Armbian is not switching to new kernel
r_knipp
Armbianmonitor:
I did a dist-upgrade on my BPi M1. Now it is running on
ARMBIAN 5.73 stable Debian GNU/Linux 9 (stretch) 4.7.3-sunxi
When I choose a newer kernel in armbian-config after the reboot it is still running with the old kernel.
When I do an apt-get upgrade it shows this error in the output:
update-initramfs: failed for /boot/initrd.img-4.20.7-sunxi with 1
The BPi is booting from SSD with LVM.
Thank you very much for any help.
Regards,
Robert
Edited by r_knipp
Link to post
Share on other sites
22 hours ago, Igor said:
SDcard's /boot folder must be mounted to /boot all the time. Mount it (add to fstab) and manually install image + dtb package.
Thank you very much for your replay, Igor.
Could you please be more precise? I'm not a linux expert.
Two or three years ago I found an instruction, how to boot Armbian from lvm, that worked for me,
but with this problem I'm overwhelmed.
When I try to mount /dev/mmcblk0p1/boot I get an error.
What do I exactly have to do to run the system on the lvm as if it is running on the SD card?
Link to post
