I've start looking about the Switching DEV to 5.0.y ...
I've done a preliminary trial for OrangePiPCPlus after disabling few patches, etc ... Installed with success ...
Although it produce at lot of patch rejects, I think we should pursue the move to 5.0.y, even if it looks more painful than the switch from 4.19.y to 4.20.y done few weeks ago ...
I'm also calling for help on this move, as I've seen lot of patch rejects in Lima patches : @JMCC are you the expert here ?
For all Devs wishing to keep backup images of 4.20.y, build your images ASAP before the switch occurs ! :rolleyes:
Any concerns ?
EDIT: Oh ! I almost forgot : this is the patching.log, excluding the ones I had to disabled :
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/0020-sunxi-call-fdt_fixup_ethernet-again-to-set-macaddr-f.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/4kfix-limit-screen-to-full-hd.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/Merrii_Hummingbird_A20.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-a20-olinuxino-micro-emmc-support.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-a20-optional-eMMC.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-awsom-defconfig.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-bananapi-bpi-zero.patch
Reversed (or previously applied) patch detected!  Skipping patch.
1 out of 1 hunk ignored -- saving rejects to file arch/arm/dts/Makefile.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-beelink-x2.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-emmc_support_to_neo1_and_2.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-nanopi-air-emmc.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-nanopi-duo.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-nanopi-m1-plus2-emmc.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-nanopineoplus2.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-orangepi-plus2-emmc.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-orangepi-zero-usb-boot-support.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-orangepi-zeroplus.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-orangepi-zeroplus2_h3.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-sunvell-r69.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-xx-boot-auto-dt-select-neo2.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-xx-nanopi-k1-plus-emmc.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add-xx-nanopineocore2.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add_emmc_olinuxino_a64.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/add_emmc_orangepiwin.patch
2 out of 3 hunks FAILED -- saving rejects to file arch/arm/dts/sun50i-a64-orangepi-win.dts.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/adjust-default-dram-clockspeeds.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/adjust-small-boards-cpufreq.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/enable-DT-overlays-support.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/enable-autoboot-keyed.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/enable-ethernet-orangepiprime.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/enable-r_pio-gpio-access-h3-h5.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/fdt-setprop-fix-unaligned-access.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/fix-orangepizero-plus-h3.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/fix-usb1-vbus-opiwin.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/h3-Fix-PLL1-setup-to-never-use-dividers.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/h3-enable-power-led.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/h3-set-safe-axi_apb-clock-dividers.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/lower-default-DRAM-freq-A64-H5.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/sun8i-set-machid.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/sunxi-boot-splash.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/u-boot/u-boot-sunxi/branch_dev/workaround-reboot-is-poweroff-olimex-a20.patch
1 out of 1 hunk FAILED -- saving rejects to file configs/A20-OLinuXino-Lime2-eMMC_defconfig.rej
1 out of 1 hunk FAILED -- saving rejects to file configs/A20-OLinuXino-Lime2_defconfig.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0000-remove-old-ths-node.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0000-unlock-h5-dvfs.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0001-arm64-allwinner-a64-enable-Wi-Fi-for-Pine64.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0002-arm64-allwinner-a64-add-Mali-device-node.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0003-net-stmmac-dwmac-sun8i-support-RGMII-modes-with-PHY-.patch
