Hi, I'm currently working to enable SPI on NanoPi M4 but it is not working...
I have edited main DT to the following one and now /dev/spidev0.0 appears.
        spi@ff1c0000 {
                compatible = "rockchip,rk3399-spi\0rockchip,rk3066-spi";
                reg = < 0x00 0xff1c0000 0x00 0x1000 >;
                clocks = < 0x08 0x47 0x08 0x15b >;
                clock-names = "spiclk\0apb_pclk";
                interrupts = < 0x00 0x44 0x04 0x00 >;
                pinctrl-names = "default";
                pinctrl-0 = < 0x4a 0x4b 0x4c 0x4d >;
                #address-cells = < 0x01 >;
                #size-cells = < 0x00 >;
                status = "okay";
                phandle = < 0x101 >;
                        spidev{
                    compatible = "spidev";
                    status = "okay";
                    reg = <0>;
                    spi-max-frequency = <10000000>;
But when I checked spi with this tool:https://github.com/torvalds/linux/blob/master/tools/spi/spidev_test.c
I only got the result below and no matrix appears...
spi mode: 0x0
bits per word: 8
max speed: 500000 Hz (500 KHz)
Here is what dmesg | grep spi returns
[    1.560666] rockchip-spi ff1c0000.spi: Failed to request TX DMA channel
[    1.560679] rockchip-spi ff1c0000.spi: Failed to request RX DMA channel
[    1.560689] rockchip-spi ff1c0000.spi: no high_speed pinctrl state
[    1.561289] spidev spi0.0: buggy DT: spidev listed directly in DT
[    1.561365] WARNING: at drivers/spi/spidev.c:720
[    1.561421] PC is at spidev_probe+0x6c/0x1d8
[    1.561430] LR is at spidev_probe+0x68/0x1d8
[    1.564338] [<ffffff80086f86b0>] spidev_probe+0x6c/0x1d8
[    1.564348] [<ffffff80086f57c4>] spi_drv_probe+0x9c/0xb4
[    1.564433] [<ffffff80086f605c>] spi_add_device+0x12c/0x188
[    1.564443] [<ffffff80086f6424>] of_register_spi_device+0x2c0/0x2d8
[    1.564453] [<ffffff80086f78f8>] spi_register_master+0x448/0x484
[    1.564463] [<ffffff80086f7988>] devm_spi_register_master+0x54/0x94
[    1.564474] [<ffffff80086fac60>] rockchip_spi_probe+0x2ec/0x440
[    1.564568] [<ffffff80090f94f8>] rockchip_spi_driver_init+0x18/0x20
[    1.566326] rockchip-pinctrl pinctrl: pin gpio3-7 already requested by ff1c0000.spi; cannot claim for fe300000.ethernet
I have checked the output from the proper GPIO with oscilloscope but found nothing.
almost spent couple weeks on this
Anyone had the same issue or knows what to do here?
@Nao - Do you have any more details on how you got to this point ?
I have made an image using the Armbian repo:
https://github.com/armbian/build/
I then use the Device Tools to inspect the tree:
# fdtdump /boot/dtb/rockchip/rk3399-nanopi4-rev01.dtb > device_tree.txt
This shows:
	aliases {
		spi1 = "/spi@ff1d0000";
    spi@ff1c0000 {
        compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi";
        reg = <0x00000000 0xff1c0000 0x00000000 0x00001000>;
        clocks = <0x00000008 0x00000047 0x00000008 0x0000015b>;
        clock-names = "spiclk", "apb_pclk";
        interrupts = <0x00000000 0x00000044 0x00000004 0x00000000>;
        pinctrl-0 = <0x0000004c 0x0000004d 0x0000004e 0x0000004f>;
        #address-cells = <0x00000001>;
        #size-cells = <0x00000000>;
        status = "disabled";
        phandle = <0x00000105>;
    spi@ff1d0000 {
        reg = <0x00000000 0xff1d0000 0x00000000 0x00001000>;
        clocks = <0x00000008 0x00000048 0x00000008 0x0000015c>;
        interrupts = <0x00000000 0x00000035 0x00000004 0x00000000>;
        pinctrl-0 = <0x00000050 0x00000051 0x00000052 0x00000053>;
        cs-gpios = <0x00000035 0x0000000a 0x00000001>;
        phandle = <0x00000106>;
        spidev@0 {
            compatible = "rockchip,spidev";
            reg = <0x00000000>;
            spi-max-frequency = <0x00989680>;
            status = "okay";
            phandle = <0x00000107>;
I noticed it says its disabled, but if I enable it with:
# fdtput /boot/dtb/rockchip/rk3399-nanopi4-rev01.dtb spi1 status -t s "okay"
Then the device wont boot.
If you dont mind sharing some of the commands you used to get the debug output and enable the interface, that'd be great.
sorry I edited a status at a wrong spi (actually it was spi@ff1c0000, which corresponds to the SPI0 which is only for SPIFlash) and after edited the status at spi@ff1d0000, my machine doesn't boot...
basically I followed an instruction mentioned here,
Just a follow up on SPI .....
