, just nothing... no console access, i did not open the box.
best regards
guys finally i got it complied and it is booting
 ____            _ _       _       ____ ____  _
| __ )  ___  ___| (_)_ __ | | __  / ___/ ___|/ |
|  _ \ / _ \/ _ \ | | '_ \| |/ / | |  _\___ \| |
| |_) |  __/  __/ | | | | |   <  | |_| |___) | |
|____/ \___|\___|_|_|_| |_|_|\_\  \____|____/|_|
Welcome to Focal with Linux 5.8.0-sunxi64
No end-user support: built from trunk
System load:   7.64 5.94 3.76   Up time:       17 min           Local users:   2
Memory usage:  23 % of 1926MB   IP:            192.168.
CPU temp:      59°C
Usage of /:    10% of 29G
Last login: Fri Aug 14 11:43:02 2020 from 192.168.
root@beelink-gs1:/home/beelink# cat /var/log/dmesg
[    2.018058] kernel: ohci-platform: OHCI generic platform driver
[    2.018233] kernel: ohci-platform 5101400.usb: Generic Platform OHCI controller
[    2.018260] kernel: ohci-platform 5101400.usb: new USB bus registered, assigned bus number 2
[    2.018371] kernel: ohci-platform 5101400.usb: irq 30, io mem 0x05101400
[    2.081166] kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08
[    2.081186] kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.081202] kernel: usb usb2: Product: Generic Platform OHCI controller
[    2.081215] kernel: usb usb2: Manufacturer: Linux 5.8.0-sunxi64 ohci_hcd
[    2.081228] kernel: usb usb2: SerialNumber: 5101400.usb
[    2.081604] kernel: hub 2-0:1.0: USB hub found
[    2.081642] kernel: hub 2-0:1.0: 1 port detected
[    2.082378] kernel: usbcore: registered new interface driver usb-storage
[    2.082864] kernel: mousedev: PS/2 mouse device common for all mice
[    2.083641] kernel: sun6i-rtc 7000000.rtc: registered as rtc0
[    2.083682] kernel: sun6i-rtc 7000000.rtc: setting system clock to 1970-01-01T00:00:07 UTC (7)
[    2.083699] kernel: sun6i-rtc 7000000.rtc: RTC enabled
[    2.083801] kernel: i2c /dev entries driver
[    2.084183] kernel: sun8i-thermal 5070400.thermal-sensor: Failed to get calibration nvmem cell (-517)
[    2.084207] kernel: sun8i-thermal 5070400.thermal-sensor: Failed to probe thermal sensor (-517)
[    2.084616] kernel: sunxi-wdt 7020400.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    2.085770] kernel: sdhci: Secure Digital Host Controller Interface driver
[    2.085789] kernel: sdhci: Copyright(c) Pierre Ossman
[    2.085818] kernel: Synopsys Designware Multimedia Card Interface Driver
[    2.086425] kernel: sdhci-pltfm: SDHCI platform and OF driver helper
[    2.086569] kernel: sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
[    2.087061] kernel: ledtrig-cpu: registered to indicate activity on CPUs
[    2.087483] kernel: hid: raw HID events driver (C) Jiri Kosina
[    2.087582] kernel: usbcore: registered new interface driver usbhid
[    2.087593] kernel: usbhid: USB HID core driver
[    2.089102] kernel: NET: Registered protocol family 10
[    2.114747] kernel: Segment Routing with IPv6
[    2.114855] kernel: NET: Registered protocol family 17
[    2.114998] kernel: 8021q: 802.1Q VLAN Support v1.8
[    2.115159] kernel: 9pnet: Installing 9P2000 support
[    2.115235] kernel: Key type dns_resolver registered
[    2.115705] kernel: registered taskstats version 1
[    2.115721] kernel: Loading compiled-in X.509 certificates
[    2.119429] kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 8f056047adb00eda9ac57e97a166dd2fcf7fa442'
[    2.119559] kernel: zswap: loaded using pool lzo/zbud
[    2.119818] kernel: Key type ._fscrypt registered
[    2.119830] kernel: Key type .fscrypt registered
[    2.119839] kernel: Key type fscrypt-provisioning registered
[    2.120863] kernel: Btrfs loaded, crc32c=crc32c-generic
[    2.132867] kernel: Key type encrypted registered
[    2.132938] kernel: AppArmor: AppArmor sha1 policy hashing enabled
[    2.132981] kernel: ima: No TPM chip found, activating TPM-bypass!