1 out of 1 hunk ignored -- saving rejects to file drivers/net/ethernet/stmicro/stmmac/dwmac-sun8i.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0004-arm64-allwinner-a64-disable-the-RTL8211E-internal-RX.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0005-drm-gem-cma-Export-with-handle-allocator.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0006-drm-sun4i-Add-GEM-allocator.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0007-Add-sopine-HDMI-sound-and-WiFi-support.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0008-arm64-dts-sun50i-a64-pine64-add-HDMI-audio-nodes.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0009-dt-bindings-update-the-Allwinner-GPADC-device-tree-b.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0011-iio-adc-sun4i-gpadc-iio-rename-A33-specified-registe.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0012-iio-adc-sun4i-gpadc-iio-rework-sampling-start-end-co.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0013-iio-adc-sun4i-gpadc-iio-rework-support-clocks-and-re.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0014-iio-adc-sun4i-gpadc-iio-rework-support-multible-sens.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0015-iio-adc-sun4i-gpadc-iio-rework-support-nvmem-calibra.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0016-iio-adc-sun4i-gpadc-iio-rework-add-interrupt-support.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0017-iio-adc-sun4i-gpadc-iio-add-support-for-H3-thermal-s.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0018-iio-adc-sun4i-gpadc-iio-add-support-for-A83T-thermal.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0019-arm-dts-sunxi-h3-h5-add-support-for-the-thermal-sens.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0020-arm-dts-sun8i-h3-add-support-for-the-thermal-sensor-.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0021-arm-dts-sun8i-h3-add-thermal-zone-to-H3.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0026-iio-adc-Kconfig-enable-A80-A64-and-H5-for-THS.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0027-iio-adc-sun4i-gpadc-iio-add-support-for-H5-thermal-s.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0028-iio-adc-sun4i-gpadc-iio-add-support-for-A80-thermal-.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0029-iio-adc-sun4i-gpadc-iio-add-support-for-A64-thermal-.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0030-arm64-dts-allwinner-h5-add-support-for-the-thermal-s.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0031-arm64-dts-allwinner-h5-add-termal-zone-to-H5.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0032-arm-dts-sun9i-a80-add-support-for-the-thermal-sensor.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0033-arm-dts-sun9i-a80-add-thermal-zone-to-A80.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0034-dts-a64-ths.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0035-clk-sunxi-ng-add-mux-and-pll-notifiers-for-A64-CPU-c.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0036-sun4i-gpadc-iio-ignore-zero-samples-to-avoid-force-p.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0037-a64-dvfs-wip.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0038-ARM-dts-add-gpu-node-to-exynos4.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0039-dt-bindings-add-switch-delay-property-for-mali-utgar.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0042-drm-lima-add-lima-uapi-header.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0043-drm-lima-add-mali-4xx-GPU-hardware-regs.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0044-drm-lima-add-lima-core-driver.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0045-drm-lima-add-GPU-device-functions.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0046-drm-lima-add-PMU-related-functions.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0047-drm-lima-add-L2-cache-functions.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0048-drm-lima-add-GP-related-functions.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0049-drm-lima-add-PP-related-functions.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0050-drm-lima-add-MMU-related-functions.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0051-drm-lima-add-BCAST-related-function.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0052-drm-lima-add-DLBU-related-functions.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0053-drm-lima-add-GPU-virtual-memory-space-handing.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0055-drm-lima-add-buffer-object-functions.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0056-drm-lima-add-GEM-related-functions.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0057-drm-lima-add-GEM-Prime-related-functions.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0058-drm-lima-add-GPU-schedule-using-DRM_SCHED.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0059-drm-lima-add-context-related-functions.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0061-drm-lima-use-SPDX-identifiers-and-change-copyright.patch
1 out of 1 hunk FAILED -- saving rejects to file drivers/gpu/drm/lima/Kconfig.rej
1 out of 1 hunk FAILED -- saving rejects to file drivers/gpu/drm/lima/Makefile.rej
1 out of 1 hunk FAILED -- saving rejects to file drivers/gpu/drm/lima/lima_ttm.c.rej
1 out of 1 hunk FAILED -- saving rejects to file drivers/gpu/drm/lima/lima_ttm.h.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0062-drm-lima-lima_reg.h-use-BIT.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0063-drm-lima-add-IRQF_SHARED-for-GP-irq.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0064-drm-lima-Kconfig-only-depend-on-ARM-or-ARM64.patch