I found updating the device tree (dtb file) like so:
# fdtput /boot/dtb/rockchip/rk3399-nanopi4-rev01.dtb /spi@ff1d0000 status -t s "okay"
# fdtput /boot/dtb/rockchip/rk3399-nanopi4-rev01.dtb /serial@ff370000 status -t s "disabled"
I found disabling the serial thing made it all stable so the device didnt lock up.
This enabled the device in the tree like so:
    spi@ff1d0000 {
        status = "okay";
        spidev@0 {
            reg = <0x00000000>;
            status = "okay";
I can see the device here:
root@nanopim4:~# ls -l /dev/spidev1.0
crw------- 1 root root 153, 0 Feb 28 11:46 /dev/spidev1.0
However loading the fbtft driver still doesnt seem happy, reporting the controller is busy....
[   45.573108] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[   45.592470] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
[   45.594705] spidev spi1.0: spidev spi1.0 10000kHz 8 bits mode=0x00
[   45.594949] spidev spi1.0: Deleting spi1.0
[   45.595969] fbtft_device: GPIOS used by 'fb_st7789v':
[   45.595985] fbtft_device: 'reset' = GPIO32
[   45.595994] fbtft_device: 'dc' = GPIO56
[   45.596013] spi spi1.0: fb_st7789v spi1.0 32000kHz 8 bits mode=0x00
[   45.608977] fb_st7789v: module is from the staging directory, the quality is unknown, you have been warned.
[   45.618367] rockchip-spi ff1d0000.spi: spi controller is in busy state!
So I'm not 100% certain its working, but I feel like I'm getting closer.
Update:
I modified the device tree file via...
# dtc -@ -I dtb -O dts -o rk3399-nanopi4-rev01.dts /boot/dtb/rockchip/rk3399-nanopi4-rev01.dtb
# vi rk3399-nanopi4-rev01.dts
... add spidev section to spi@ff1c0000 ..
... update spi@ff1c0000 to status "okay"
# mv /boot/dtb/rockchip/rk3399-nanopi4-rev01.dtb /boot/dtb/rockchip/rk3399-nanopi4-rev01.dtb.backup
# dtc -@ -I dts -O dtb -o /boot/dtb/rockchip/rk3399-nanopi4-rev01.dtb rk3399-nanopi4-rev01.dts
.. but after booting dmesg shows:
[    2.518765] rockchip-pinctrl pinctrl: pin gpio3-7 already requested by ff1c0000.spi; cannot claim for fe300000.ethernet
[    2.518777] rockchip-pinctrl pinctrl: pin-103 (fe300000.ethernet) status -22
[    2.518786] rockchip-pinctrl pinctrl: could not request pin 103 (gpio3-7) from group rgmii-pins  on device rockchip-pinctrl
So I checked my device tree and it looks like its configured like so:
    spi@ff1c0000 {
        status = "okay";
        spidev {
            status = "okay";
            reg = <0x00000000>;
So...... it sounds like its complaining about pin-103 ? but I cant see any reference to that in the spi specification. So I'm not 100% sure where the conflict is.
For reference, it DID create a new device (/dev/spidev32766.0) ... which is not really what I was expecting.
Given the voodoo magic that seems to drive this device, is there any useful reference we can use to line up exactly what ff1c0000 and ff1d0000  should be ? Some posts suggest that spi@ff1c0000 is mapped to the eMMC slot or something.
Maybe "cat /sys/kernel/debug/gpio" could help figure it out ...
I did the same thing with the nightly and got the following
$ ls -l /dev/spidev*
crw------- 1 root root 153, 0 Mar 19 02:38 /dev/spidev0.0
crw------- 1 root root 153, 1 Mar 19 02:38 /dev/spidev1.0
$ dmesg | grep spi
[    2.608230] rockchip-spi ff1c0000.spi: Failed to request TX DMA channel
[    2.608293] rockchip-spi ff1c0000.spi: Failed to request RX DMA channel
[    2.611627] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[    2.611676] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[    3.101184] rockchip-pinctrl pinctrl: pin gpio3-7 already requested by ff1c0000.spi; cannot claim for fe300000.ethernet
so I tested this spidev1.0 with spidev_test.c
but again, it returned this
$ sudo ./a.out -D /dev/spidev1.0
[sudo] password for pi:
spi mode: 0x0
bits per word: 8
max speed: 1000000 Hz (1000 KHz)
Hi
i am using Nano pi M4 board and friendly arm lubuntu.
tried with npi-config to enable SPI but it was not allowed to enable.and showing error!!
I also tried to enable through terminal , but spidev is not shown in /dev/,
also i saw some of comments for enabling spi from dtb file , but for me inside boot directory it was empty . please help how to enable the SPI pin for nanopi m4.
