Posted (edited)
Hy,
I have tried to use my tinkerboard like an hotspot. configuration done with armbian-config.
when i used the armbian jessie ( ARMBIAN 5.73 stable Debian GNU/Linux 8 (jessie) 4.19.20-rockchip) :
everything works IF i don't do an apt-upgrade.
If i do an apt-upgrade or using the last img of armbian strectch, i cannot connect any devices to my Tinkerboard :
here what i have when i used ssh to see what's wrong :
  Reveal hidden contents
Can somebody help me please :)
Edited by Tido
added spoiler - for better reading, please do that yourself next time. thx
Expand
I can confirm that it is crashing for me too. Finding out why will take a little longer. It would help to know which was last known good configuration ...
Expand
Hy.
When i use your image "ARMBIAN 5.73 stable Debian GNU/Linux 8 (jessie) 4.19.20-rockchip)" it Works. BUT don't do an apt-upgrade,if not it will crash.
I have a copy of this img if you need.
Expand
Provide logs with
armbianmonitor -u
Hello i use ARMBIAN Nightly 5.75.190210 and ubuntu Bionic( 4.19.26). I have exact same bug ( and in last stable release : ARMBIAN 5.73)
I do not remember having this bug on ARMBIAN Stable Next bionic 5.72 (4.19.16).
Expand
On Ubuntu bionic default 4.4 hotspot no have bug.
I find the problem. This is the dnsmasq service that does not want to start with the system despite the presence of the "service dnsmasq start" command in the rc.local file. I do not know where is the problem ??
Would someone have a solution for the hotspot?
For the "next" version, the hotspot lights up, the dnsmasq service works but it is impossible to connect to it (driver problem?).
For the "default" version, the hotspot is launched, but the dnsmasq service does not start at startup, if it is launched at the hands everything works.
Expand
Hy.
I haven't tried tout launcher manually. But with a Bash script starting automatically at the boot but it failed.
Expand
Yes, something is wrong with a driver upstream. It is crashing and until this is not solved, you can use legacy builds until then or some older kernel version -> armbian-config -> system -> alternative kernels.
  On 3/15/2019 at 7:26 AM, domoticity said:
Hy.
Expand
Expand
It's good I found my bug with the hotspot version 4.4 (branch "default"). It was a synchronization command from the RTC that crashed the rc.local script.
Once the bug settles everything has become functional.
By cons version "default" has a dual wifi card (a physics + a virtual) which is very convenient to have the hotspot and wifi connection.
This feature is not present on the "next" version.
After doing some tests.
On the latest version 4.4, the hotspot is running and there is the virtual wifi.
On the latest version 4.19, version 4.19.20 to a buggy hotspot and version 4.19.18 to a functional version (but without the virtual wifi networks).
Version 5.0 RC5 at a functional hotspot.