1 out of 1 hunk ignored -- saving rejects to file drivers/gpu/drm/lima/Kconfig.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0065-drm-lima-add-comments-for-lima_reg.h.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0066-drm-lima-wait-bo-fence-before-bo-close.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0067-drm-lima-refine-lima_gem_sync_bo.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0068-drm-lima-vm-will-be-freed-when-lima_sched_free_job.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0069-drm-lima-vm-alloc-buffer-with-multi-page-table.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0070-drm-lima-clear-vm-page-table-when-alloc.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0071-drm-lima-update-SPDX-header-to-match-kernel-rules.patch
1 out of 1 hunk ignored -- saving rejects to file drivers/gpu/drm/lima/Makefile.rej
1 out of 1 hunk ignored -- saving rejects to file drivers/gpu/drm/lima/lima_ttm.c.rej
1 out of 1 hunk ignored -- saving rejects to file drivers/gpu/drm/lima/lima_ttm.h.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0072-drm-fourcc-add-ARM-tiled-format-modifier.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0073-drm-lima-add-DRM_LIMA_GEM_MOD-ioctl.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0074-a64-ccu-enable-LDOs-for-pll-mipi-and-add-min-max-rat.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0075-sopine-baseboard-enable-HS200-for-eMMC.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0077-drm-lima-port-to-4.18-kernel.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0078-drm-lima-user-can-choose-not-to-use-dlbu-on-mali450.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0080-rtl8723bs-disable-error-message-about-failure-to-all.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0081-arm64-arch_timer-Workaround-for-Allwinner-A64-timer-.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0082-arm64-dts-allwinner-a64-Enable-A64-timer-workaround.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0085-clk-sunxi-ng-Adjust-MP-clock-parent-rate-when-allowe.patch
2 out of 2 hunks ignored -- saving rejects to file drivers/clk/sunxi-ng/ccu_mp.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0101-arm64-dts-allwinner-a64-Enable-HDMI-output-on-A64-bo.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0102-dt-bindings-power-supply-axp20x-add-AXP813-AC-power-.patch
2 out of 2 hunks ignored -- saving rejects to file Documentation/devicetree/bindings/power/supply/axp20x_ac_power.txt.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0103-dt-bindings-power-supply-axp20x-add-AXP803-power-bin.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0104-dt-bindings-gpio-gpio-axp209-add-AXP803-GPIO-binding.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0105-dt-bindings-iio-adc-add-AXP803-ADC-bindings.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0106-ARM-dts-axp81x-add-AC-power-supply-subnode.patch
1 out of 1 hunk ignored -- saving rejects to file arch/arm/boot/dts/axp81x.dtsi.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0107-arm64-dts-allwinner-axp803-add-AC-and-battery-power-.patch
1 out of 1 hunk ignored -- saving rejects to file arch/arm64/boot/dts/allwinner/axp803.dtsi.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0108-arm64-dts-allwinner-a64-sopine-baseboard-enable-powe.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0109-arm64-dts-allwinner-a64-pinebook-enable-power-suppli.patch
1 out of 1 hunk ignored -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-a64-pinebook.dts.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0110-power-supply-add-AC-power-supply-driver-for-AXP813.patch
7 out of 7 hunks ignored -- saving rejects to file drivers/power/supply/axp20x_ac_power.c.rej
1 out of 1 hunk ignored -- saving rejects to file include/linux/mfd/axp20x.h.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0111-mfd-axp20x-Add-AC-power-supply-cell-for-AXP813.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0112-mfd-axp20x-Add-supported-cells-for-AXP803.patch
1 out of 1 hunk FAILED -- saving rejects to file drivers/mfd/axp20x.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0117-ASoC-dt-binding-Add-bindings-for-Allwinner-A64-codec.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0120-arm64-dts-allwinner-a64-add-nodes-necessary-for-anal.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0121-arm64-dts-allwinner-a64-enable-sound-on-Pine64-and-S.patch
2 out of 2 hunks ignored -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-a64-pine64.dts.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0122-arm64-dts-allwinner-a64-enable-sound-on-Pinebook.patch
1 out of 2 hunks FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-a64-pinebook.dts.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0123-drm-sun4i-tcon-enable-dithering-on-tcon0-is-there-s-.patch
