Matthew Harding Posted January 30, 2019 Posted January 30, 2019 Armbianmonitor: http://www.nourlgiven.com Hello, I have an issue, i am running the Pine LTS board on eMMC using Armbian latest stable image. We want to access the serial port on the board, so to test i downloaded putty, i select serial and click open. I get an error when opening this, so i have to run: sudo chmod 777 /dev/tty50 and sudo chmod /dev/tty52 on each boot, then i am able to open the serial port using putty. When i look at the ls -l /dev/tty50 i get: crw--w---- 1 root tty 4, 50 Jan 30 30 16:07 tty50. After etensive research i added my user cst to the tty group, but when i reboot i still have to manually run chmod again to access the serial port. Can someone please assist me with getting this command to run on boot or some solution as i cannot every time run this command as these boards are Gateways which will be in remote locations. I did try rc.local but i understand that this is not available anymore. I am not too much of a Armbian guru so if you could assist in detailed steps i would appreciate it. No URL is given when i run the armbianmonitor command, it is blank. Thanks!
martinayotte Posted January 30, 2019 Posted January 30, 2019 On 1/30/2019 at 2:38 PM, Matthew Harding said: sudo chmod 777 /dev/tty50 and sudo chmod /dev/tty52 on each boot Expand Those tty are not the one for serial port, you should use /dev/ttyS0, /dev/ttyS1 or /dev/ttyS2. On 1/30/2019 at 2:38 PM, Matthew Harding said: I did try rc.local but i understand that this is not available anymore. Expand Not true ! /etc/rc.local exist on any Linux including Armbian ...
guidol Posted January 30, 2019 Posted January 30, 2019 On 1/30/2019 at 3:22 PM, martinayotte said: Not true ! /etc/rc.local exist on any Linux including Armbian ... Expand but on the original PC (X86/AMD64) port of debian stretch I didnt got a /etc/rc.local I had to create a own rc.local-service or start /home/guido/rc.local via crontab and @reboot but on armbian in the debian stretch version it is every time available.
Matthew Harding Posted January 31, 2019 Author Posted January 31, 2019 thanks for the replies, i mean S0 and S2. Here is my /etc/inid.d/rc.local !/bin/bash -e ### BEGIN INIT INFO # Provides: rc.local # Required-Start: $all # Required-Stop: # Default-Start: 2 3 4 5 # Default-Stop: # Short-Description: Run /etc/rc.local if it exist ### END INIT INFO echo "running rc.local"> /tmp/rctest.txt sudo chmod 777 /dev/ttyS0 sudo chmod 777 /dev/ttyS2 exit 0 Is there something i am missing here?