[    2.133016] kernel: ima: Allocated hash algorithm: sha1
[    2.133048] kernel: ima: No architecture policies found
[    2.133097] kernel: evm: Initialising EVM extended attributes:
[    2.133109] kernel: evm: security.selinux
[    2.133117] kernel: evm: security.SMACK64
[    2.133125] kernel: evm: security.SMACK64EXEC
[    2.133133] kernel: evm: security.SMACK64TRANSMUTE
[    2.133141] kernel: evm: security.SMACK64MMAP
[    2.133149] kernel: evm: security.apparmor
[    2.133156] kernel: evm: security.ima
[    2.133164] kernel: evm: security.capability
[    2.133172] kernel: evm: HMAC attrs: 0x1
[    2.150324] kernel: sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[    2.150634] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator
[    2.151106] kernel: printk: console [ttyS0] disabled
[    2.151193] kernel: 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 24, base_baud = 1500000) is a 16550A
[    3.529582] kernel: printk: console [ttyS0] enabled
[    3.535241] kernel: xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.540777] kernel: xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    3.548578] kernel: xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f064 hci version 0x100 quirks 0x0000000002010010
[    3.558022] kernel: xhci-hcd xhci-hcd.1.auto: irq 31, io mem 0x05200000
[    3.564306] kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    3.572585] kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.579816] kernel: usb usb3: Product: xHCI Host Controller
[    3.584704] kernel: usb usb3: Manufacturer: Linux 5.8.0-sunxi64 xhci-hcd
[    3.590717] kernel: usb usb3: SerialNumber: xhci-hcd.1.auto
[    3.596021] kernel: hub 3-0:1.0: USB hub found
[    3.599811] kernel: hub 3-0:1.0: 1 port detected
[    3.604011] kernel: xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.609516] kernel: xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[    3.617190] kernel: xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    3.623780] kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.631993] kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[    3.640267] kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.647497] kernel: usb usb4: Product: xHCI Host Controller
[    3.652383] kernel: usb usb4: Manufacturer: Linux 5.8.0-sunxi64 xhci-hcd
[    3.658396] kernel: usb usb4: SerialNumber: xhci-hcd.1.auto
[    3.663639] kernel: hub 4-0:1.0: USB hub found
[    3.667431] kernel: hub 4-0:1.0: 1 port detected
[    3.672184] kernel: usb_phy_generic usb_phy_generic.2.auto: supply vcc not found, using dummy regulator
[    3.681520] kernel: musb-hdrc musb-hdrc.3.auto: MUSB HDRC host driver
[    3.687292] kernel: musb-hdrc musb-hdrc.3.auto: new USB bus registered, assigned bus number 5
[    3.695187] kernel: phy id_det change to host
[    3.699041] kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    3.707320] kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.714549] kernel: usb usb5: Product: MUSB HDRC host driver
[    3.719523] kernel: usb usb5: Manufacturer: Linux 5.8.0-sunxi64 musb-hcd
[    3.725535] kernel: usb usb5: SerialNumber: musb-hdrc.3.auto
[    3.730941] kernel: hub 5-0:1.0: USB hub found
[    3.734730] kernel: hub 5-0:1.0: 1 port detected
[    3.740148] kernel: sun8i-thermal 5070400.thermal-sensor: Thermal sensor ready!
