I'm trying to get something beyond Android on a Jide Remix Mini. Originally sold as an "Android PC", it's now unsupported by manufacturer. The configuration is not bad: Allwinner A64 SOC and my unit has 2GB of RAM and 16 GB eMMC. Unfortunately, linux-sunxi lists it as (yet) unsupported.
I'm not that knowledgeable with image building, so any help would be appreciated.
  On 2/12/2019 at 9:17 AM, Lucil said:
Jide Remix Mini
Expand
I also own a Jide Remix Mini 2G/16G, but Jide didnt delivered a unlock solution after they dropped the Remix OS-Support for the Remix Mini :(
Remix OS isnt bad with the Keyboard/Mouse/Window-Support :)
  On 2/12/2019 at 2:48 PM, martinayotte said:
According to this link, it seems that this box is only booting in "secure" mode, therefore none of the current Armbian image will work.
Expand
Yes, I was thinking of adapting a solution based on
  Quote
Normally Remix Mini boots from the internal 8/16 GiB eMMC. If an SD card with a valid TOC0 header is present, this will take precedence and the BROM will load code from there. FEL mode is another way to access the device: to trigger FEL mode, there is a button accessible via the pin-hole, located between the SD card slot and the audio jack. A somewhat special USB cable (A male to A male) is needed to connect the upper USB host receptacle to your desktop PC, which is running the sunxi-fel tool.
Instead of pressing the button it is possible to have a TOC0 based bootable SD card image, which switches the device into FEL mode:
Expand
... and the rest of the explanation on sunxi website.
Expand
Not bad, but limited. This would be a good always-on low power linux server. I tried with UserLAnd, but results are not good.
