Hello, everyone.
I'm planning to make a "power button" on orange pi zero using GPIO pins. I'm using kernel 4.x
Of course, some questions.
General idea is:
1) Create the overlay with correct pin number
2) Install acpid
3) It should work.
Questions:
- What resistor should I use to short pin to ground ? 10K ? May other values work ? (Not sure my "scrap metal" box has exact this value)
- How does overlay file look like ? I've seen some variants on the forum, but can some one point to working code ? I'm planning to use PA06 pin, as far as I understand it's a pin 7 on OpiZero 26 pin connector.
- I'm already using overlay for I2C for I2C0 (pins 3 and 5). Do I understand correctly that introducing acpi button won't affect I2c functionality.
Thanks a lot in advance
