Skip to content
View in the app
Armbian Community Forums
[Odroid C2] root login problem.
Featured Replies
i had a little problem with root login on C2. It gives a message about "/usr/local/bin/temper" file absent and goes to restart.
Problem solved by installation "armhf" architecture (temper file is present but compiled for 32 bit).
thank you very much for your work.
Yes, there are some 32bit binaries which needs to be fixed, but nothing is critical. There should be no problem with login except showing an error.
& thanks, I am happy that you give a try. The system will be improved and issues fixed. This was more or less first C2 and first arm64 build.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