[    3.746926] kernel: sun50i_cpufreq_nvmem: Using CPU speed bin speed0
[    3.753271] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[    3.762545] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[    3.771531] kernel: scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
[    3.778802] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[    3.787934] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[    3.796839] kernel: sun8i-mixer 1100000.mixer: deferred probe timeout, ignoring dependency
[    3.804617] kernel: sun4i-drm display-engine: deferred probe timeout, ignoring dependency
[    3.830986] kernel: sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800010d6fb88)
[    3.838733] kernel: sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800010d73d30)
[    3.846811] kernel: sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff800010d6b948)
[    3.855223] kernel: sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator
[    3.863319] kernel: sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY)
[    3.873595] kernel: sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver
[    3.881396] kernel: sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff800010d6ef50)
[    3.888928] kernel: [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.895861] kernel: [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    3.968992] kernel: Console: switching to colour frame buffer device 128x48
[    3.992047] kernel: sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
[    4.000015] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[    4.009558] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[    4.018859] kernel: of_cfs_init
[    4.021482] kernel: of_cfs_init: OK
[    4.025804] kernel: Freeing unused kernel memory: 2240K
[    4.044966] kernel: Run /init as init process
[    4.048715] kernel:   with arguments:
[    4.048718] kernel:     /init
[    4.048720] kernel:   with environment:
[    4.048724] kernel:     HOME=/
[    4.048726] kernel:     TERM=linux
[    4.048729] kernel:     ubootpart=26535d99-01
[    4.048732] kernel:     cgroup_enable=memory
[    4.232944] kernel: usb 2-1: new full-speed USB device number 2 using ohci-platform
[    4.451552] kernel: sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PD regulator
[    4.458928] kernel: sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 96
[    4.465995] kernel: sun50i-h6-pinctrl 300b000.pinctrl: pin-96 (5020000.ethernet) status -517
[    4.473943] kernel: sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 96 (PD0) from group PD0  on device 300b000.pinctrl
[    4.476000] kernel: usb 2-1: New USB device found, idVendor=1997, idProduct=2433, bcdDevice=20.12
[    4.484985] kernel: dwmac-sun8i 5020000.ethernet: Error applying setting, reverse things back
[    4.501453] kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.508803] kernel: usb 2-1: Product: Mini Keyboard
[    4.513119] kernel: usb 2-1: Manufacturer:
[    4.534287] kernel: axp20x-i2c 1-0036: AXP20x variant AXP806 found
[    4.542202] kernel: input:   Mini Keyboard as /devices/platform/soc/5101400.usb/usb2/2-1/2-1:1.0/0003:1997:2433.0001/input/input0
[    4.558861] kernel: input: axp20x-pek as /devices/platform/soc/7081400.i2c/i2c-1/1-0036/axp221-pek/input/input1
[    4.613647] kernel: hid-generic 0003:1997:2433.0001: input,hidraw0: USB HID v1.01 Keyboard [  Mini Keyboard] on usb-5101400.usb-1/input0
[    4.639122] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[    4.655231] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[    4.671115] kernel: dcdca: supplied by vcc-5v
[    4.671886] kernel: sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PD regulator
[    4.694589] kernel: sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 96
[    4.707715] kernel: sun50i-h6-pinctrl 300b000.pinctrl: pin-96 (5020000.ethernet) status -517
[    4.721665] kernel: sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 96 (PD0) from group PD0  on device 300b000.pinctrl
[    4.738715] kernel: dwmac-sun8i 5020000.ethernet: Error applying setting, reverse things back
[    4.753369] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[    4.753525] kernel: dcdcc: supplied by vcc-5v
[    4.770085] kernel: input:   Mini Keyboard Mouse as /devices/platform/soc/5101400.usb/usb2/2-1/2-1:1.1/0003:1997:2433.0002/input/input2
[    4.802605] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[    4.818224] kernel: input:   Mini Keyboard System Control as /devices/platform/soc/5101400.usb/usb2/2-1/2-1:1.1/0003:1997:2433.0002/input/input3
[    4.841183] kernel: dcdcd: supplied by vcc-5v
[    4.854162] kernel: vdd-sys: Bringing 900000uV into 960000-960000uV
[    4.866816] kernel: dcdce: supplied by vcc-5v
[    4.875776] kernel: random: fast init done
[    4.887097] kernel: aldo1: supplied by vcc-5v
[    4.897618] kernel: aldo2: supplied by vcc-5v
