xaduha Posted December 20, 2018 Share Posted December 20, 2018 Latest doesn't seem to work at all, so something like 5.59 4.18.0-rc7-sunxi64 mentioned here https://github.com/armbian/testings would be ideal. Alternatively is there a way I can build old version myself? I ran ./compile docker BOARD=orangepilite2 BRANCH=dev but resulting image doesn't work also. Link to comment Share on other sites More sharing options...
Igor Posted December 20, 2018 Share Posted December 20, 2018 2 hours ago, xaduha said: but resulting image doesn't work also. Doesn't work or there is no HDMI output - which is a known problem? Link to comment Share on other sites More sharing options...
xaduha Posted December 20, 2018 Author Share Posted December 20, 2018 Doesn't boot as far as I can tell, red LED. If that's normal, then I'll check further. I ordered some USB-TTL, but I don't have it yet. Images that I got from official site work (android and ubuntu). Link to comment Share on other sites More sharing options...
Igor Posted December 20, 2018 Share Posted December 20, 2018 32 minutes ago, xaduha said: Doesn't boot as far as I can tell, red LED. If that's normal, then I'll check further. I ordered some USB-TTL, but I don't have it yet. Images that I got from official site work (android and ubuntu). Probably it boots up just fine. We have a recent test report https://github.com/armbian/testings/blob/master/orangepilite2-dev.report confirming that. Official images are based on a Linux 3.10.y which is EOL and code is a terrible state. It's not worth investing precious time into this. Allwinner H6 support for modern kernel is just not there yet while most of the basic things already works for months. HDMI could be also brought up, but it's simply too expensive in the present state. Link to comment Share on other sites More sharing options...
xaduha Posted December 20, 2018 Author Share Posted December 20, 2018 Well the image that report describes isn't available, is it? https://dl.armbian.com/orangepilite2/nightly/ doesn't have it and https://dl.armbian.com/orangepilite2/archive/ is empty. Maybe it's a good idea to keep at least one of those when a report is made? Link to comment Share on other sites More sharing options...
Igor Posted December 20, 2018 Share Posted December 20, 2018 (edited) 18 minutes ago, xaduha said: Maybe it's a good idea to keep at least one of those when a report is made? Armbian has a deterministic compilation process. If an image for this board with a kernel 4.19.1 works, there is a (almost) 99.9% certainty that auto created image with a kernel 4.19.9 works as well. There were no related changes in the source between those two builds. Edited December 20, 2018 by Igor added "almost" :) Link to comment Share on other sites More sharing options...
xaduha Posted December 20, 2018 Author Share Posted December 20, 2018 Well, it works, that red LED misled me. With everything else so far it turned green shortly after powering up with a bootable card. Link to comment Share on other sites More sharing options...