1 out of 3 hunks FAILED -- saving rejects to file drivers/gpu/drm/sun4i/sun4i_tcon.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0124-drm-lima-Fix-Lima-to-work-with-drm-scheduler-changes.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0125-drm-lima-Fix-lima-cache-creation.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0126-drm-bridge-move-ANA78xx-driver-to-analogix-subdirect.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0127-drm-bridge-split-some-definitions-of-ANX78xx-to-dedi.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0128-drm-bridge-extract-some-Analogix-I2C-DP-common-code.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0129-dt-bindings-Add-ANX6345-DP-eDP-transmitter-binding.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0130-drm-bridge-Add-Analogix-anx6345-support.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0131-arm64-allwinner-a64-add-pinmux-for-RGB666-LCD.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0132-arm64-allwinner-a64-enable-ANX6345-bridge-on-Pineboo.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0134-drm-sun4i-rgb-Add-5-tolerance-to-dot-clock-frequency.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0135-clk-sunxi-ng-enable-so-said-LDOs-for-A64-SoC-s-pll-m.patch
1 out of 1 hunk ignored -- saving rejects to file drivers/clk/sunxi-ng/ccu-sun50i-a64.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0136-hdmi-audio-fixup.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0137-Pinebook-HDMI-audio.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0139-Bluetooth-Add-new-quirk-for-broken-local-ext-feature.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0140-Bluetooth-hci_h5-Add-support-for-reset-GPIO.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0141-dt-bindings-net-bluetooth-Add-rtl8723bs-bluetooth.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0142-Bluetooth-hci_h5-Add-support-for-binding-RTL8723BS-w.patch
1 out of 3 hunks FAILED -- saving rejects to file drivers/bluetooth/hci_h5.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0143-Bluetooth-btrtl-add-support-for-the-RTL8723CS.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0144-arm64-allwinner-a64-enable-Bluetooth-On-Pinebook.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0145-arm64-allwinner-a64-enable-Bluetooth-On-Pine64.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/0146-arm64-allwinner-a64-enable-Bluetooth-On-SoPine-baseb.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/ARM-dts-sun7i-Disable-OOB-IRQ-for-brcm-wifi-on-Cubietruck-and-Banana-Pro.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/Revert_BT_HCIUART_RTL_ACPI_dependency.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/add-BergMicro-SPI-flashes.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/add-h5-emmc-compatible.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/add-orangepi-zeroplus2.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/add-orangepi3.patch
1 out of 1 hunk FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/Makefile.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-a64-v3-02-19-arm64-dts-allwinner-a64-Add-Pine64-LTS-device-tree-file.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-a64-v3-15-19-arm64-dts-allwinner-a64-Olinuxino-enable-USB.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-a64-v3-18-19-arm64-dts-allwinner-a64-NanoPi-A64-Add-Wifi-chip.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-a64-v3-19-19-arm64-dts-allwinner-a64-NanoPi-A64-Add-blue-status-LED.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-a83t-add-one-more-freq-step-1.6ghz.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-a83t-v7-3-4-ARM-dts-sun8i-a83t-bananapi-m3-Enable-IR-controller.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-bpi-m2-zero-enable-dvfs.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-cubieboard-cubietruck-green-LED-mmc0.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-cubietruck-enable-uart2.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-cubietruckplus-enable-hdmi.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h2plus-nanopi-duo-add-device.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h2plus-sunvell-r69-add-device.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h3-add-rtc-osc32k-out.patch
2 out of 2 hunks FAILED -- saving rejects to file arch/arm/boot/dts/sunxi-h3-h5.dtsi.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h3-nanopi-fix-random-ethernet-mac.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h3-nanopi-neo-core-add-emmc.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h5-add-0000-nanopi-k1plus.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h5-add-0001-nanopi-neo-core2.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h5-add-0002-nanopi-neo2-v1.1.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h5-add-0003-nanopi-m1-plus2.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h5-orangepi-pc2-add-spi-flash.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h5-orangepi-zero-plus-add-regulator.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h5-orangepi-zero-plus2-onboard-led.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h6-add-orangepi-one-plus-and-lite2.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h6-add-rtc-osc32k-out.patch