[    4.901294] kernel: input:   Mini Keyboard Consumer Control as /devices/platform/soc/5101400.usb/usb2/2-1/2-1:1.1/0003:1997:2433.0002/input/input4
[    4.932759] kernel: vcc-ac200: Bringing 700000uV into 3300000-3300000uV
[    4.933378] kernel: hid-generic 0003:1997:2433.0002: input,hidraw1: USB HID v1.01 Mouse [  Mini Keyboard] on usb-5101400.usb-1/input1
[    4.963419] kernel: aldo3: supplied by vcc-5v
[    4.964035] kernel: sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PD regulator
[    4.987342] kernel: sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 96
[    5.000821] kernel: sun50i-h6-pinctrl 300b000.pinctrl: pin-96 (5020000.ethernet) status -517
[    5.015194] kernel: sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 96 (PD0) from group PD0  on device 300b000.pinctrl
[    5.032739] kernel: dwmac-sun8i 5020000.ethernet: Error applying setting, reverse things back
[    5.047402] kernel: vcc25-dram: Bringing 700000uV into 3300000-3300000uV
[    5.047968] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[    5.076683] kernel: bldo1: supplied by vcc-5v
[    5.076742] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[    5.104047] kernel: bldo2: supplied by vcc-5v
[    5.115551] kernel: bldo3: supplied by vcc-5v
[    5.126615] kernel: vcc-dcxoio: Bringing 700000uV into 1800000-1800000uV
[    5.140353] kernel: bldo4: supplied by vcc-5v
[    5.151482] kernel: cldo1: supplied by vcc-5v
[    5.162396] kernel: cldo2: supplied by vcc-5v
[    5.173065] kernel: vcc-wifi-1: Bringing 700000uV into 3300000-3300000uV
[    5.186275] kernel: cldo3: supplied by vcc-5v
[    5.196981] kernel: vcc-wifi-2: Bringing 700000uV into 3300000-3300000uV
[    5.210056] kernel: sw: supplied by regulator-dummy
[    5.221279] kernel: axp20x-i2c 1-0036: AXP20X driver loaded
[    5.233712] kernel: dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found
[    5.246394] kernel: dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found
[    5.258577] kernel: dwmac-sun8i 5020000.ethernet: PTP uses main clock
[    5.270620] kernel: dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator
[    5.393164] kernel: dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 50000)
[    5.408691] kernel: dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
[    5.421985] kernel: dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
[    5.435122] kernel: dwmac-sun8i 5020000.ethernet: COE Type 2
[    5.445803] kernel: dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
[    5.458242] kernel: dwmac-sun8i 5020000.ethernet: Normal descriptors
[    5.469381] kernel: dwmac-sun8i 5020000.ethernet: Chain mode enabled
[    5.480804] kernel: libphy: stmmac: probed
[    5.505096] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[    5.519833] kernel: sunxi-mmc 4020000.mmc: Got CD GPIO
[    5.553711] kernel: sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    5.569097] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[    5.607719] kernel: sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    5.634376] kernel: mmc0: host does not support reading read-only switch, assuming write-enable
[    5.650005] kernel: mmc0: new high speed SDHC card at address 214f
[    5.661979] kernel: mmcblk0: mmc0:214f APPSD 29.5 GiB
[    5.673809] kernel:  mmcblk0: p1
[    5.784967] kernel: mmc1: new DDR MMC card at address 0001
[    5.796093] kernel: mmcblk1: mmc1:0001 NCard  14.5 GiB
[    5.806370] kernel: mmcblk1boot0: mmc1:0001 NCard  partition 1 4.00 MiB
[    5.818099] kernel: mmcblk1boot1: mmc1:0001 NCard  partition 2 4.00 MiB
[    5.830837] kernel: sunxi-mmc 4022000.mmc: data error, sending stop command
[    5.842442] kernel: sunxi-mmc 4022000.mmc: send stop command failed
[    6.004521] kernel: EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    6.742262] systemd[1]: System time before build time, advancing clock.
[    6.781915] systemd[1]: systemd 245.4-4ubuntu3.2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    6.816069] systemd[1]: Detected architecture arm64.
[    6.876201] systemd[1]: Set hostname to <beelink-gs1>.
[    7.287330] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
[    7.575776] kernel: random: systemd: uninitialized urandom read (16 bytes read)
[    7.591924] systemd[1]: Created slice system-modprobe.slice.
[    7.610341] kernel: random: systemd: uninitialized urandom read (16 bytes read)
[    7.624224] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.643154] kernel: random: systemd: uninitialized urandom read (16 bytes read)
[    7.656839] systemd[1]: Created slice User and Session Slice.
[    7.675383] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.696582] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.719643] systemd[1]: Reached target User and Group Name Lookups.
[    7.739394] systemd[1]: Reached target Remote File Systems.
[    7.758252] systemd[1]: Reached target Slices.
[    7.775723] systemd[1]: Reached target Swap.
[    7.792731] systemd[1]: Reached target System Time Set.
