I installed Armbian_5.75_Orangepizeroplus2-h3_Debian_stretch_next_4.19.20.
But it can't boot up.
These image can boot up.
Armbian_5.65_Orangepizeroplus2-h3_Debian_stretch_next_4.14.78
Armbian_5.69_Orangepizeroplus2-h3_Debian_stretch_next_4.19.13
I have been having the same problem for a number of images, I ended up having to add a user patch to use the uboot in May.
    U-Boot SPL 2018.11-armbian (Feb 08 2019 - 11:34:49 +0100)
    DRAM: 512 MiB
    Trying to boot from MMC1
    U-Boot 2018.11-armbian (Feb 08 2019 - 11:34:49 +0100) Allwinner Technology
    CPU:   Allwinner H3 (SUN8I 1680)
    Model: Xunlong Orange Pi Zero Plus 2
    DRAM:  512 MiB
    MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
    Loading Environment from EXT4... ** File not found /boot/boot.env **
    ** Unable to read "/boot/boot.env" from mmc0:1 **
    In:    serial
    Out:   serial
    Err:   serial
    Net:   No ethernet found.
    230454 bytes read in 29 ms (7.6 MiB/s)
    starting USB...
    USB0:   USB EHCI 1.00
    USB1:   USB OHCI 1.0
    USB2:   USB EHCI 1.00
    USB3:   USB OHCI 1.0
    USB4:   USB EHCI 1.00
    USB5:   USB OHCI 1.0
    scanning bus 0 for devices... 1 USB Device(s) found
    scanning bus 2 for devices... 1 USB Device(s) found
    scanning bus 4 for devices... 1 USB Device(s) found
    Autoboot in 1 seconds, press <Space> to stop
    switch to partitions #0, OK
    mmc0 is current device
    Scanning mmc 0:1...
    3798 bytes read in 24 ms (154.3 KiB/s)
    U-boot loaded from SD
    Boot script loaded from mmc
    179 bytes read in 19 ms (8.8 KiB/s)
    4922074 bytes read in 271 ms (17.3 MiB/s)
    7323200 bytes read in 390 ms (17.9 MiB/s)
    ** File not found /boot/dtb/sun8i-h3-orangepi-zero-plus2.dtb **
    libfdt fdt_check_header(): FDT_ERR_BADMAGIC
    No FDT memory address configured. Please configure
    the FDT address via "fdt addr <address>" command.
    Aborting!
    504 bytes read in 214 ms (2 KiB/s)
    Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo
    Aborting!
    504 bytes read in 213 ms (2 KiB/s)
    Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo
    Aborting!
    Error applying DT overlays, restoring original DT
    ## Loading init Ramdisk from Legacy Image at 43300000 ...
       Image Name:   uInitrd
       Image Type:   ARM Linux RAMDisk Image (gzip compressed)
       Data Size:    4922010 Bytes = 4.7 MiB
       Load Address: 00000000
       Entry Point:  00000000
       Verifying Checksum ... OK
    ERROR: Did not find a cmdline Flattened Device Tree
    Could not find a valid device tree
    SCRIPT FAILED: continuing...
    mmc1(part 0) is current device
    Scanning mmc 1:1...
    Device 0: device type unknown
    ... is now current device
    No ethernet found.
    missing environment variable: bootfile
    Retrieving file: pxelinux.cfg/00000000
    No ethernet found.
    No ethernet found.
    No ethernet found.
    No ethernet found.
    No ethernet found.
    No ethernet found.
    No ethernet found.
    No ethernet found.
    Retrieving file: pxelinux.cfg/default-arm-sunxi
    No ethernet found.
    No ethernet found.
    No ethernet found.
    Config file not found
    No ethernet found.
    No ethernet found.
Edited by Igor
spoilers
11 hours ago, Milad said:
but not fixed with your solution
True, it's broken. Working on a better solution, testing at this moment. @Milad Images on the download section has been updated.
It worked well. thanks for your help:)