2 out of 2 hunks ignored -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-h6-clock-higher.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-nanopiair-h3-camera-wifi-bluetooth-otg.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-olinuxino-A64-add-eMMC.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-add-RTL8723.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0008-arm64-allwinner-h6-add-missing-mmc-pins.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0009-arm64-allwinner-h6-enable-MMC0-2-on-Pine-H64.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0018-arm64-allwinner-h6-enable-AXP805-PMIC-on-Pine-H64.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0019-arm64-allwinner-h6-add-PCF8563-RTC-on-Pine-H64-board.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0020-phy-allwinner-add-phy-driver-for-USB3-PHY-on-Allwinn.patch
1 out of 1 hunk FAILED -- saving rejects to file drivers/phy/allwinner/Kconfig.rej
1 out of 1 hunk ignored -- saving rejects to file drivers/phy/allwinner/Makefile.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0021-dt-bindings-usb-add-binding-for-the-DWC3-controller-.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0023-arm64-allwinner-h6-add-USB3-device-nodes.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0024-arm64-allwinner-h6-enable-USB3-port-on-Pine-H64.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0025-phy-sun4i-usb-add-support-for-missing-USB-PHY-index.patch
3 out of 3 hunks ignored -- saving rejects to file drivers/phy/allwinner/phy-sun4i-usb.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0026-phy-sun4i-usb-add-support-for-H6-USB2-PHY.patch
5 out of 5 hunks ignored -- saving rejects to file drivers/phy/allwinner/phy-sun4i-usb.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0027-arm64-allwinner-h6-add-USB2-related-device-nodes.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0028-arm64-allwinner-h6-enable-USB2-on-Pine-H64.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0029-arm64-allwinner-h6-add-basical-DVFS-support.patch
4 out of 5 hunks FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0030-arm64-allwinner-h6-add-CPU-regulator-for-Pine-H64.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0032-net-stmmac-sun8i-force-select-external-PHY-when-no-i.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0034-arm64-allwinner-h6-add-EMAC-device-nodes.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine-h6-pine-h6-0035-arm64-allwinner-h6-add-support-for-the-Ethernet-on-P.patch
3 out of 3 hunks ignored -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6-pine-h64.dts.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/board-pine64-add-spi-flash.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/dvbskys960-fix.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/fix-bananam2ultra-missing-clk-out-a.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/fix-bananapi-m2-plus-wifi.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/fix-bananapi-m2-ultra-wifi.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/fix-orangepiwin-usb.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-add-H6-DMA.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-add-H6-GPIO-disable_strict_mode.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-add-H6-I2Cs.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-add-H6-SPIs.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-add-H6-UARTs.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-add-H6-Watchdog.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-add-configfs-overlay.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-add-h3-mixer1.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-add-i2s-DT-pins.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-add-missing-uart2_rts_cts_pins-H3-H5.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-add-nand-H27UBG8T2BTR.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-add-overlay-compilation-support.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-arm64-add-proc-cpuinfo-entries.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-armbian-boot-logo-on-screen-center.patch
2 out of 3 hunks FAILED -- saving rejects to file drivers/video/fbdev/core/fbmem.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-axp20x-sysfs-interface.patch
1 out of 5 hunks FAILED -- saving rejects to file drivers/mfd/axp20x.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-enable-allwinner-SoCs-SID-support.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-enable-kernel-dtbs-symbol-generation.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-increasing_DMA_block_memory_allocation_to_2048.patch
1 out of 1 hunk FAILED -- saving rejects to file arch/arm64/mm/dma-mapping.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-packaging-4.20-dev.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-provoke-the-early-load-of-sun8i-codec.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-spidev-remove-warnings.patch
1 out of 1 hunk FAILED -- saving rejects to file drivers/spi/spidev.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-sunxi-overlays.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/general-sunxi-rtc-clocksource.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/userpatches/kernel/sunxi-dev/i2c-mv64xxx-debug.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/userpatches/kernel/sunxi-dev/make-usb0host-opilite.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/nand-disable-badblock-check-for-migration.patch
1 out of 2 hunks FAILED -- saving rejects to file drivers/mtd/nand/raw/nand_base.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/p-board-h6-add-THS.patch