[    7.811314] systemd[1]: Listening on Syslog Socket.
[    7.829763] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.850030] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    7.870935] systemd[1]: Listening on Journal Audit Socket.
[    7.890415] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.910399] systemd[1]: Listening on Journal Socket.
[    7.929266] systemd[1]: Listening on udev Control Socket.
[    7.948557] systemd[1]: Listening on udev Kernel Socket.
[    7.971931] systemd[1]: Mounting Huge Pages File System...
[    7.994845] systemd[1]: Mounting POSIX Message Queue File System...
[    8.018812] systemd[1]: Mounting Kernel Debug File System...
[    8.038057] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[    8.058149] systemd[1]: Starting Restore / save the current clock...
[    8.082280] systemd[1]: Starting Set the console keyboard layout...
[    8.106895] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    8.129214] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    8.134309] systemd[1]: Started Nameserver information manager.
[    8.163655] systemd[1]: Reached target Network (Pre).
[    8.184104] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    8.199693] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    8.221376] systemd[1]: Starting Load Kernel Modules...
[    8.243842] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.268054] systemd[1]: Starting udev Coldplug all Devices...
[    8.275635] kernel: EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    8.307187] systemd[1]: Mounted Huge Pages File System.
[    8.326001] systemd[1]: Mounted POSIX Message Queue File System.
[    8.345558] systemd[1]: Mounted Kernel Debug File System.
[    8.366524] systemd[1]: Finished Restore / save the current clock.
[    8.388368] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    8.414863] systemd[1]: Finished Load Kernel Modules.
[    8.437134] systemd[1]: Finished Remount Root and Kernel File Systems.
[    8.463094] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    8.482511] systemd[1]: Mounting Kernel Configuration File System...
[    8.509852] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    8.525165] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    8.545351] systemd[1]: Starting Load/Save Random Seed...
[    8.568847] systemd[1]: Starting Apply Kernel Variables...
[    8.592514] systemd[1]: Starting Create System Users...
[    8.617833] systemd[1]: Finished Set the console keyboard layout.
[    8.638609] systemd[1]: Mounted Kernel Configuration File System.
[    8.648511] systemd[1]: Finished Apply Kernel Variables.
[    8.658214] systemd[1]: Finished Create System Users.
[    8.670294] systemd[1]: Starting Create Static Device Nodes in /dev...
[    8.679845] systemd[1]: Finished udev Coldplug all Devices.
[    8.694205] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[    8.713447] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[    8.725467] systemd[1]: Finished Create Static Device Nodes in /dev.
[    8.732511] systemd[1]: Reached target Local File Systems (Pre).
[    8.743412] systemd[1]: Mounting /tmp...
[    8.755186] systemd[1]: Starting udev Kernel Device Manager...
[    8.765766] systemd[1]: Mounted /tmp.
[    8.772653] systemd[1]: Reached target Local File Systems.
[    8.783554] systemd[1]: Starting Armbian ZRAM config...
[    8.794995] systemd[1]: Starting Set console font and keymap...
[    8.806081] systemd[1]: Starting Raise network interfaces...
[    8.816959] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    8.823235] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
[    8.823536] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    8.835401] systemd[1]: Finished Set console font and keymap.
[    8.875663] systemd[1]: plymouth-read-write.service: Succeeded.
[    8.877604] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    9.165229] systemd[1]: Started udev Kernel Device Manager.
[    9.172200] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    9.172775] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active.
[    9.183188] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    9.183344] systemd[1]: Reached target Local Encrypted Volumes.
[    9.322415] kernel: zram: Added device: zram0
[    9.323038] kernel: zram: Added device: zram1
[    9.330684] kernel: zram: Added device: zram2
[    9.420988] kernel: cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 912000 KHz
[    9.426950] kernel: cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1080000 KHz
[    9.509564] kernel: zram1: detected capacity change from 0 to 1009922048
[    9.531119] systemd[1]: Finished Raise network interfaces.
[    9.547950] systemd[1]: Found device /dev/ttyS0.