1 out of 1 hunk ignored -- saving rejects to file drivers/nvmem/sunxi_sid.c.rej
1 out of 1 hunk ignored -- saving rejects to file drivers/thermal/Makefile.rej
1 out of 4 hunks FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/userpatches/kernel/sunxi-dev/rs485-8250_dw.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/userpatches/kernel/sunxi-dev/sc16is7xx-clk.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/userpatches/kernel/sunxi-dev/sc16is7xx-debug.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/simple-amplifier_add-vcc-regulator.patch
2 out of 2 hunks ignored -- saving rejects to file sound/soc/codecs/simple-amplifier.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/userpatches/kernel/sunxi-dev/spics-debug.patch
1 out of 2 hunks FAILED -- saving rejects to file drivers/spi/spi.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/sun50i-codec-analog_add-cpvdd-regulator.patch
2 out of 2 hunks ignored -- saving rejects to file sound/soc/sunxi/sun50i-codec-analog.c.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/sunxi-h5-add-gpio-regulator-overclock.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/ths-29-sun4i-gpadc-iio-add-h5-thermal-zone.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/timekeeping32-tweaks-for-4.20.y.patch
1 out of 1 hunk FAILED -- saving rejects to file include/linux/timekeeping32.h.rej
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/timekeeping32-tweaks-for-5.0.y.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/update-nanopi-neo-plus2-enable-regulator-fix-leds.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/v3-1-2-si2168-Set-TS-clock-mode-and-frequency.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/v3-2-2-dvbsky-Add-support-for-MyGica-T230C-v2.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/wifi-2001-01-rtl8188eu-kconfig-makefile.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/wifi-2002-02-rtl8188eu.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/wifi-3001-add-realtek-8189es-kconfig-makefile.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/wifi-3002-add-realtek-8189es.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/wifi-4001-add-realtek-8723cs-kconfig-makefile.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/wifi-4002-add-realtek-8723cs.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/wifi-8723bs-AP-bugfix.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/wifi-add-realtek-8189fs.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/wifi-add-xradio.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/wifi-bt-bananapi-m2-plus.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/wifi-orangepi-pc-plus-pwrseq.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/wifi-orangepi-prime.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/wifi-orangepi-zero-fix-xradio-interrupt.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/xxx-nanopik1plus.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/xxx-nanopineo2v1.0-dvfs.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/xxx-olinuxino-battery-audio.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/xxx-orangepi2-plus-regulator.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/xxx-orangepiprime-addregulator.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/xxx-orangepizero-plus2-default-regulator.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/xxx-pinebook-revert-pwm-polairity-TEMP-WORKAROUND.patch
Processing file /disk2/home/martin/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/xxx-teres-fixed.patch
martin@giroles-hpel8300:~/git-work/igorpecovnik-armbian/build$
I'm also calling for help on this move, as I've seen lot of patch rejects in Lima patches : [mention=7899]JMCC[/mention] are you the expert here ?
Any concerns ?
So what’s the suggested strategy for dealing with the patches? Like whats a method to determine which do we trash, which do we assume is mainlined already, which need to be fixed etc....
Sent from my iPad using Tapatalk
3 hours ago, martinayotte said:
Any concerns ?
None since its DEV.
What concerned me more is that https://github.com/megous/linux 4.19.y is getting behind. Changes, which are landing to the mainline, are getting harder and harder to merge in. Anyone remember what will be lost when moving to mainline 4.19.y as a base?
Is is sane to think moving stable branch to 4.20.y?
Well, I've never had a look into the Lima source code, and I don't have any Allwinner HW available to test (my OPi+2E is "on duty" as a production machine). But, if it's about checking some rejected patches, of course I can try to lend a hand.
Should we tag the last commit before changing to the 5.0 work?
I think that 4.20.y is pretty stable, so Yes, NEXT could be change to 4.20.y ...
@Igor ? Do you wish to do a backup of current DEV-4.20.y to use it to update NEXT in a near future ?
I will probably start doing commits for DEV-5.0.y in next few days, I've upgraded almost all my park/garden of Allwinner boards ...
On 3/12/2019 at 3:53 AM, Igor said:
New tag should be enough.
I've committed the initial stuff ! :rolleyes:
Now, I will pursue the patch cleaning ...
Let me know if you are unable to build 5.0.y on some Allwinner boards ...