[   10.476338] kernel: mc: Linux media interface: v0.10
[   10.506102] kernel: panfrost 1800000.gpu: clock rate = 432000000
[   10.506123] kernel: panfrost 1800000.gpu: bus_clock rate = 100000000
[   10.507481] kernel: panfrost 1800000.gpu: mali-t720 id 0x720 major 0x1 minor 0x1 status 0x0
[   10.507490] kernel: panfrost 1800000.gpu: features: 00000000,10309e40, issues: 00000000,21054400
[   10.507495] kernel: panfrost 1800000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002821 AS:0xf JS:0x7
[   10.507498] kernel: panfrost 1800000.gpu: shader_present=0x3 l2_present=0x1
[   10.512197] kernel: [drm] Initialized panfrost 1.1.0 20180908 for 1800000.gpu on minor 1
[   10.551039] kernel: videodev: Linux video capture interface: v2.00
[   10.556151] kernel: sun8i-ce 1904000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
[   10.556729] kernel: sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[   10.563629] kernel: sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[   10.563807] kernel: sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[   10.563861] kernel: sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[   10.563931] kernel: sun8i-ce 1904000.crypto: Register cbc(aes)
[   10.564091] kernel: sun8i-ce 1904000.crypto: Register ecb(aes)
[   10.564156] kernel: sun8i-ce 1904000.crypto: Register cbc(des3_ede)
[   10.564210] kernel: sun8i-ce 1904000.crypto: Register ecb(des3_ede)
[   10.564287] kernel: sun8i-ce 1904000.crypto: CryptoEngine Die ID 0
[   10.585969] kernel: asoc-simple-card sound-spdif: dit-hifi <-> 5093000.spdif mapping ok
[   10.664954] kernel: Registered IR keymap rc-beelink-gs1
[   10.684522] kernel: IR NEC protocol handler initialized
[   10.696585] kernel: sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
[   10.697736] kernel: cedrus 1c0e000.video-codec: deferred probe timeout, ignoring dependency
[   10.700975] kernel: random: crng init done
[   10.700982] kernel: random: 7 urandom warning(s) missed due to ratelimiting
[   10.709777] kernel: cedrus 1c0e000.video-codec: Device registered as /dev/video0
[   10.713093] kernel: rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0
[   10.713206] kernel: rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
[   10.713288] kernel: input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input5
[   10.713539] kernel: sunxi-ir 7040000.ir: initialized sunXi IR driver
[   17.740260] kernel: asoc-simple-card hdmi-sound: i2s-hifi <-> 5091000.i2s mapping ok
[   17.759824] systemd[1]: Finished Load/Save Random Seed.
[   17.764939] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   17.765237] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[   17.769527] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   17.772803] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   17.773238] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.776550] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   17.776780] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   17.776851] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   17.777037] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   17.777128] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   17.777187] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   17.785469] systemd[1]: plymouth-read-write.service: Succeeded.
[   17.786603] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   17.789135] kernel: Adding 986248k swap on /dev/zram1.  Priority:5 extents:1 across:986248k SSFS
[   17.945845] kernel: zram0: detected capacity change from 0 to 52428800
[   18.016642] systemd[1]: Finished Armbian ZRAM config.
[   18.024760] systemd[1]: Starting Armbian memory supported logging...
[   18.099804] kernel: EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[   18.099833] kernel: ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
[   19.915005] systemd[1]: Finished Armbian memory supported logging.
[   19.922466] systemd[1]: Starting Journal Service...
[   20.070173] systemd[1]: Started Journal Service.
[  476.917860] kernel: dwmac-sun8i 5020000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=POLL)
[  476.919616] kernel: dwmac-sun8i 5020000.ethernet eth0: No Safety Features support found
[  476.919628] kernel: dwmac-sun8i 5020000.ethernet eth0: No MAC Management Counters available
[  476.919633] kernel: dwmac-sun8i 5020000.ethernet eth0: PTP not supported by HW
[  476.919641] kernel: dwmac-sun8i 5020000.ethernet eth0: configuring for phy/rgmii link mode
[  480.997681] kernel: dwmac-sun8i 5020000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  480.997713] kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 1486.413495] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1487.405448] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1490.413318] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1491.405276] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1494.413142] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1495.405103] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1498.412972] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1499.404926] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1502.412823] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1503.404753] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1506.412619] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1507.404576] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1510.412445] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1511.404403] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1514.412274] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1515.404227] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1518.412100] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1519.404053] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1522.411926] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1523.403882] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1526.411750] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1527.403706] sun6i-rtc 7000000.rtc: rtc is still busy.
RCT Problem ?
  • Werner locked this topic
